Which simulator is better for a 6-DOF Stewart motion platform project? FlightGear vs X-Plane
Discussion in 'Flight Simulator 2020 - FS2020' started by Kamal alrawafi, Nov 23, 2025 at 17:17.
  1. Kamal alrawafi
    Kamal alrawafi New Member
    6Coins
    Hello everyone,
    I'm building a 6-degree-of-freedom Stuart rig for an air traffic simulation project, and would like to benefit from the community's experience before choosing a main simulator
    My settings:
    – Traffic server running on a PC (UDP input)
    – Washing algorithm + inverse kinetics calculated on computer
    - Platform driven by a microcontroller (Ethernet/serial)
    - Target refresh rate: 50-150Hz for motion
    - Operating system: Windows 11
    I'm currently comparing two simulators: FlightGear and X-Plane.
    What I need from the simulator:
    - Low-latency motion data output with six degrees of freedom (push, swing, lift and roll, pitch, and yaw)
    - Stable data flow to traffic server (UDP preferred)
    - Consistency in values (no random mutations)
    - Community support/examples/plugins if possible
    My impressions so far:
    – FlightGear gives you complete freedom (open source, FDM editing, socket broadcast)
    – X-Plane seems to have a strong motion platforming ecosystem (DataRefs + Plugins + SimTools support)
    Before I choose, I'd like to hear real opinions from people who have actually tested motion rigs:
    • Which one gave better motion response and lower latency?
    • Which was easier to handle with the motion server?
    • Are there any recommended plugins/tools/example code?
    • If you switch from one to the other – why?
    I'm grateful for any comments, screenshots, logs or links to build threads.
    Thank you in advance!
