Question Wich one is better for gear ratio???
Discussion in 'Ready, set, go - Start your engines' started by Arta Yasa, Feb 13, 2023.
  1. Arta Yasa
    Arta Yasa Member
    794Coins
    Hi all.
    Wich one is better for gear ratio exsample i have motpr with 3000rpm.
    1 is gear ratio 1:50 worm gear.
    2 is gear ratio with multiple gear
    Exsaple 1st ratio is 1:10 2nd ratio is 1:5. (Mybe worm gear or etc)
    Wich one is better? Because the output smae 60rpm.
  2. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,769Coins
    With a two stage you get more backlash and probbebly a lower efficienty
