[WIP] DIY active pedal by Tristian Fenwick
Discussion in 'DIY peripherals' started by RacingMat, Apr 24, 2023.
  1. RacingMat
    21,067Coins
    Hi there :)
    Here is a promissing project for DIY active pedals: https://github.com/tjfenwick/DIY-Sim-Racing-Active-Pedal by Tristian Fenwick
    FYI, "active pedal" by SimuCube intends to reproduce any travel and force profiles:
    mainly you can customize pedal travel distance, brake pressure but also brake air gap, ABS shaking... without any screwdriver or wrench. :)
    "I built this pedal using a load cell, NEMA 23 Integrated Easy Servo Motor, and Arduino Uno, for a fraction of the cost of the official Simucube pedals. While there are still some issues to address, such as shaky ADS1256 readings and a lack of computing power on the Arduino, I'm really pleased with how it's coming along."
    BOM: 250€
    **Some of these parts will be switched out as I only picked them cause I had them laying around
    • 300kg Load Cell $36.69
    • NEMA 23 Integrated Easy Servo Motor 130w ( iSV57T-130 ) $93.93 (Could probably get away with the smaller 90 watt version and cut down on the overall length of the pedal)
    • ADS1256 $17.99
    • 8x 608-2RS Ball Bearing $8.99
    • Tr8x8 Lead Screw with T8 Brass Nut $11.99 (upgrading to a ball screw in the future)
    • 8mm to 8mm Shaft Coupling $9.99
    • Arduino Uno $16.99 (upgrading to a Teensy 4.0 in the future)
    • 2x Micro Limit Switch $5.99
    • DROK 48V Power Supply, AC 110V/220V to DC 0-48V 10A 480W $40.99
    In my opinion, the tricky part is the command loop: highest rates needed, lowest noise, telemetry filtering (just like our direct drive wheels)... I wish him a great achievement.
    • Like Like x 5
  2. iLLuac4
    iLLuac4 Active Member
    896Coins
  3. workfayer
    workfayer New Member
    Brazil
    89Coins
    2DOF, 3DOF, Arduino
    Is it possible to adapt this system to work with an IBT2 and motor brush? To make the closed circuit, it would be enough to use an incremental motor coupled to the motor, this would make the project accessible to many more people, unfortunately this motor from the original design is very expensive in my country, thank you :):)
  4. Thierry59191
    Thierry59191 Member
    - 76Coins
    4DOF
    It's a great project that I'd love to implement, but I'll wait for Simgic to release their version, hoping it will be well-polished and relatively affordable.
    I think 3D prints, even with technical filaments, won't last over time—especially since we usually slam the brakes hard when we miss a braking point :grin
  5. Misanthrop
    Misanthrop Active Member
    754Coins
    Only a matter of your design, there are already many 3d printed pedals and no one is breaking ;)
  6. Thierry59191
    Thierry59191 Member
    - 76Coins
    4DOF
    It's true that after some research, I found a lot of them made with 3D printing, but I have to admit I wouldn't feel confident considering how hard I brake :D:D
  7. Map63Vette
    Map63Vette Active Member
    Mechanical Engineer
    Lawrence, KS
    709Coins
    A 300kg load cell seems awfully overkill, doesn't it? Is that more due to physical size requirements or limitations? I know people like their stiff sim pedals, but 600+ lbs of force is an awful lot of force to be generating with a single leg, even with some mechanical advantage. I realize it's not the more expensive part of the system though, so maybe minimal savings to be had. But it could give you better resolution to the force, if that matters.
  8. Misanthrop
    754Coins
    A Loadcell can be the most expensive Part of the build!
    Most of the people are using 200 or 100kg Loadcells.
