Question Wiper motor starts instantly when plug USB
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by tselehub, Mar 11, 2024.
  1. tselehub
    tselehub New Member
    98Coins
    HI, I have made all the connections correctly. I have checked them 100 times in the last ten days. When I plug it into the computer, the motor starts right up. I use arduino uno + IBT. Why is he doing that? I'm crazy, I've been trying for 10 days. Im trying to make 1dof (only traction loss)
    Check the video:
    https://youtube.com/shorts/JbRbufKJtbc
  2. ProjectF1
    ProjectF1 Member
    Electrician
    202Coins
    AC motor, Arduino, 4DOF
    I think you have not connected the position feedback potentiometer and the motor is looking for its position...
  3. tselehub
    tselehub New Member
    98Coins
    when I connected it he broke it. the motor did not stop.
  4. Trent Robinson
    Trent Robinson Member
    Systems Engineer
    258Coins
  5. tselehub
    tselehub New Member
    98Coins
    I will try BUT if you see my motor spin very fast. Every video I have see from other people spin slower and make slow moves
  6. Trent Robinson
    Systems Engineer
    258Coins
    I can't see your settings well as it is too blurry, but it looks like you have it on motion and without the feedback info, the motor is rapidly trying to match the curve without the feedback info.
    The speed of the motor is a function of the maxpwm, gear ratio of your motor and load. A 50:1 with low maxpwm will be "slow". A 25:1 with high maxpwm will move more quickly. Load is obviously nonexistent in this case.
    Following that procedure will ensure success if your wiring and hardware is correct.
    147,009Coins
    +10,845 / 53 / -2
    These are the steps to setting up SMC3, which includes initially not powering motors, please follow each step and if any step fails then report that and include pictures, not video, of all settings:
    1. Disconnect the motor power supply
    2. Make sure Simtools is not running – we’re not ready for that yet!
    3. Wire up the Arduino (with SMC3 installed) to your H-Bridges and connect to your computer via USB
    4. Run the Windows SMC3 Utility software and make sure it communicates with the Arduino (There is no need to set baud rates, they are not configurable)
    5. Set the Kp, Ki, Kd, PWMmin, PWMmax, PWMrev to 0 for ALL motors (This will make sure the motors don’t move)
    6. Set Clip to 255 (you need to do this first) and Limit to 255 (This will give you plenty of margin if something goes wrong while setting up)
    7. Turn on the power to your motors – nothing should move at this stage!
    8. Set Kp to about 400
    9. Now slowly, increase PWMmax… at some point the motor should start to move. When it does check the “Green” feedback line is moving toward the “Blue” target position.
      • If it is then that motor and feedback is wired correctly - proceed to test other motors.
      • If it is moving away turn off motor power immediately (or quickly reduce PWMmax again). In this case you need to either reverse the wires to the motor being tested –OR– reverse the +5V and GND wires to your feedback pot for the motor being tested (do not do both). Restart the test from the beginning.
    10. Do the above for each motor
