X-sim plugin data format
Discussion in 'Force-Sender & Plugins' started by overloaded, Oct 19, 2011.
  1. overloaded
    overloaded New Member
    8Coins
    Hello everyone!
    I`m trying to interface different games from own software to play with forces-to-platform position algorythms, using x-sim plugins.
    What I need (please see attached image) is Ax Ay Az acceleration(in Gs, where in static position Az = -1, Ax = 0 pointing right, Ay = 0 pointing to the forward of vecicle ), and Wx Wy Wz angular speeds in rad/sec.
    I`ve seen source of plugin but can't figure out for sure the right parameters position and sign in data[22] array(see code) and their format and units of measure.
    I understood that for example
    Ax = -data[12] / 100000 (G), but if it is possible to get info on indexes for all 6 params please post it in format provided in my example an according to attached image.
    Forehead thank you.
    Code:
    typedef struct PluginDataEx
    	int			data[22];
    	int			speed;					//current speed in kmh
    	int			rpm;					//rpm
