x-sim sender and profiler
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by jmb racing, Apr 18, 2010.
Thread Status:
Not open for further replies.
  1. jmb racing
    jmb racing New Member
    Oñati (Spain)
    2Coins
    Hello.
    I have a problem with this two softwares. I want to do de testing to know if the actuators are ''OK'', but I can't do it. When I click start it says that profiler doesn't connect with sender or something like that.
    Thanks.
  2. Nima
    Nima Member Gold Contributor
    Glaser
    Bad Zwischenahn
    531Coins
    you must start the sender and than you can see in the profiler on the right top
    the ip from the sender pc.you must have the profiler ip in the sender.do you have one ore two pc?
  3. jmb racing
    Oñati (Spain)
    2Coins
    I solved the above, changing the version, but now I have another problem, which in profliler It moves the graphic, but the actuator does not move while I play.
  4. Nima
    Glaser
    Bad Zwischenahn
    531Coins
    look in the output sektion you must have the name from your scn5 in output.
  5. jmb racing
    Oñati (Spain)
    2Coins
    all solved
  6. jagadeeswararao
    jagadeeswararao New Member
    self employed
    India
    102Coins
    can anyone suggest where I can download x sim sender and x sim profiler
    148,064Coins
    +10,885 / 54 / -2
Thread Status:
