Yaw axis washout
Discussion in 'SimTools DIY Version' started by Jan Kroupa, Mar 18, 2014.
  1. Jan Kroupa
    Jan Kroupa New Member
    Czech Republic
    176Coins
    4DOF, 6DOF
    Hello, please can someone help me with setting of yaw axis?
    I am building endless rotation simulator. When I am play DIRT3 I have problem with washout on yaw axis (roation): when I have full washout filter set, it take loooong time to wash back into zero,
    can I somehow speedup washing?
    Imagine you turn to right and simulator start turning, that is OK,
    then you go straight, but simulator si still rotating and stoping very slowly, and that is NOT OK.
    very similar problem I have wirh Xplane and helicopter rotating.
    P.S. Sorry for my bad english
  2. eaorobbie
    20,431Coins
    High value of washout will cause lag, not fully tested as of yet, try small numbers and adjusting the % of axis and Min Max settings.
    With Dirt3 have you tried the extra1 DOForce its traction loss, when I get time back in the workshop a drift frame(tractionloss) is the next addition to my seatmover.
  3. yobuddy
    49,198Coins
    To have the washout return the zero faster, move the slider up in the washout filer for that DOF.
  4. Jan Kroupa
    Czech Republic
    176Coins
    4DOF, 6DOF
    I know that, but its still very slow.
    I will try to use extra data from dirt, mention above
  5. Jan Kroupa
    Czech Republic
    176Coins
    4DOF, 6DOF
    Traction loss on dirt works perfectly . Now I am trying to get working my endless rotation with flying Sims
    When I apply washout to yaw and flying helicopter they is rotating on place, is not working correctly
  6. yobuddy
    49,198Coins
    what flying game buddy?
  7. eaorobbie
    20,431Coins
    His been testing in Dirt3 and Xplane , from info in 1st post
  8. mrz
    mrz Bus driving simulator
    researcher
    Dubai
    281Coins
    do you access washout algorithm to check the code?
