Yoda scanning without wheel forcefeedback connected ?
Discussion in 'Yoda - ForceFeedback Scanner' started by nonogeo, Jan 8, 2009.
  1. nonogeo
    nonogeo New Member
    For testing Yoda with a game, obligatory wheel forcefeedback is connected and soft installed ?
  2. egoexpress
    Which games do you intend to test with Yoda?
  3. nonogeo
    nonogeo New Member
    I test with GTR2 Demo.
  4. egoexpress
  5. nonogeo
    nonogeo New Member
    Hi
    Now it's Ok, the problem -> 2. Search the file for following entry: Write Shared Memory=0
    3. Replace 0 with 1
    Thank you for your help.
  6. egoexpress
    Make a windows filesearch for: .plr
    You should find a file then, which is named like your player name that you have assigned in GTR2 -> playername.plr
    Open it with MS Editor and click edit>search. Enter shared in the search window, and you will be linked to a line in the plr file, where you can set the shared memory value to 1. Acutally that will enable the function, which has been disabled before.
    Though I am not sure if the demo version offers this feature as well.
    Regards
  7. nonogeo
    nonogeo New Member
    All is ok
    -> Yoda scanning OK
    -> Pluging GTR2 OK
    :highfive:
