Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. noorbeast
    149,361Coins
    +10,941 / 54 / -2
    If you use the Oculus Rift for Dirt Rally then you may find this graphics setting tip useful to reduce judder:
  2. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
  3. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Try Codemasters Proxy Server
    You can add multiple ports where you want the Data.
    Add 20777 port and also 4123 so both would receive output data.
    http://www.eksimracing.com/cmps/
  4. frenchfly
    frenchfly Member
    Mold Maker
    Winnipeg, Canada
    - 334Coins
    2DOF, JRK
    Dirt Rally now supports more than one udp entry in hardware settings so you no longer need the proxy server. example
    <motion enabled="true" extradata="1" delay="1" port="10001" ip="127.0.0.1"/> <motion enabled="true" extradata="1" delay="1" port="4123" ip="127.0.0.1"/>
    • Informative Informative x 3
  5. gorzasty
    Poland, Wrocław
    1,060Coins
    Thx!
    I added next udp string: <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1" /><udp enabled="true" extradata="3" ip="127.0.0.1" port="20777" delay="1" />
    and everything works together.
  6. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    Its marked as private?
    149,361Coins
    +10,941 / 54 / -2
    It is not my video so nothing can be done about that, the owner must have changed the setting for some reason.
  8. uru
    uru New Member
    81Coins
    2DOF, SCN5
    I was trying to understand how to install the Codemaster Proxy Server and fortunately I found the infos here written. Now my Dash and the motion are working together. Thanks a lot.
  9. gorzasty
    Poland, Wrocław
    1,060Coins
    Does anyone have trouble with the plugin and version 1.0 of DR? I tried to unpatch and patch again but still no works ;/
  10. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Might want to tag @value1
  11. gorzasty
    Poland, Wrocław
    1,060Coins
    Thx, that is it!
  12. Wanegain
    Wanegain Active Member
    Bruxelles
    1,987Coins
    You need to edit the file hardwaresettings in Documents/My Games/DiRT Rally and set udp="true" under motion="enabled" (or something like that, I don't have the file on my laptop)
    With the new version it's disabled by default :thumbs
  13. welen123
    welen123 Member Gold Contributor
    HongKong
    35Coins
    add a new text string in the hardware_setting_config.
    <motion_platform>
    <udp enabled="true" extradata="0" ip="127.0.0.1" port="20777" delay="1" />
    <fanatec enabled="true" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>
    dont try to change the port "20777"string !!!it will sent a wrong data to the tuning center, add a new string and it will works!
  14. Wanegain
    Bruxelles
    1,987Coins
    I am using Codemasters Proxy server and I kept the original port.
    I saw the fanatec option too but I did not test without CPS, does it work for Simtools and Fanaled ?
  15. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Thank you welen123 and wanegain :cheersnow the plugin works
  16. uru
    uru New Member
    81Coins
    2DOF, SCN5
    I'm using to command my Frex SCM a Lince software. Yesterday, after updated Dirt Rally to 1.0 version I tested the seat movement and the feeling is very bad. Sometimes it remains stopped. It seems that doesn't move correctly. What about with xSim? Are you satisfied?
    I'm planning to test soon or later xSim software but I don't want to move to a similar solution.
    Thank you.
  17. Nick Moxley
    17,056Coins
    DR is a little "spikey" from my experience but more than do able on Simtools.
    FYI the software here is NOT called Xsim, Rather Simtools.
  18. uru
    uru New Member
    81Coins
    2DOF, SCN5
    Ok, Simtools. ;)
    But do you have all the movements?
  19. Nick Moxley
    17,056Coins
    All the movements meaning what exactly ?
  20. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    I noticed that with v1.0 that I had to do a re tuning to get better sensations. Shakes like a motha now!
