Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. value1
    14,934Coins
  2. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Great !
    You are the best value1 !
  3. dJuL
    dJuL yes !
    None
    9,424Coins
    3DOF, SCN6
    Works fine also with extradata=1
    (simDash doesn't work with extradata=3)
    API 3 for simtools and API 1 for simdash in server
    :D
  4. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    I am getting that same problem with the Heave, Surge and sway sitting at zero then spitting out a number then going back to zero. The motion is very jittery and doesn't react like other games do,
    If I turn the values down then I just get random jerks of motion.
    I recorded a video to show the problem. In the video I first do a sustained turn which should give me a pretty sustained Sway value, Then I do some zig-zags and you should see the sway sway form side to side, it just sort of jitters around instead of going with the motion.
    If you watch closely you can see it keeps going back to zero, then back to a value then back to zero.
  5. value1
    14,934Coins
    Hi @Avenga76
    Is this with the new version of the plugin only (extradata=3) or with the old version (extradata=0) or with both?
  6. Avenga76
    Network Engineer
    3,261Coins
    That was with the new Extradata=3 plugin.
    I haven't tried the old version yet because it isn't compatable with my Accuforce/Sim Commander. I will try it with the old version and report back.
  7. value1
    14,934Coins
    @Avenga76: ok, thanks.
    I just tested the output here and it's smooth as silk.
  8. Avenga76
    Network Engineer
    3,261Coins
    I tested it with the old plugin and that same problem, It might even be worse because the values seem a lot lower.
  9. value1
    14,934Coins
    @Avenga76: Agree, that's most annoying. I don't have this on my computer though.
    This is a Wild.jpg guess: Probably you can try fiddling with the delay value in the hardware_settings_config.xml file:
    <motion enabled="True" ip="127.0.0.1" port="4123" delay="1" extradata="3" />
  10. Avenga76
    Network Engineer
    3,261Coins
    I will give that a try tomorrow and see if it helps.
  11. SilentChill
    20,581Coins
    Thats the exact same problem I am having and it is the same in both old and new. I will try the new settings later too thanks @value1
  12. Atlas974
    Atlas974 old school
    Physics chemestry
    Reunion island
    358Coins
    Thank you for your work!
  13. Avenga76
    Network Engineer
    3,261Coins
    I did some more testing tonight.
    It was already set on delay=1 but I tried it with delay=0, delay=1 and delay=2 on both the old and new plugin. All my tests had the same erratic motion. no improvement at all.
  14. Avenga76
    Network Engineer
    3,261Coins
    It does look like it is the game data that is jittery.
    It is doing the same thing in Sim Commander
    This is a graph of the Surge (longitudinal G forces). It should be quite smooth as I accelerate and brake but you can see it keeps dropping back to zero.
  15. Atlas974
    Atlas974 old school
    Physics chemestry
    Reunion island
    358Coins
    The problem might be with the game as Dirt Rally is still in the early dev stage. Perhaps make notice of this problem on the official forums or wait for the next patch (this week if we re lucky!)
  16. value1
    14,934Coins
    Hi @Avenga76
    How have you captured the screen?
    And how did you capture the data in the graph? (SimCommander?)
    As mentioned I don't have the flickering "0"s on my installation. I guess it's a timing issue. Therefore the tests with the delay.
    I can only do some tests with the raw data flowing from Dirt at the weekend.
  17. Avenga76
    Network Engineer
    3,261Coins
    I just used OBS to capture my screen.
    The graph data is from Sim Commander, it lets you map pretty much any data to a graph, gauge or text (Game telemetry, motion telemetry, Accuforce telemetry and more. It has really good logging and analysis tools). In that case it was the Surge because it was easy to demonstrate while braking and accelerating.
    I do think it is a weird timing issue or something like that. Other people over at the SimXperience forums are experiencing the same issue and others are fine.
    I don't think it is plugin related because it is doing it with both the old and new plugin plus SimCommander.
    One of the other members on the SimXperience forums also tested Dirt Rally with Dashmeter Pro and they saw the same G force problems in the G force meter.
    • Informative Informative x 3
  18. Avenga76
    Network Engineer
    3,261Coins
    I did some more testing and the jitter only happens while you are running in windowed mode.
    In full screen it worked fine.
    Although I did need to reverse the Sway, it was pulling the seat in to the corner instead of pushing away from the corners
  19. Daguru
    Kitchen installer
    Wales uk
    454Coins
    Motion platform
    Thank you @value1 for the update and thank you @prodigy for the Cmps link
    Just got my Gi Max working with motion well happy
  20. jamiebird76
    jamiebird76 New Member
    36Coins
    2DOF, SCN5
