prilad
IL-2 Sturmovik: Cliffs of Dover Plugin 2.0.0.1
SimTools game plugin for IL -2 Shturmovik "Cliffs of Dover"
  1. Historiker
    Michigan USA
    9,207Coins
    Hi Hugso, I am sure Ale can answer this better but I will share with you what I found in the Team Fusion forums.
    The developers of IL-2 wanted to keep people from cheating in multiplayer so they locked the code to allow telemetry only in single player. Since the mission builder can be used for both single player and multiplayer missions I assume that it outputs to a multiplayer file type regardless of what you are trying to use it for?
    The issue is not with Simtools, but rather IL-2 itself.
    Hope this helps.
  2. prilad
    Dubna, Russia
    9,649Coins
    3DOF, DC motor, Arduino, 4DOF
    Hi, @hugso. I think you can answer by yourself. ;) All missions in CloD must have special patch "script" file with the same name and .cs extention ( for example for "Free Hunt.mis" you can found script file "Free Hunt.cs" )
    For all "standard" missions script files are generated when games was patched. But if you create your own mission by Mission Builder, you should to "create" script file for this mission. Good news that all script files are equal. So you should copy any *.cs file and rename it ( remember - script must be named as mission file ).
    Try this and let me know about results.
    By the way - you can found missions and scripts files in next folder:
    C:\Users\...\Documents\1C SoftClub\il-2 sturmovik cliffs of dover\missions
  3. hugso
    hugso Active Member
    Glos UK
    611Coins
    Arduino, Motion platform, 4DOF
    Wow, thanks for that Prilad. I will try that later today. It will be beyond brilliant for me if this works. As I said before, SimTools is a dream come true for me. Thanks again.
  4. hugso
    hugso Active Member
    Glos UK
    611Coins
    Hi Prilad, thanks a million - it works great! I am so pleased. I can now fly my favourite flight sim exactly as I want. Great! You really are a star. I wish I could reward you in some way.
  5. prilad
    Dubna, Russia
    9,649Coins
    Have a nice flight, @hugso :)
    I hope when I will build my sim, I'll join you.. :cheers
  6. yobuddy
    50,128Coins
    I vote @prilad for president! :thumbs
  7. hugso
    hugso Active Member
    Glos UK
    611Coins
    That would be great! See you in the skies over the White Cliffs... Since Team Fusion modded CloD it really is a great sim. Thanks so much for your help.
  8. hugso
    hugso Active Member
    Glos UK
    611Coins
    Gets my vote!
  9. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,939Coins
    President of the Simtools plugins for all games :thumbs
  10. hugso
    hugso Active Member
    Glos UK
    611Coins
    Really enjoying flying this sim with my 4 dof. Absolutely loving it. Thank you again for all your help getting things working. Is there any chance of one day including surge motion? This would involve me doing a fair bit of rebuilding of my sim, but it would be really cool to feel acceleration and deceleration especially when taking off and landing.
  11. prilad
    Dubna, Russia
    9,649Coins
    Hi, @hugso . I'll try to do something with surge when I'll have some free time :cheers
  12. hugso
    hugso Active Member
    Glos UK
    611Coins
    That would be great Prilad, thanks.
  13. Celk
    Celk New Member
    192Coins
    Hi Prilad,
    I used your CoD plugin 3.0.0.9 and patched the steam game from the installation directory. (../steamapps/common/il-2 sturmovik cliffs of dover). After patching I do not see a window that saying patching OK. However patch button goes to Remove patch state. Now I getting the roll and picth values when I start the game from steam. However these values do not change when the plane moves in training , quick or single missions. Always roll and pitch default values coming. I do not see any devicelink.txt files in under the steam CoD installation directory. I think game manager and steam game devicelink or consol can not connect to each other. What can I do?
  14. prilad
    Dubna, Russia
    9,649Coins
    Hi, @Celk. Can you find manually where is file "Free Hunt.mis" and other mission files (*.mis) on your computer? Give me a full path to Single missions, Quick Edit missions, and Training missions.
    I think plugin can't find this paths for "Steam" version.
    And you should to know, that CoD has not "devicelink" interface.
  15. hugso
    hugso Active Member
    Glos UK
    611Coins
    Hi Prilad and Celk
    The trick about .cs files is the answer to getting all single missions to work. Before, I could only use Training and Free Hunt, but now I can set up any Single Mission I make in Full Mission Builder and SimTools works perfectly. By the way, I have just added surge motion which gives rather nice acceleration and braking effects when taxiing. Thanks for your hard work Prilad.
  16. prilad
    Dubna, Russia
    9,649Coins
    Yes, @hugso. There is the method to "patch" game "manually"...:grin
  17. berty
    berty Member
    164Coins
    I have the same problem as a @Colk. I patch the game in the folder to the installed (no steam) as this can be solved? :)
  18. noorbeast
    150,285Coins
    +11,001 / 55 / -2
  19. Harry King
    Harry King Member
    224Coins
    3DOF, Arduino
    OK trying to install what folder is this going into the original C:\Program Files (x86)\Steam\steamapps\common\il-2 sturmovik cliffs of dover or should I choose a different directory?
  20. noorbeast
    150,285Coins
    +11,001 / 55 / -2
    That is the correct Steam path used for patching COD.
