value1
Joystick plugin 2.0.0.1
SimTools plugin to read the joystick values
  1. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    What settings do you use? I have similar setup and can't get joystick plugin to work - everything reads okay in tuning center, but both testing and actual joystick input produce few jerky movements, then no response whatsoever. Worked marvelously with Elite plugin until recent update.
  2. Atlas974
    Atlas974 old school
    Physics chemestry
    Reunion island
    358Coins
    Well.
    Follow these instructions.
    Then you need to link the tuning center value with you joystick mouvements. For exemple on mine when i roll with my stick, in tuning center i saw extra 3 values moving: so i know that the roll on my stick is link to extra 3 and i configure that into my axis management so that extra 3 value make the motors move. Same thing for the pitch, some changes ot inverse the movements if needed and you're good to go.
  3. Daguru
    Kitchen installer
    Wales uk
    454Coins
    Motion platform
    Once I got the numbers moving in tuning centre I just used capture max min etc and tuned like a normal game works great on Apache air assault you can even use button press on the extra values
  4. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    Well, I finally made it work, stick for pitch and roll. Very nice, works for Eve Valkyrie as well. Is there a way to enable one more device, pedals for example?
  5. robatik
    robatik New Member
    iran
    164Coins
    Feedback Joystick Is There?
  6. auryza
    auryza Active Member
    Lithuania
    4,333Coins
    2DOF, 3DOF, Arduino
    Use this one , "Xbox 360 Controller Emulator", you can make any controller act like a xbox360 controller, or even more different kind of controllers. All necessary information and downloads you can find here. https://github.com/x360ce/x360ce
    150,279Coins
    +11,001 / 55 / -2
  8. AlexinChina
    AlexinChina Member
    China
    371Coins
    fantastic work, i want to paly this right now;)
  9. hideki
    hideki Active Member
    Spain
    - 208Coins
    2DOF, SCN5
    Hello Everyone. This is a nice and usefull pluging for those games that dont have any. My problem is that when using acceleration the motors dont go back to center point so I am in a constant wheelie until I brake. Any way so solve that? Any old post to look for that if there is any? Many thanks!!
  10. Rudolf Jan Horak
    Rudolf Jan Horak Member
    Simulator Maintenance Student
    Devils Lake, ND
    274Coins
    Motion platform
    It looks like if you have a game that is not yet supported by the Sim Tools, this is a good program to use. Would that be right? On our project I am working on what I hope will be a pod racer which I don't think will ever be supported so is this my only choice? From what I read above, it looks like this software moves the platform in the direction that you move the stick?
  11. hideki
    Spain
    - 208Coins
    2DOF, SCN5
    Yes. I wanted to play motogp 15. For cornering its not that bad, but for acceleration and braking on the other hand...
  12. Rudolf Jan Horak
    Devils Lake, ND
    274Coins
    Motion platform
    @noorbeast Did you get this playback motion question answered or figured out? I have a friend of mine on here that is working on a motion sim and would like to be able to put in the motions and be able to play them back in a similar way that those simulators at the mall that have no controls where you just ride the ride and as the video plays, the motion responds.
  13. value1
    14,914Coins
    There's an app of @yobuddy – AFAIK pretty much in alpha stadium still though.
  14. noorbeast
    150,279Coins
    +11,001 / 55 / -2
    Yes I did, it is planned functionality for SimTools 2.0, and as @yobuddy points out is just in the early development phase so is a little way off at the moment.
  15. George Dobransky
    Hungary
    - 33Coins
    Hi There,
    Is anyone else using Thrustmaster T-Flight Hotas?
    The plugin not recognise pitch, thrust, etc...
    Only X and RZ axis.
    Any ideas?
    George
  16. value1
    14,914Coins
    Sorry, I just have a wacky old Xbox 360 Wireless Controller :(
  17. noorbeast
    150,279Coins
    +11,001 / 55 / -2
    @value1 created the plugin so may be able to advise as to what is supported.
  18. steveh2112
    steveh2112 Member
    semi retired
    Phuket, Thailand
    1,147Coins
    i followed all the step, installed the plugin, in game manager i select joystick (not joypad like the doc says?). on patching, i select C:\Program Files (x86)\SimTools, but i don't see SimTools_Joystick.exe in the simtools folder?
    anyhow, its in the .zip so i just dragged it out and put on the desktop and when i run SimTools_Joystick.exe i get that menu show above. but my sim takes an immediate note dive, full pitch down.
    i tried all the buttons on that menu thing but non seem to move the sim with my xbox controller.
    i verified the xbox controller is working ok by running joy.cpl and looking at properties, the controller is fine
    any ideas pls?
    game engine is running
    i'm using the default profile BTW, do i need to make a profile for the joystick?
    i opened the tuning center and input data read -32767 (0xffff) regardless of which joystick i select
    thx
  19. noorbeast
    150,279Coins
    +11,001 / 55 / -2
    Try unpatching @steveh2112, exit GameManger in the system tray, the restart Game Manager as Admin and then repatch.
  20. steveh2112
    steveh2112 Member
    semi retired
    Phuket, Thailand
    1,147Coins
    i thought the same thing, i just did that and now i have SimTools_Joystick.exe and SimTools_Joystick_Recorder.exe in simtools folder, so i run SimTools_Joystick.exe from simtoolf folder and same problem, tuning center shows input -32767
    oh well, its only a test tool, i guess i'll try running DCS since that's the whole point of the thing anyhow
