Revolution firmware and software for AMC1.5+1.6
Discussion in 'SimTools compatible interfaces' started by CraCk, Jun 15, 2012.
  1. prilad
    Dubna, Russia
    9,652Coins
    3DOF, DC motor, Arduino, 4DOF
    Re: Revolution firmware and software for AMC1.5
    Can you describe the situation in more detail? And try to put the AMC into terminal mode by turning dip-switch number 1. Did you receive a message to computer from AMC in this mode?
    I think I could make a mistake when adapting the project for the atmega644, when made UART initialization . If you are not able to receive the data into terminal, so it is.
    I think - this is a small mistake. :D You have been connected to another PWM channel and received noised signal (from UNCONNECTED potentiometer). Connect, please, oscilloscope to second PWM channel.
  2. tronicgr
    tronicgr
    I tried terminal mode, nothing either... I don't see activity on the RX led on the USB breakout meaning the atmega644 doen't even try to send anything. I had the hardware tested with my firmware so I can assure you there is nothing wrong with the board, it connects correctly to x-sim and terminal.
    Also the problem with potentiometers exists even with two of them connected. I never have such problem with my firmware, one unconnected channel doesn't affect the other especially if its connected!!! Maybe you need to set the ADC to Single shot conversion instead of Free running, I don't know how this could called in the programming language you used.
    Also, why you swapped the PWM channels? I had them like that forever... :lol:
    Regards,
    Thanos
  3. prilad
    Dubna, Russia
    9,652Coins
    Ok. I will try to test my firmware in Proteus simulator
  4. prilad
    Dubna, Russia
    9,652Coins
    But with mega8535 it works good.
  5. tronicgr
    tronicgr
    I managed to connect it to software, it was some settings on the FTDI com port I had set for other project.
    But the problem with ADC potentiometers still exist and I took a video of the capture of it on your program so you can see it graphically! Something is not on in the code for the potentiometers or you have mixed the channels or something.
    Thanos
  6. prilad
    Dubna, Russia
    9,652Coins
    OK. I hope it reduced disappointing level :D
    I think, I have fixed this problem in this firmware
    AMC16_mega644_22mHz_byALE_fix.rar
  7. tronicgr
    tronicgr
    I tried the new firmware and get the same results... as on the last video I posted.
    Used different type potentiometers even SS490 ratiometric hall effect ones but I get the same faulty realings.
    To describe it better, its like every half second the first potentiometer's value is set to the value of the second potentiometer, like its following the second potentiometer's value. I think you are doing the measurement twice and for the second time you mix up the ADC channel names or something.
  8. prilad
    Dubna, Russia
    9,652Coins
    Unfortunately I am unable to check the firmware on the device. But software emulation shows that there is no problem. The problem was that the ADC input multiplexer does not have time to switch from one channel to another. Now I added a delay in the ADC measurement cycle.
    Here's another firmware version, in which I increased the delay in the hope that the problem will disappear.
    AMC16_mega644_22mHz_byALE_fix2.rar
    And one more modification
    AMC16_mega644_22mHz_byALE_fix3.rar
  9. tronicgr
    tronicgr
    Yes, looks good now! Works! No more crazy potentiometers! Let me do some real tests now with motors.
    Do you mind if I put a link to it at the AMC1.6 project blog?
    *EDIT: lol, why you took down the link? Was working fine!
  10. prilad
    Dubna, Russia
    9,652Coins
    I compared the firmware for mega644 with old firmware for mega64 and found one difference in the procedure for initializing the ADC. The version of fiх3 I did initialize identical mega64.
    Check, please, the third firmware too.
    Of course I do not mind.
    I can make firmware for 18 MHz too.
  11. tronicgr
    tronicgr
    Ok Thanks!! I tried fix3 works fine too... what was that?
    Anyway another issue I just realized is that I can't change the settings KP Hi Lo etc from the interface. I fill thee values I want into fields, press the save settings button but they are not updated into the chip, still get the same numbers. Is that another bug or incompatibility between the two chips?
    Generally whatever code I write for my chips is directly transferable to another chip of the same family with the only change the chip identification...!
  12. CraCk
    CraCk Member Gold Contributor
    Made in Ukraine
    670Coins
    The procedure for writing this:
    1. Input value
    2. Press Enter
    3. Press key Save the new settings in the EEPROM of the controller
  13. tronicgr
    tronicgr
    Oh... I guess I missed that Enter thing in the directions... Hahaha...
    Works fine then I guess!!! Ready for some actual motor testing!
    Thanks!!
  14. tronicgr
    tronicgr
    Here is a test with my motor... Works great I would say!
    http://www.youtube.com/watch?v=ImRfTZ5qI8A
    I love the graphing function... Can you make it to start over again automatically?
    Thanos
  15. prilad
    Dubna, Russia
    9,652Coins
    how could it be otherwise? :D
    You mean the automatic restart recording data in the buffer after the end of the record?
    Like in oscilloscope?
  16. tronicgr
    tronicgr
    Yes....!!! No need to click it over and over again when you have to adjust other values... Just an Auto mode button would be great!
  17. tronicgr
    tronicgr
    Wait to see the next video... I finally have proof about the refresh period rate importance...
  18. prilad
    Dubna, Russia
    9,652Coins
  19. value1
    14,993Coins
    :D
  20. tronicgr
    tronicgr
    Here it is ....
    The video speaks of it self... You want quality in motion? Change that 33ms delay to 3ms or 1ms if possible!!! :lol:
