v0.09 is here
It supports GameVibe and GameDash albeit on a generic level.
Install like usual via Plugin Updater and then patch DCS. After patching you can go to SavedGames/DCS/Scripts/Hooks and open the Simtools_DCS_Exp_Hook..... .lua file.
In this file you can choose between metric or imperial units. With just a little bit of Lua you can assign any values you like to the export slots.
If you absolutely insist on using Euler angles, you can set the bool "YouAbsolutelyInsistOnUsingEulerAnglesEvenThoughThatMakesNoFuckinSense" to true and thou shalt get Euler angles. However, thou shalt not ask me for a fix to the inherent problems with roll and loop and heading changes!The fix is to NOT use Euler angles
Enjoy![]()
