Genre: Space Simulator
This plugin provides pitch, roll, yaw,speed, surge, sway and heave acceleration (SPACESHIP)
This plugin provides pitch, roll and accelerations for yaw, surge, sway and heave. also Extra 1 Roll and Extra 2 Pitch (SRV)
Features:
-External configuration file (XML) for updating the pointer and other settings.
-GameVibe (Turbulence, Road Detail, Collision L/R & F/B)
The plugin is configurable via an XML file (within the plugin folder) allowing you to:
-Manually change the pointer without recompiling the plugin
-Option to change the SRV DOF to reverse
-Changing the % of force
-Option to change the SRV Roll & Pitch from the Extra1-2 to the normal Roll / Pitch.
This plugin works with the current version of Elite Dangerous: Horizons Fleet Carriers Patch 4
Special instructions:
-If you are updating from a previous working version of this plugin, there is no need to patch again, just use the SimTools plugin updater.
-After patching, have a look at the XML to configure the forces to your desired values.
-If GameManager crash on game launch, it probably mean you have an outdated wow64ext.dll (9kb) in the plugin directory.
I advise you replace it with the one located on your simtools installation directory, it should be around 700kb in size.
Author: Wagnard
Based on the work of : value1, SilentChill
Elite Dangerous Horizons/Odyssey Plugin (XML edition) Ascendancy update
- Ascendancy pointers update Oct 31, 2024
- Odyssey 18.09 pointers Sep 19, 2024
- Odyssey 18.08 pointer update Aug 7, 2024
