value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. Some Vibe errors fixed
    value1
    RaceRay, Lol4 and Zed like this.
  2. Update for GameVibe
    value1
    Update for GameVibe
    This update also addresses an issue reported by @SilentChill here.
    The plugin now only delivers data while in Ride View mode! In all other modes the plugin sends no data.
    There are issues with pitch and roll during a looping or a corkscrew. Unfortunately there is not a lot I can do ATM. (It is a...
    John Memeo and Zed like this.
  3. Update for SimTools V2
    value1
    deniz222 likes this.
  4. Improved error trapping
    value1
    I was a little lazy with the error trapping with the previous version.
    This one is somewhat better and should work troublefree even when you start SimTools before the simulation.
    Let me know, please.
  5. Update for NoLimits V2.2
    value1
    This plugin makes use of the new API provided by NoLimits.
    A big "Thank you" to Ole Lange for taking the time and effort to implement a genuine API!
    This version of the plugin works with NLS V2.2 and higher! If you run an earlier version of the simulation, use plugin version 2.1.5.0!
    In order to activate the telemetry in the simulation, you must start NLS with the option --telemetry.
    Non-Steam version:
    Create a shortcut to nolimits2app.exe – right click...
    ManuCM796 likes this.
  6. Update to include version NLS 2.1.5.0
    value1
    (full versions stand-alone and steam, 32 bit and 64 bit)
  7. Resolves timing issues when starting the simulation while SimTools already running
    value1
    Resolves timing issues when starting the simulation while SimTools already running (see post here)
    Thanks to @noorbeast for pointing this issue out! :thumbs
  8. Update to include version NLS 2.1.0.0
    value1
    Includes motion support for the previous versions and all versions of V2.1.0.0
  9. Update to include V2.0.9.0
    value1
    Supports all the old versions + V2.0.9.0 (Demo 32 & 64 bit, Full 32 & 64 bit, Steam 64 bit)
  10. Support of Steam version (x64)
    value1
    This version supports the Steam version of NLS V2.0.8.1 (x64 only) and of course all the non-steam versions as well.
    Thanks to @SilentChill for his help!
