My project (guide me)
Discussion in 'DIY Motion Simulator Projects' started by CalSim, Aug 2, 2014.
Best set to "heave" a total of 300kg??
  1. Stepper motor ie. NEMA 23-34 (x6)
    5 vote(s)
    33.3%
  2. Huge homemade actuator (x4, x6??)
    9 vote(s)
    60.0%
  3. Worm DC motor > 50W ( x6)
    3 vote(s)
    20.0%
Multiple votes are allowed.
  1. Tino
    Tino Member
    1,289Coins
  2. CalSim
    CalSim building things
    bacteriology analist
    Spain
    1,310Coins
    DC motor, Arduino, JRK
    @Tino , there is a con for that motor: read carefully:
    • Holding torque : Low Holding torque, we've found these are quite easy to back drive, so if you need a worm drive with holding power this is not suitable.
    An0other con for me is that they sell from Australia which is the antipodes for spain and south europe, where I am. And import taxes for countries outside the UE are high here.
    Thata a powerfull motor, but its 16Amps at 12volts, we can have a better one, at least 30A can be easy handled. Think about the other i found, its 2500rpm, 16Amps at 24v (which is double). Now we add an external worm gear and set the final speed to 100 rpm. (25:1). The motor itself has an output of 12.5Newtons. imagine what after the worm gear.
    About the 3:1 relation gear. I'll build my actuators with heavy duty - non maintenance- threaded belts, because of noise.
    Anyway, im not expert with this, i'm going to try this configuration but I still need an easy way to control it. ( I dont know what kind of H-bridge i have to buy), please suggest me some.
  3. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,778Coins
    Hi
    Those wormgear motors are sold in europe, by motion control products @ there ebay store. (€80.00)
    if you need a holding wormgearbox you need a bigger I,they become fully locking between I 50/I 60
    regards AD
  4. Tino
    Tino Member
    1,289Coins
    Hi Miguel,
    Your motor which does 16Amps at 24v sounds more powerful, but it seems to have lower torque - 12.5N vs 20N from motiondynamics.
    I am not too worried about motor efficiency as I will be using cheap and powerful (147A on 12v) server PSU:
    http://www.ebay.co.uk/itm/IBM-Blade...=US_Disk_Array_Components&hash=item5afdd59381
    or, if you need 24V you can use two 12V server PSU:
    http://www.tjinguytech.com/my-projects/diy-24v-47a
    Perhaps someone with more experience can correct me, but 3 to 1 sprocket system would bump the torque to 60N and I think that it would be unlikely that these motors would backdrive then.
    Also, additional gears and building the actuators would make this build really complicated (at least for me).
    Personally I'd rather buy SCN5 than try to build my own actuators.
    Unfortunately I haven't delved deep enough into simulator design to recommend H-bridge or other electronics.
    merchan-e recommended these H-bridges in this post: http://www.ebay.es/itm/BTS7960-43A-...181?pt=LH_DefaultDomain_0&hash=item2c7b59af55
    http://www.xsimulator.net/community/threads/6dof-motion-platform-‘lite’.5481/page-2#post-55836
    For my 1st simulator I will most likely be using Thanos 6dof electronics.
    Thanks, Tino.
  5. CalSim
    Spain
    1,310Coins
    I've been some days out, i bought some tools and next week i'll start building the actuator itself, I have drawn my own design, without strings and with my own knowledge. If the first actuator works, it'll be easy to go on with others.
    I'll post photos soon.
  6. Tino
    Tino Member
    1,289Coins
    Hi adgun,
    Do you know if these motors are available in europe?
    http://www.motiondynamics.com.au/worm-drive-motor-12v-24v-200w-180-rpm-20nm-torque.html
    On motion control products ebay store I could only find 15Nm 65rpm motor (not enough umph)
    http://www.ebay.co.uk/itm/12V-DC-Ge...al_Components_Supplies_ET&hash=item19f0dd7b66
    billo2404 mentioned these motors from Canada
    http://www.ebay.it/itm/GEAR-MOTOR-1...483?pt=LH_DefaultDomain_0&hash=item51bed470a3
    Apparently this motor has 50-60Nm "load"
    Is that 50-60 Nm torque?
    Has anyone tried these motors?
    They also sell 160RPM version with 30-40Nm "load"
    http://www.ebay.it/itm/GEAR-MOTOR-1...384?pt=LH_DefaultDomain_0&hash=item51bd392f00
    Presuming that load means torque, doesn't that seem a little too good to be true?
    Regards,
    Tino.
  7. adgun
    adgun Active Member
    mechanic
    Netherlands
    5,778Coins
    Hi Tino
    Look for there 12v motor compactible with mcp4 gearbox and mcp4 gearbox 25;1
    And yes,the motor seams to good to be true
  8. CalSim
    Spain
    1,310Coins
    Hey Tino motiondinamics motor has 20N outside the gearbox, right?
    The 300w motor i showed is 12.5 N without gearbox. What about an universal 25:1 worm gearbox to have about 100rpm?
  9. Tino
    Tino Member
    1,289Coins
    Hi Miguel,
    12.5Nm @ 2500 RPM sounds a bit optimistic for 300W motor, but I could be wrong.
    Since the motor is quite cheap (~€56.4) I suggest you purchase one and let us know if it works as advertised.
    I'm a bit worried that gearbox might cost much more than this motor...
    I thought you were building actuators?
  10. CalSim
    Spain
    1,310Coins
    Yes i'm building actuators with my own design. have a mindbraker with the motor im going to buy
    I'll spend about 150€ max on motor/wormgear. a 100€ universal wormgear would be great to use with this motor.
    That motor is used to power electric skates.
  11. CalSim
    Spain
    1,310Coins
    Well since i've been out these days, i want to update this with a new thread, where i'll update the build of my actuator.
    http://www.xsimulator.net/community/threads/dc-actuator-design.5762/
    Right now i've been building my workstation and buying some tools, to cut shafts, etc, etc.
    This is my garage actually without trash :p
    So I will left this to the "big rig" with 6 actuators and follow what i'm working on now
  12. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    3DOF, Arduino, SimforceGT, Motion platform
    how about around 100kg? can use the same coding? the coding that i used like that..
    Code:
    #include <SoftwareSerial.h>
    const int RedLedPin =  2;
    const int YelLedPin =  3;
    const int GreenLedPin =  4;
    const int Actuator1_Fwd_Pin=6;
    const int Actuator1_Rvs_Pin=5;
    const int Actuator2_Fwd_Pin=8;
    const int Actuator2_Rvs_Pin=7;
    const int Actuator3_Fwd_Pin=10;
    const int Actuator3_Rvs_Pin=9;
    const int Limit_Switch1_Pin=11;
    const int Rx_Pin=12;
    const int Tx_Pin=13;
    int Red_LED_State = LOW;
    int Yel_LED_State = LOW;
    int Green_LED_State = LOW;
    unsigned long Red_LED_previousMillis = 0;
    unsigned long Yel_LED_previousMillis = 0;
    unsigned long Green_LED_previousMillis = 0;
    unsigned long Actuator1Fwd_previousMillis=0;
    unsigned long Actuator1Rvs_previousMillis=0;
    unsigned long Actuator2Fwd_previousMillis=0;
    unsigned long Actuator2Rvs_previousMillis=0;
    unsigned long Actuator3Fwd_previousMillis=0;
    unsigned long Actuator3Rvs_previousMillis=0;
    char numStr[16];      // the number characters and null
    String X_axis[]="";
    long data_X;          // the number stored as a long integer
    long data_Y;          // the number stored as a long integer
    long data_Z;          // the number stored as a long integer
    int position_X;
    int position_Y;
    int position_Z;
    char data_serial[3];
    char X_axis_data[3];
    SoftwareSerial mySerial(12, 13); // RX, TX
    void setup()
    pinMode(RedLedPin, OUTPUT);
    pinMode(YelLedPin, OUTPUT);
    pinMode(GreenLedPin, OUTPUT);
    pinMode(Actuator1_Fwd_Pin, OUTPUT);
    pinMode(Actuator1_Rvs_Pin, OUTPUT);
    pinMode(Actuator2_Fwd_Pin, OUTPUT);
    pinMode(Actuator2_Rvs_Pin, OUTPUT);
    pinMode(Actuator3_Fwd_Pin, OUTPUT);
    pinMode(Actuator3_Rvs_Pin, OUTPUT);
    pinMode(Limit_Switch1_Pin, INPUT);
    Serial.begin(9600);
    mySerial.begin(9600);
    void Red_LED_Blink(const long interval_Red)
      unsigned long Red_LED_currentMillis = millis();
      if(Red_LED_currentMillis - Red_LED_previousMillis >= interval_Red) {
        // save the last time you blinked the LED
        Red_LED_previousMillis = Red_LED_currentMillis;
        // if the LED is off turn it on and vice-versa:
        if (Red_LED_State == LOW)
          Red_LED_State = HIGH;
        else
        // set the LED with the ledState of the variable:
        digitalWrite(RedLedPin, Red_LED_State);
    void Yel_LED_Blink(const long interval_Yel)
      unsigned long Yel_LED_currentMillis = millis();
      if(Yel_LED_currentMillis - Yel_LED_previousMillis >= interval_Yel) {
        Yel_LED_previousMillis = Yel_LED_currentMillis;
        if (Yel_LED_State == LOW)
          Yel_LED_State = HIGH;
        else
        digitalWrite(YelLedPin, Yel_LED_State);
    void Green_LED_Blink(const long interval_Green)
      unsigned long Green_LED_currentMillis = millis();
      if(Green_LED_currentMillis - Green_LED_previousMillis >= interval_Green) {
        Green_LED_previousMillis = Green_LED_currentMillis;
        if (Green_LED_State == LOW)
          Green_LED_State = HIGH;
        else
        digitalWrite(GreenLedPin, Green_LED_State);
    void move_actuator1_fwd(const long interval_actuator1)
      unsigned long Actuator1Fwd_currentMillis = millis();
      digitalWrite(Actuator1_Fwd_Pin,HIGH);
      digitalWrite(Actuator1_Rvs_Pin,LOW);
      if(Actuator1Fwd_currentMillis - Actuator1Fwd_previousMillis >= interval_actuator1) {
    Actuator1Fwd_previousMillis = Actuator1Fwd_currentMillis;
        digitalWrite(Actuator1_Fwd_Pin,LOW);
    delay(50);
    void move_actuator1_rvs(const long interval_actuator1)
      unsigned long Actuator1Rvs_currentMillis = millis();
      digitalWrite(Actuator1_Rvs_Pin,HIGH);
    if(Actuator1Rvs_currentMillis - Actuator1Rvs_previousMillis >= interval_actuator1) {
      Actuator1Rvs_previousMillis = Actuator1Rvs_currentMillis;
    delay(50);
    void move_actuator2_fwd(const long interval_actuator2)
      unsigned long Actuator2Fwd_currentMillis = millis();
      digitalWrite(Actuator2_Fwd_Pin,HIGH);
      digitalWrite(Actuator2_Rvs_Pin,LOW);
      if(Actuator2Fwd_currentMillis - Actuator2Fwd_previousMillis >= interval_actuator2) {
    Actuator2Fwd_previousMillis = Actuator2Fwd_currentMillis;
        digitalWrite(Actuator2_Fwd_Pin,LOW);
    void move_actuator2_rvs(const long interval_actuator2)
      unsigned long Actuator2Rvs_currentMillis = millis();
      digitalWrite(Actuator2_Rvs_Pin,HIGH);
    if(Actuator2Rvs_currentMillis - Actuator2Rvs_previousMillis >= interval_actuator2) {
      Actuator2Rvs_previousMillis = Actuator2Rvs_currentMillis;
    void move_actuator3_fwd(const long interval_actuator3)
      unsigned long Actuator3Fwd_currentMillis = millis();
      digitalWrite(Actuator3_Fwd_Pin,HIGH);
      digitalWrite(Actuator3_Rvs_Pin,LOW);
      if(Actuator3Fwd_currentMillis - Actuator3Fwd_previousMillis >= interval_actuator3) {
    Actuator3Fwd_previousMillis = Actuator3Fwd_currentMillis;
        digitalWrite(Actuator3_Fwd_Pin,LOW);
    void move_actuator3_rvs(const long interval_actuator3)
      unsigned long Actuator3Rvs_currentMillis = millis();
      digitalWrite(Actuator3_Rvs_Pin,HIGH);
    if(Actuator3Rvs_currentMillis - Actuator3Rvs_previousMillis >= interval_actuator3) {
      Actuator3Rvs_previousMillis = Actuator3Rvs_currentMillis;
    void Red_LED_Off()
        digitalWrite(RedLedPin,LOW);
    void Yel_LED_Off()
        digitalWrite(YelLedPin,LOW);
    void Green_LED_Off()
        digitalWrite(GreenLedPin,LOW);
    void initialize_actuator_position()
    delay(100);
    int initialize=1;
    int fwd_status=1;
    int rvs_status=0;
    int  count_fwd=0;
    int count_rvs=0;
    int count=0;
    while(initialize)
      int rand_val=rand();
      if (rand_val>1000){rand_val=1000;}
      Yel_LED_Blink(rand_val);
      if((fwd_status==1)&&(rvs_status==0))
      count_fwd=count_fwd+1;
      count_rvs=0;
      delay(100);
      delay(100);
      if(count_fwd==40){
                          fwd_status=0;
                          rvs_status=1;
                          count=count+1;
                            delay(100);
      int   switch_status=digitalRead(Limit_Switch1_Pin);
      if(switch_status==0){initialize=0;
                           Yel_LED_Off();
                            digitalWrite(GreenLedPin,HIGH);
                            delay(100);
      if((fwd_status==0)&&(rvs_status==1))
      count_fwd=0;
      count_rvs=count_rvs+1;
      delay(100);
      delay(100);
      if(count_rvs==40){
                          fwd_status=1;
                          rvs_status=0;
                          count=count+1;
                            delay(100);
                           Yel_LED_Off();
                            delay(100);
        if(count==5){
                            digitalWrite(RedLedPin,HIGH);
                            while(1){}
    void loop()
    Red_LED_Off();
    Yel_LED_Off();
    Green_LED_Off();
    delay(100);
    initialize_actuator_position();
    unsigned previous_data_X=511;
    unsigned  previous_data_Y=511;
    unsigned previous_data_Z=511;
    signed int val_X;
    signed int val_Y;
    signed int val_Z;
    while(1)
    Green_LED_Blink(rand_val);
    int check_data=1;
    int count=0;
    while(check_data)
               if ( Serial.available () > 0 )
                  numStr[count]=Serial.read();
                  mySerial.write(numStr[count]);
                if(numStr[count]=='C')
                      check_data=0;
               count=count+1;
      //mySerial.write(numStr);
    String data= String(numStr);
    mySerial.println(data);
    String data_x=data.substring(2,5);
    int X=data_x.toInt();
    mySerial.println(X);
    String data_y=data.substring(6,9);
    int Y=data_y.toInt();
    mySerial.println(Y);
    String data_z=data.substring(10,13);
    int Z=data_z.toInt();
    mySerial.println(Z);
    if(X<previous_data_X)
      move_actuator1_rvs(1000);
      delay(250);
      previous_data_X=X;
    if(X>previous_data_X)
      move_actuator1_fwd(1000);
      delay(250);
      previous_data_X=X;
    if(Y<previous_data_Y)
      move_actuator2_rvs(1000);
      delay(250);
      previous_data_Y=Y;
    if(Y>previous_data_Y)
      move_actuator2_fwd(1000);
      delay(250);
      previous_data_Y=Y;
    if(Z<previous_data_Z)
      move_actuator3_rvs(1000);
      delay(250);
      previous_data_Z=Z;
    if(Z>previous_data_Z)
      move_actuator3_fwd(1000);
      delay(250);
      previous_data_Z=Z;
  13. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    one question from me everybody..how much cost or average cost to buy motor i mean per unit? if i must buy with other country i think it is more expensive..
  14. Casey Pareni
    Casey Pareni MasterP
    Firefighter
    Arizona
    350Coins
  15. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
  16. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    try this one..
    String X_axis[]="";
    int position_X;
    int position_Y;
    int position_Z;
    void setup()
    Serial.begin(9600);
    else
    else
    else
    delay(50);
    delay(50);
    void Red_LED_Off()
    void Yel_LED_Off()
    delay(100);
    int initialize=1;
    int fwd_status=1;
    int rvs_status=0;
    int count_fwd=0;
    int count_rvs=0;
    int count=0;
    while(initialize)
    count_rvs=0;
    delay(100);
    delay(100);
    if(count_fwd==40){
    fwd_status=0;
    rvs_status=1;
    count=count+1;
    delay(100);
    Yel_LED_Off();
    delay(100);
    count_fwd=0;
    delay(100);
    delay(100);
    if(count_rvs==40){
    fwd_status=1;
    rvs_status=0;
    count=count+1;
    delay(100);
    Yel_LED_Off();
    delay(100);
    if(count==5){
    while(1){}
    void loop()
    Red_LED_Off();
    Yel_LED_Off();
    Green_LED_Off();
    delay(100);
    signed int val_X;
    signed int val_Y;
    signed int val_Z;
    while(1)
    int check_data=1;
    int count=0;
    while(check_data)
    check_data=0;
    count=count+1;
    delay(250);
    previous_data_X=X;
    delay(250);
    previous_data_X=X;
    delay(250);
    previous_data_Y=Y;
    delay(250);
    previous_data_Y=Y;
    delay(250);
    previous_data_Z=Z;
    delay(250);
    previous_data_Z=Z;
  17. Pedro Silva
    Pedro Silva New Member
    Telecomm, Electronics
    Yoshkar-Ola, Russia
    251Coins
    Hello Robbie!
    Im a starter in this forum (just signed up last week) and i got your project to be my first shot, i found it the easies to understand. Nice job, BTW!
    I just have 2 questions about it:
    1) I made the setup exactly the way you explained, i triple checked all detailes, Axis Assignments, i used the interface config you put in your zip, and so on. I assembled Arduino outputs on my osciloscope to check PWM variation as i still dont have my motors. However, i noticed that i have inverted result, i mean, when i slide roll on Game Engine Output Test i get pitch result on osciloscope (both PWM moving together) and when i slide pitch on output test i get roll result (inverse proportional PWM on osciloscope). How is the correct way to solve it?
    and
    2) IN one of your posts you said that we need to create a default axis assignment and you said to distribute 50%/50%. However when i was sutdying the documentation they gave as an example of default assignment the distribution of 60%/60%, which by the way i found strange because they dont make 100% ... Anyway, in practice what does it really change to use 50% or 60% in this case?
    Once more congrats for your job and hope i can soon get ready my first SIM. Thanks!
  18. noorbeast
    151,467Coins
    +11,039 / 56 / -2
    Just change the pitch and roll in the Axis Assignments.
    See here re percentage allocations: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
  19. Pedro Silva
    Yoshkar-Ola, Russia
    251Coins
    Hummm... that im afraid i did already... or maybe im just mistaken? As per my understanding, if i swap the axis on axis assignment it would produce the same result as swap the output pins from Arduino, and still would be inverted pitch and roll, just changing the side. It seems to be something else that im not getting yet. Take a look on the following pictures.
    My actual axis assignment:
    My interface settings:
    PWM with Roll all to the right (should be max PWM for one output and min PWM for another out, instead they move together, what is pitch behavior):
    PWM with Pitch on maximum (should be max PWM for both outputs, instead they move inverse, what is roll behavior):
    Thanks!!
    151,467Coins
    +11,039 / 56 / -2
    It sounds like one motor needs its direction reversed @Pedro Silva, as the way the Axis Assignment is set with one Dir checked for roll is correct and one motor should go up and the other down.
