2DoF Build Seat Mover
Discussion in 'DIY Motion Simulator Projects' started by DonCorleonez, Mar 15, 2016.
  1. DonCorleonez
    DonCorleonez Member
    195Coins
    Hi all,
    still about motor, after several browse in google about RPQ-180 motor, i find that vicpopo have experience with this motor.
    The problem He had is that he never found a suitable h-bridge to drive them.All h-bridges he used burned !!
    What does it mean?can i use ard-jrk or ard-mm route?
    153,788Coins
    +11,150 / 57 / -2
    It would help to link to the member/examples you are talking about, as I can't get my head around what the issue actually is.
  3. robatik
    robatik New Member
    iran
    164Coins
    Does anyone plug for the test?
  4. DonCorleonez
    DonCorleonez Member
    195Coins
    Hi all, i resume my project.
    by today i already place order for 3 motor 25:1 from Motion Dynamics, hope it'll arrive soon.
    In the meantime, i will use MM route, have anyone experience with it?or have reliable code
    153,788Coins
    +11,150 / 57 / -2
    You have your choice for Aduino code: https://www.xsimulator.net/community/faq/arduino-code-for-use-with-various-hardware-and-simtools.31/
    But try the SMC3 Aduino code out, as it has the handy Windows config utility: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Same with MM, there are different ways to configure them depending on what they are driving: https://www.xsimulator.net/community/faq/motor-driver-for-arduino-compatible-controller.11/category
    But as a single motor driver should be fine for the MMs: https://www.xsimulator.net/community/faq/monster-moto-shield-as-a-single-motor-driver.101/
  6. DonCorleonez
    DonCorleonez Member
    195Coins
    Thanks @noorbeast , new reading material while waiting motor and MM arrive
    Place order on MM from Aliexpress.com, 28.90 USD for 5 MM, hope it'll arrive soon and no defect MM
  7. DonCorleonez
    DonCorleonez Member
    195Coins
    Progressing by ordering 3x hall effect from singapore element14
    by the way, what is minimum wattage and voltage for 3dof psu?
    153,788Coins
    +11,150 / 57 / -2
  9. DonCorleonez
    DonCorleonez Member
    195Coins
    @noorbeast, how much do i need? one for each motor or two/one for all rig?
  10. stevemontuno
    stevemontuno Active Member
    1,461Coins
    @DonCorleonez You can use one PSU with 1 mostermoto running 2 motors ,,, or 2 PSU's for 2 monstermoto's running 2 motors ,,,,,,or 2 PSU's with 4 monstermoto's running 2 motors,,,.
    153,788Coins
    +11,150 / 57 / -2
    One per motor is recommended and they are cheap enough. Even though you can get quite powerful server PSUs they can be a bit sensitive and our sims tend to have significant power spikes, so best to have one per motor.
  12. DonCorleonez
    DonCorleonez Member
    195Coins
    thanks, will looking 3 server psu..
    and for coupling between motor shaft and hall sensor, i will use flexible coupling. Is there any special requirement for outer/inner diameter?
    after searching for several online store there is 8x10mm, 5x5mm, 6.35x5 mm.
    which one is suitable?
  13. noorbeast
    153,788Coins
    +11,150 / 57 / -2
    For flexible couplings 6.35mm is the standard shaft size for things like the Hall sensors, the other end you choose whatever fits what you are attaching it to.
  14. DonCorleonez
    DonCorleonez Member
    195Coins
    still waiting for parts..
    meanwhile, what is recommended pivot for under seat?i mean which parts of car can be used(with photo better, sometimes it have different meaning). And is there any specific type of vehicle?truck, sedan, mpv?
    153,788Coins
    +11,150 / 57 / -2
    Use a universal joint from a car tailshaft and mount it as close to the base of the seat as possible: https://www.xsimulator.net/community/faq/universal-joint-placement.108/
  16. DonCorleonez
    DonCorleonez Member
    195Coins
    @noorbeast, thanks for the advice, i need another advice.
    To build shoulder mount seat shaker, what is recommended size of steel for base frame & seat frame to make it as light as possible and not flexing?
    153,788Coins
    +11,150 / 57 / -2
    Minimum steel size depends a lot on design, as there are different ways to reinforce a structure, like triangle gussets and floor plates. But I would say 25mm is likely near the minimum and will need some design bracing to prevent twist.
  18. DonCorleonez
    DonCorleonez Member
    195Coins
    @noorbeast, i mean is the thickness is it 2.00 mm enough?or little bit overkill?
    for pivot?is it what i circled in photo can be used?both end? (dont mind for filename:D)
  19. Nick Moxley
    Yes that is a U joint style that your after. Just make sure its nice and tight at the joints and your good to go.
  20. DonCorleonez
    DonCorleonez Member
    195Coins
    got 4 unit second hand psu for 60 usd
