Simulator 3DOF development with brushless motor + Arduino
Discussion in 'DIY Motion Simulator Projects' started by Playsimulator, Jan 25, 2016.
  1. Playsimulator
    Playsimulator Member Gold Contributor
    france la voulte sur rhone
    178Coins
    3DOF, Arduino
    Hello everyone,
    I would like to show you my study of my 3 DOF simulator .
    For the cinematic of the motion platform, here are the element that I will use.
    • Angle gear 1/50 or 1/60 (see according to final mass of the platform
    • 1000W Brushless Motors Leadshine EL5-M1000-1-32 (3.2Nm / 3000 rev / min)
    • Double cam with different positions to 100mm / 80mm / 60mm.
    Mechanical of the motion platform 3DOF:
    [​IMG][/url
    [​IMG][/url
    Gravity center :
    [​IMG][/url
    Electrical of the motion platform 3DOF:
    I would like to use Simtools + Arduino Uno + 3 Driver Leadshine EL5-D1000-1 (See the link of the datasheet below). What do you think about that?
    https://www.google.fr/url?sa=t&rct=...K6PeA6hfgUTah08NA&sig2=KHgElHE2Cro5OMGU7qSUdA
    I try to draw the wiring between the arduino and the Driver Leadshine EL5-D1000-1. (See the PDF on the link below)
    http://jonueva.synology.me/Sch%C3%A9ma%20playsimulator_V2.pdf
  2. RacingMat
    21,082Coins
    it looks good! :thumbs
  3. Playsimulator
    178Coins
    3DOF, Arduino
    Hello Racing Mat,
    You are everywhere!!!
    You are impressive
    I need some information about the wiring between the Arduino and my brushless driver EL5.
    I am not electronics engineer; I understand nothing but I try.
    I would like to know if i can compare my driver EL5 with the card Monster in terms of signal. (PWM)
    For you the software of the arduino will be the same than you or not?
    For the moment it's a little fuzzy for me.
  4. RacingMat
    21,082Coins
    Thanks!
    can you share here the datasheet of this EL5?
  5. Playsimulator
    178Coins
    3DOF, Arduino
  6. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    Pourquoi ne pas mettre d simples rotule en place des joints de Cardan en haut des bielles ?
    Why not set up of simple ball universal joints at the top of the rods?
  7. Playsimulator
    178Coins
    3DOF, Arduino
    Hello Momoclic,
    The sphérical bearing does not have enough angle, I prefer use these types of hinges for their robustness and large tilt angles.
    The disadvantage is the price.
  8. Blugreen
    Blugreen New Member
    477Coins
    Hi @Playsimulator. I am going to follow this as I wish to build almost exactly the same unit. Have you progressed further?
  9. Playsimulator
    178Coins
    3DOF, Arduino
  10. Playsimulator
    178Coins
    3DOF, Arduino
    I would like to share with you the advancement of my project of 3DOF.
    I begin to see the end of the manufacturing and I hope that first results will be good.
    • Like Like x 6
    • Winner Winner x 4
  11. Martoul
    Martoul Member
    Paris, France
    177Coins
    Nice 3D pictures!
    153,770Coins
    +11,149 / 57 / -2
    Looking good, well done, and excellent craftsmanship.
    I am really looking forward to your next video once the top frame is complete.
  13. SeatTime
  14. sasystem
    sasystem New Member
    Metal Worker
    Spain
    367Coins
    I love this job.
    In practice you do not exactly like the design. Why? It's a nice design :thumbs
  15. SeatTime
    Not too sure who you are commenting to, but could not find a negative comment on this thread ? I do like AC Servo motors (I would have loved to use them in my sim) - I was just pointing out for members who may not know, that they are quite expensive $$$ for your average DIYer - which is true.
  16. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    Very Very nice ... Love your work
    Can you please just post more details of the motors wireing and the driver configuration .
    And which aurduino code did you use ?
    I mostly advice using a VFD inverters for 3 phase induction motors with the same angled gearbox and an SMC3 Arduino code for such 3DOF setup .
  17. sasystem
    sasystem New Member
    Metal Worker
    Spain
    367Coins
    I made a comment in the thread. It was not a response to your comment.
  18. bruce stephen
    general contractor
    michigan
    9,115Coins
    Wow those servos are a little pricey. This should be a blast when it's finished. Very clean build @sasystem look forward to seeing this rig completed.
  19. sasystem
    sasystem New Member
    Metal Worker
    Spain
    367Coins
    Bruce. Yes. I can not wait to see it in operation.
    PDF file link does not work. It's just me?
  20. Playsimulator
    178Coins
    3DOF, Arduino
    First test of the 3 DOF
    • Like Like x 5
