RC Model for Motion Simulation
Discussion in 'SimTools compatible interfaces' started by eaorobbie, Jul 17, 2013.
  1. Jun
    Jun New Member
    South America
    7,048Coins
    Servos also use potentiometer to calculate position. :thumbs
  2. BondeX
    BondeX Active Member
    EE
    Michigan, USA
    1,501Coins
    @Jun if that is the case than how come @eaorobbie's circuit on first page does not have anything going to analog input on arduino? Unless the servo has its own feedback loop?
  3. Jun
    Jun New Member
    South America
    7,048Coins
  4. BondeX
    EE
    Michigan, USA
    1,501Coins
  5. Malik10
    Malik10 Member
    MALAYSIA
    657Coins
    3DOF, Arduino, SimforceGT, Motion platform
    this is my model for three axis..roll yaw and pitch...how can i got the coding using arduino ?
    152,541Coins
    +11,086 / 56 / -2
  7. Drustar
    Drustar New Member
    Australia
    263Coins
    As a simpleton with general knowledge and understanding of the world, how can I possibly follow this? I successfully set up your 2dof system with hobby servo's running LFS, seems quite nice, however now I want to get into the reason I am here which is a 5 dof system where a 6th component is an electric motor offering 360 degree continuous yaw. Do you think I can do it or am I dreaming?
    I followed your instructions earobbie on how to expand the 2dof to a 4 dof but it didn't work. I simply copied and pasted the code into arduino for the 2dof setup, (thanks so much for that), I wish I could do the same for a 6dof setup. (hint hint). No seriously, I tried to change the parts of the script you suggest but still no luck.
    152,541Coins
    +11,086 / 56 / -2
    Did you set up the associated SimTools interface and axis settings?
  9. Drustar
    Drustar New Member
    Australia
    263Coins
    Yes, absolutely. The thing I don't understand is that I have seen a screenshot of the interface setup where the Interface output is R<Axis1>~L<Axis2>~F<~Axis3>~ etc, however in other posts it says you must specify a number from 1-255. what is the difference?
    152,541Coins
    +11,086 / 56 / -2
    The Interface Output designates the Axis and the Startup and Shutdown Outputs designate the position in the motion range, so you can do things like have the motors go to a particular position when starting and stopping: http://www.xsimulator.net/community/faq/startup-and-shutdown-positional-controls.234/
  11. Drustar
    Drustar New Member
    Australia
    263Coins
    Oh well thank you for making this understandable. So I guess an example would be when you have a high sitting seat, you might want it to drop down low at the end? Wonderful to know and thanks.
  12. eaorobbie
    20,488Coins
    Sending that via the axis output will cause code to error:
    R<Axis1>~L<Axis2>~F<Axis3>~ is correct you had a "~" in the wrong place
    Code reads the letter R , L , or F as you have set to decide which servo to move. Then reads <Axis(x)> value which is 8bit meaning it has a range of 0-254 being 127 is horizontal. Depending on how you have set the scaling in code it will either have 0 or 254 as it top position or the opposite on the bottom position.
    Hope that helps a little.
  13. Historiker
    9,208Coins
    Stickied so new users can find this easier. It is a great tool for prototyping new builds, especially for new users. I know it helped me a great deal way back when.
  14. TwinsDaddy
    TwinsDaddy New Member
    Salaryman
    Seoul, Korea
    248Coins
    Arduino, 6DOF
    Nice!!
    Thanks to your project.
  15. mirxtrem
    mirxtrem mirxtrem.apps
    Electrical engineering student
    Colombia
    312Coins
    excelent!, i wonder if i can use two servo motors or another king of motor to built a force feedback system to my steering wheel, because it does not have any.
    my idea is use sim tools for simulate the forces in the wheel.
  16. mirxtrem
    Colombia
    312Coins
    Thank You!, first i spend 10 coins download code but i didn't know how works exactly but then i download the full package with the presets and works perfectly. i dont have servo but i connected two leds and i can see the change in the light.
  17. LI JIAN HUI
    LI JIAN HUI Learn 2DOF maker
    CHINA
    351Coins
    2DOF, DC motor
    I bought a servo motor and drive plate, but no SimTools GameEngine like are not gold, and now really want to try the effect, how do ah brothers
  18. Nathan Older
    Nathan Older Member
    211Coins
    I remember my first test was with a couple of lego Motors, with a rig made of lego and a Scalextric Audi R8 sat on top.
    I have a video somewhere of the first run. will have to dig it out.
  19. pillowsack
    pillowsack New Member Gold Contributor
    Programmer
    Vancouver, WA, USA
    371Coins
    I seem to have trouble getting any noticeable movement from my servos. Sketch is running with no errors, wiring is correct, but the only thing I am unsure about is the Axis Assignments and the Interface settings.
    152,541Coins
    +11,086 / 56 / -2
