CarDashX : TM1638 sketch for GameDash
Discussion in 'Official Companion Apps' started by vthinsel, Aug 26, 2015.
  1. martin falz
    martin falz Member
    Deutschland
    228Coins
    thx this i have make but the problem iss the same.
    in the game dash tool i have signals but it comes nothing at the arduino.
    and i becomm the skript not load on the arduino
  2. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Gamedash setup looks OK, I see you are running Practice mode (in Race the dash is not working).
    Do you use Simtools only for dashboard?
    Do you have any Axis / Motors set in Interface tab in GameEngine?
  3. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,031Coins
    Arduino, 4DOF
    I got this issue once. You must have GameEngine fully working with interface settings / axis assignments fully working. Does tuning center report values ?
    I have just updated the file in the first post with the latest version which adds the T command : some games report the max RPM so the gamedash doesn't need to learn the max value, and it won't stop working due to weird RPM values reported (which required the button 6)
  4. cazsan
    cazsan Member
    Programmer
    444Coins
    I was actually in quick race mode. I'll try in practice mode as soon as I can.
    Yet, I use only SimtTool for the dashboard but I achieved to get it working with another ino code.
    I have 0 DOF but configured Interface 1 like this :
  5. vthinsel
    FRANCE
    6,031Coins
    Arduino, 4DOF
    Which version of the arduino IDE are you using ? I switched to 1.6.7 with no problems (avoir 1.6.6 which was broken)
    I also added the EEPROM lib I use in the first post, just in case.
  6. martin falz
    martin falz Member
    Deutschland
    228Coins
    Thx now iss it working. But the LEDs goes not.
    I have the sketch from the First side on arduino.
    Have i everything wrong doing?
    I play iracing and the setup iss the same wat vthinsel few Post bevor write.
  7. vthinsel
    FRANCE
    6,031Coins
    Arduino, 4DOF
    Are your leds single color or dual color ? My code handles dual color.
  8. cazsan
    cazsan Member
    Programmer
    444Coins
    I just wonder if you should not add this code to handle one color TM1638 and add a conf parameter in the ino file. What do you think about?
  9. martin falz
    martin falz Member
    Deutschland
    228Coins
    I don't know. What can i do to Check this.?is it easy to seit heute the sketch from 2 to 1 Color?
  10. vthinsel
    FRANCE
    6,031Coins
    Arduino, 4DOF
  11. cazsan
    cazsan Member
    Programmer
    444Coins
    I could test it if I get my display working ;)
    Anyway, the switch for red/bi-colored in the code is pretty small and easy to do, even if you don't put it in the CardashX code
  12. insanegr
    insanegr !N$@n€
    Athens
    16,721Coins
    dual colors LED have three pins and single color LED have two pins.look at the backside of the TM1638 to see how many pins you have and will see if they are single or dual color LED
  13. martin falz
    martin falz Member
    Deutschland
    228Coins
    Thx for your help. I have the Wrong sketch in arduino. Now iss all perfekt.
  14. cazsan
    cazsan Member
    Programmer
    444Coins
    Ok I just did some tests with the lastest code and lastest arduino IDE (1.6.7).
    Everything light up as usual, the logo displays well on the segments, the parameters are also well saved but still no data shown to the display (nor the leds for the RPM).
    I checked on Game Dash and Tuning Center to ensure my data is well updated and everything seems to work as expected (values changes when the car moves). The Game Manager is set up and connected..
    I'll test the dash with some other games to see if the issue comes from PCars or anything else.
    Edit : After a quick test on Assetto Corsa, it seems the dash does not updates like I have i other games. Maybe communication is broken with TM1638 and arduino?
  15. cazsan
    cazsan Member
    Programmer
    444Coins
    I get something to display only when writing command DATA through arduino console with 115200 baud rate set.
    If something different is selected as rate, nothing appears.
    So this parameter let met think that the problem could be GameEngine parameters so I changed to 115200 too but no more...
    Maybe Game Engine parameters have to be set with some data specific?
  16. mys3lf
    mys3lf New Member
    Designer
    118Coins
    There is any way to config 1 or 2 buttons on tm1638 to show Ex: Oil Temp / Water Temp or Fuel? its possible to do that?
  17. mys3lf
    mys3lf New Member
    Designer
    118Coins
    For those how want to invert the Display just add in arduino file
    #include <InvertedTM1638.h> and replace:
    TM1638 module1(5, 4, 3);
    to
    InvertedTM1638 module1(5, 4, 3);
  18. vthinsel
    FRANCE
    6,031Coins
    Arduino, 4DOF
    Check first post. Button 1 is used to display what you want on left side, button 2 for right side. Oil, fuel, lap, temp,...
  19. mys3lf
    mys3lf New Member
    Designer
    118Coins
    Thanks again... Now i have a fully functional CardashX and Tm1638 without lag... Now i have a request to made (another one) its possible to include single 7 segment display for shift indicator? i have one working but the arduino code only work with PC version (Pcars)... On PC version i use IC 74HC595 and 2 modules of TM1638 and works great...I think if it is possible to include single 7 segment for shift indicator it would be extraordinary....
    Just one more thing... your work is magnificent....
  20. vthinsel
    FRANCE
    6,031Coins
    Arduino, 4DOF
    You want to display the gear using a big seven segments indicator like this one (common anode) for example ?
    As there are many free pins on the arduino, it could be simple to drive it using an ULN2803 and some resistors , together with an additional power source as the +5V from USB will clearly be not enough. I can start to look at this, once I have finished my USB button box :D
