Showroom Thrustmaster T500RS Motor Upgrade 65W to 85W - SUCCESS 01/23/16
Discussion in 'DIY peripherals' started by Pit, Dec 14, 2015.
Would you upgrade your T500RS and risk to void the guarantee in case of a successfully upgrade?
  1. Yes
    33 vote(s)
    82.5%
  2. No
    7 vote(s)
    17.5%
  1. Pit
    30,510Coins
    ...which has been done!
    BTW still running. Meanwhile I have bought a DD wheel (Big MIge), so this nice gadget will to be offered this month including an adapter and the F1 wheel add-on.
  2. Masilicondrio
    Masilicondrio New Member
    Programmer
    Uruguay
    186Coins
    P120NF10 specs are max 100 Volts & 110 Amps :eek: woooow
  3. Chris Edwards
    Chris Edwards Yindi
    Australia
    365Coins
    DC motor
    Great news thanks for your experiment I have found and ordered the motor in Aus $220.00 delivered 3 weeks. I will use the new T500 my second for 2-3 months then do the upgrade.
    I previously owned a V2 Fanatec would not touch with a barge pole, great when working, but to deal with amateurs for 2-3 months and wait 4-5 weeks for them to email you back no thanks returned for a full refund and what a fight.
  4. Chris Edwards
    Chris Edwards Yindi
    Australia
    365Coins
    DC motor
    Hello I have completed the mod every thing works but the wheel continues to go left to right no self centre what so ever just keeps going left to right on start up until I turn it off.
    Any suggestions ? thanks.
  5. Pit
    30,510Coins
    Hi Chris. First thing that comes to mind is the (wrong?) polarity. Could you upload some HQ photos of your mod?
  6. Chris Edwards
    Chris Edwards Yindi
    Australia
    365Coins
    DC motor
  7. Chris Edwards
    Chris Edwards Yindi
    Australia
    365Coins
    DC motor
    How do you upload photos I tried the upload a file button nothing happens thanks. or you can send me your email address and I will send to that thanks.
  8. Pit
    30,510Coins
    Scriptblocker enabled? No Javascript enabled? Should work anyway. Please try again or upload to any image drive like https://imageshack.com/ .
    153,728Coins
    It could be restrictions as a new user, so just try again.
  10. Chris Edwards
    Chris Edwards Yindi
    Australia
    365Coins
    DC motor
  11. Chris Edwards
    Chris Edwards Yindi
    Australia
    365Coins
    DC motor
  12. Pit
    30,510Coins
    Hi CHris, first of all I cannot understand why you have cut the wire, the existing wire/cable does the job very well. Second I hope you did not damage the little board stuck on the motor, there are some diodes / transistors which can be damaged easily. Thirdly are you sure about the polarity after replacing the wire to the motors? Last but hopefully least the DY-01E340369 mini board stuck at the back of the motor has to be turned by 180° and IMO you forgot to ground one of the screws of the motors as shown on the second picture.
  13. Pit
    30,510Coins
    ADDENDUM ! ! ! Obviously the DY-01E340369 mini board is correct installed but w/o the GND?
  14. Chris Edwards
    Chris Edwards Yindi
    Australia
    365Coins
    DC motor
    Thanks so much for your help I am such an idiot I had to replace the wires I stuffed
    them I am going to do what you said tonight thanks heaps.
    Chris Edwards.
    The ground wire I have put on 1 of the 3 screws at the back of Hall sensor holder does
    that matter or not ?
  15. Chris Edwards
    Chris Edwards Yindi
    Australia
    365Coins
    DC motor
    Thanks so much for your help and diagrams all working now absolutely brilliant so much better feel all round even more power than the fanatec V2 which is way dearer.
    Thanks again.
  16. Pit
    30,510Coins
    Congratulations! As a bottom line you could confirm that the effort and cost is worth or it isn't?
  17. Chris Edwards
    Chris Edwards Yindi
    Australia
    365Coins
    DC motor
    I would go so far as to say it is worth doing even buying a new T500RS to do if you are thinking about the Fanatec V2 and putting the new 85 watt motor In straight away even better a second hand one.
    I have tried all the lower priced and medium ones this mod takes it way above the AU$1850.00 Fanatec V2.
    It just has more feel as you explained in your post and it never loses power like the 65 watt one (original).
    Thanks again.
  18. Kim R
    Kim R New Member
    Troms
    476Coins
    Out of curiosity, why would you want more gain? The T500RS already has way too much gain.. I'm running the main cpa settings at 60% overall strength.. And in game I even lower the ffb gains down to 40%.
  19. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    T500 rs has just enough torque to emulate the forces of power steering wheels. When it comes to emulate the forces of unassisted steering wheels it definately has a hard time keeping up. When the t500 rs base is fitted with an aftermarket 30cm+ sterring wheel, this "issue" becomes more evident.
    Now, when the t500rs wheel is fitted on a high power and fidelity motion platform its power cant keep up with the forces of the platform... and gives a weak and filtered end result.
  20. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    anyone who doesnt know how underpowered a t500 is has never used a OSW Direct Drive. My custom OSW stomps a t500rs. Makes it feel like the toy that it is.
