value1
iRacing Plugin 2.0.3.2
SimTools game plugin for iRacing
  1. bruce stephen
    general contractor
    michigan
    9,113Coins
    Do you get a readout of any kind when you boot up your game dash ard? I also notice the output is not set up at the bottom.
  2. TerminalKaos
    TerminalKaos New Member
    Australia
    260Coins
    Hi Bruce,
    I get no readout what so ever on the ard. I'm so very new to sim racing and this is the first time I am building a dash. Can I ask, what do you mean by the output is not set up on the bottom?
  3. bruce stephen
    general contractor
    michigan
    9,113Coins
  4. gorzasty
    gorzasty Active Member
    photographer, IT specialist
    Poland, Wrocław
    1,060Coins
    Hello Guys!
    I downloaded the latest ir plugin from here, but I have strange behaviour with it. My seat position is a little bit too far back in comparision with utjher titles like AC, pcars or rf2. But only when I drive. In setup or options screen seat goes ok a little bit forward. During driving everything looks ok but the offset I mentioned. Do You also have such a experience with the plugin?
  5. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    Use the Extra 2 instead of Heave. iRacing factors in gravity so when you are sitting still you are pulling 1G, most games have you at zero G when you are standing still. If you use Extra 2 it is Heave -1G so it corrects for this.
  6. gorzasty
    Poland, Wrocław
    1,060Coins
    Thank You very much @Avenga76 ! Really simple if You know the trick ;)
  7. Historiker
    9,207Coins
    Thanks especially to @value1 for updating this plugin, it used to really drive me nuts using heave :)
  8. jimmytm3
    jimmytm3 Member
    Boilermaker
    macksville, New South Wales Australia
    171Coins
    2DOF, Arduino, JRK
    Hey mate how are you i am having a bit of trouble with iracing for some reason after the latest update i have lost motion i have uninstalled and reinstalled patch and nothing seems to work i have done everything the same as normal! dirt rally etc work fine so i am thinking something has changed in iracing have you had the same problem? And do you know how to fix it ill give you an imaginary hug if you can help me lol
    Cheers James
  9. Historiker
    9,207Coins
    The last patch of iRacing automatically changes your account to DX11. Manually change it back to DX9 and see if that works. Unfortunately they are going to make iRacing DX11 only in December.
  10. Avenga76
    Network Engineer
    3,261Coins
    iRacing DX11 works with SimTools.
    I have a rift so I can only use DX11 and it has been running sweet. Make sure you are running the latest SimTools plugin because they added DX11 support for SimTools a while ago.
  11. bruce stephen
    general contractor
    michigan
    9,113Coins
    I have experienced no loss of motion with the latest build. I have been on dx11 for the last few builds and it is working (STv1.3). I had to go into the tunning center and enter smaller numbers. All fields had a base number at like 32000, I set the relevant dofs at 6 then tuned from there.
  12. bruce stephen
    general contractor
    michigan
    9,113Coins
    Its not broken just thought i would share this.
    Telemetry
    - New telemetry variables, "PlayerTrackSurfaceMaterial" and "CarIdxTrackSurfaceMaterial" are now available that indicate what type of surface is under the car (concrete, sand, grass, etc.). Surface materials are defined in new "irsdk_TrkSurf enum." This is measured relative to the center of the car, just as with the "PlayerTrackSurface enum" that indicates how the surface is scored (race, pit, offtrack, etc.).
    - New telemetry variables, "TireLF_RumblePitch", "TireLR_RumblePitch", "TireRF_RumblePitch", and "TireRR_RumblePitch" are now available. These represent the pitch in Hz produced by the tire going over a rumble strip, or 0 if the tire is currently not on a rumble strip.
    - A new telemetry variable, "PushToPass" has been added which reports the state of the Push to Pass button.
    - A new telemetry variable, "dcMGUKDeployModeToggle" has been added that indicates if the in-car MGU-K deploy mode is set to fixed(0) or adaptive(1).
    - New 360 Hz telemetry output has been implemented!
    - - 360 Hz telemetry logging is disabled by default. The option for enabling 360 Hz telemetry logging has been added to the "app.ini" file here:
    - - - [misc] irsdkLog360Hz=0 ; 0 = 360 Hz logging is disabled, 1 = 360 Hz logging is enabled.
    - - The XXshockDefl, XXshockVel and SteeringWheelTorque variables will now log out at 360 Hz, if enabled.
    :oops:- - 3 new (memory mapped file) variables have also been added that always log at the rate of 360 Hz, but not to disk. This is for use by motion platforms and base shaker plugins:
    - - - XXshockDefl_ST = Shock Position
    - - - XXshockVel_ST = Shock Velocity
    - - - SteeringWheelTorque_ST = Steering Wheel Torque
    - - This data is output as a 6 element array, with a new flag variable header indicating that ist should be treated as a subdivision of time. You will need a new version of the ATLAS plugin to properly view the data, however the old plugin, and any older telemetry tool, should continue to read the data just fine.
    - A new McLaren ATLAS importer version 1.05 is available for download from the member site. This adds some new unit conversion parameters and adds support for properly viewing 360 Hz telemetry.
    • Informative Informative x 3
  13. lilted86
    lilted86 Member
    Malaysia
    489Coins
    Hello guys,
    i have problem and crash when im using this iracing plugin on simtool 2.0...i only have 2 plugin installed in my pc which is 1)Default Live for speed and 2) iracing plugin..
    everytime i turn it on im having the crash..can someone help me?
    this is the crash log :
    System.NullReferenceException: Object reference not set to an instance of an object.
    at SimTools_GameManager.Mod_Lib.Stop_MemMap_Output()
    at SimTools_GameManager.Mod_Lib.GameStoped()
    at SimTools_GameManager.frmMain.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.6.1080.0 built by: NETFXREL3STAGE
    Assembly Version: 0.2.0.0
    Win32 Version: 0.2.0.0
    CodeBase: file:///H:/Program%20Files%20(x86)/SimTools/SimTools_GameManager.exe
    ZrYoMZvqOuzjCdBJQFIyVaqymal
    Assembly Version: 0.0.0.0
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 14.6.1038.0 built by: NETFXREL2
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.6.1081.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.6.1038.0 built by: NETFXREL2
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.6.1078.0 built by: NETFXREL3STAGE
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    Win32 Version: 4.6.1064.2 built by: NETFXREL3STAGE
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Game_PluginAPI
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///H:/Program%20Files%20(x86)/SimTools/Game_PluginAPI.DLL
    System.Management
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Management/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Management.dll
    iRacing_GamePlugin
    Assembly Version: 2.0.0.3
    Win32 Version: 2.0.0.3
    CodeBase: file:///C:/Users/ADS%20Farid%20Yan/AppData/Local/SimTools/GamePlugins/iRacing_GamePlugin.dll
    LiveForSpeed_GamePlugin
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.0.0
    CodeBase: file:///C:/Users/ADS%20Farid%20Yan/AppData/Local/SimTools/GamePlugins/LiveForSpeed_GamePlugin.dll
    Microsoft.GeneratedCode
    enabled.
    For example:
    <configuration>
    </configuration>
  14. bruce stephen
    general contractor
    michigan
    9,113Coins
    Have you updated .net framework?
  15. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    I agree I would check from 3.0 and up.
  16. lilted86
    lilted86 Member
    Malaysia
    489Coins
    i will try the latest version and will update here..thanks
  17. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Im pretty sure in the past that simtools used some things in 3.0/3.5 but that was possibly for fsx
  18. bruce stephen
    general contractor
    michigan
    9,113Coins
    4.6.1 is the current version and can be d-loaded here
  19. lilted86
    lilted86 Member
    Malaysia
    489Coins
    there's an latest update 4.6.2..and i already installed it just now...same crash happen..what did i do wrong now..
    this is the current crash log after install the 4.6.2:
    mscorlib
    Win32 Version: 4.6.1590.0 built by: NETFXREL2
    Win32 Version: 14.6.1590.0 built by: NETFXREL2
    System
    System.Drawing
    Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Xml
    Game_PluginAPI
    System.Core
    System.Management
    iRacing_GamePlugin
    enabled.
    For example:
    <configuration>
    </configuration>
  20. lilted86
    lilted86 Member
    Malaysia
    489Coins
    anyone?..or shall i post it on the simtool 2.0 discussion room?...
