knaufinator
BeamNG.drive plugin 2.0.3.0
Simtools game plugin for BeamNG.drive
  1. Trevdebow
    Trevdebow New Member
    Technical Instructor
    Brighton,Sussex
    - 187Coins
    2DOF, DC motor, SCN5
    My BeamNG plugin connects ok but nothing on the virtual axis window of the Game Engine. the BeamNG version Im using is -0.5.4.0.2252 recently purchaced. Get no output to the motion seat at all, still struggling.
  2. Trevdebow
    Brighton,Sussex
    - 187Coins
    Hi Everyone
    I'm having trouble getting any motion out of BeamNg plugin. Simtools connects ok but no out data. I have read that it is all in the main.lua and simtools.lua, but cannot figure it out. have prefixed the BeamNg shortcut with -luasocket but still no output. Can anybody help!!!:(
    Thankyou
  3. Trevdebow
    Brighton,Sussex
    - 187Coins
    Hi
    Im using BeamNGDrive-0.5.4.0.2252 and cannot get any output data, I noticed the patched main.lua does not reference simtools.lua, I am very likely wrong here, but can you post me the patched main.lua so I can see what I'm doing wrong? I'm pulling my hair out here!!
  4. Trevdebow
    Brighton,Sussex
    - 187Coins
    Hi All
    I'm having loads of trouble getting motion data out of this most recent plugin for BeamNg. I get a connection through the game engine but no data out. has anybody got BeamNg plugin working.
    Many thanks in advance
    Trevdebow
  5. Historiker
    9,208Coins
    Please keep plugin discussion in the proper thread. There is no need to create new threads on the topic.
  6. auryza
    auryza Active Member
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Hello @value1, @prilad,
    Last update on BEAMNG was month ago, 0.5.5 , probably they will release new one, soon, but hopefully they will not change nothing in file structure. Could you please check what is wrong, would be perfect to get motion from this game, again. Thank you in advance
  7. Scotty1186
    Scotty1186 Member
    Usa
    148Coins
    Just curious, I was thinking about getting this game and I was wondering if there was any resolution to this. I see it has been a few months and I was wondering if this has been solved before I pick up the game.
  8. value1
    14,995Coins
    Not yet . I think , nobody has taken care of yet.
  9. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Hello
    Solution will be after "SimTools 2.0" release. Now just need to wait.
  10. Grngoss76
    Grngoss76 New Member
    france
    47Coins
    Bonjour, le plug-in ne ffonctionne pas avec la version 0.8.. bonne année
  11. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Hello @prilad ,
    BeamNG plugin will be updated for Simtools V2?
  12. value1
    14,995Coins
    • Winner Winner x 4
  13. auryza
    Lithuania
    4,337Coins
    2DOF, 3DOF, Arduino
    Hello @value1
    What about to check what is wrong again with BeamNG plugin ?
    And after last update was one problem. When in game are more then one car, motion is unpredictable, it seems that motion reads other car forces.
    151,486Coins
    +11,041 / 56 / -2
  15. Kranky Pantz
    Kranky Pantz Active Member
    Canada, Eh!
    1,275Coins
    Hi folks.
    Does anyone here know if motion is still currently working with the latest Steam build of BeamNG?
    I've just purchased the game, and for the life of me cannot get any motion out of it.
    Perhaps things have changed in recent builds with how this is supposed to work?
    I've patched the game in the "Steamapps/Common/BeamNG.drive" directory (there weren't any specific instructions as to the correct path or directory for patching, so this is what I've chosen).
    The "Game Manager" turns blue when I start the game, but there is zero motion.
    I've set the Steam game launch option to the previously mentioned "-luasocket", but still nothing.
    The game itself does have menu options for enabling motion simulation using the standard SimTools IP & Port addresses correctly filled in (127.0.0.1 & 4123).
    Does that now override the need for the old "-luasocket" launch option.
    I've tried multiple ways and cannot get the game to actually provide motion, but it does change the Game Manager to the blue activation mode, which seems to indicate that it wants to work, but simply doesn't.
    :sos
    Any ideas???? :!
  16. value1
    14,995Coins
    Hi @Kranky Pantz
    I think the plugin does not work currently due to several changes in the API (data interface) of BeamNG.
    Don't waste more time with the current plugin. It needs re-coding :(
  17. Kranky Pantz
    Canada, Eh!
    1,275Coins
    @value1
    Oh no, well that's a bummer.
    Seeing that the in-game menu has a section for motion platform support with both IP & Port address options, I was optimistic that it would work.
    I tried it with the "-luasocket" launch option both enabled & disabled in Steam, but no luck.
    The game itself is actually quite fun, so I'll just keep it and start using the SimTools Joystick plugin for a bit of platform movement, hopefully that works.
    Did the game always have platform support in the menu options, or is that a new thing they've now added, perhaps making it more stable with future updates/patches?
    Cheers, and thanks for the quick response to my question!
  18. value1
    14,995Coins
    Hi @Kranky Pantz
    I wasn't aware that BeamNG finally supports motion data. We had to dive deep into the guts of the software previously.
    I'll give it a try when back at my PC.
    Thanks for the info!
  19. Kranky Pantz
    Canada, Eh!
    1,275Coins
    @value1
    You are welcome. :)
    Oh wow, that's great that you'll be looking into it so soon.
    If you do indeed have any luck, and wish to have a secondary tester I'd be glad to help out and report back.
    I'll be playing it later on today and over the next few days as well (I'm snowed in here at the moment, LOL!!!)
    There is also an "update rate" setting, along with several axis smoothing options available in the game's menu, so it looks like the game devs are taking motion seriously.
    BTW, does (or did) the SimTools plugin simply install into the BeamNG folder, or does it have to go somewhere else, like the "lua" folder?
    :popcorn
  20. value1
    14,995Coins
    • Winner Winner x 3
