Iracing info?
Discussion in 'Force-Sender & Plugins' started by paul3112, Aug 26, 2008.
  1. njracer
    njracer Member
    2Coins
    if i load it and uncheck the synaptrix of all axis option it will load without asking me the scn5 question, however the i can't hit the start button, there is no option to do so, its still white not blue
    am i supposed to hit the start button in the profiler? if not, after i load the simforcegt sample, what and where do i go to get the 3d model?
  2. njracer
    njracer Member
    2Coins
    ok, it pays to read, i just reread your instructions and found the 3d simulator simforcegt in the start menu, i disable the synaptrix of all axis when i loaded the simforcegt sample and am getting movement in the input section, i only have 3 things moving though, maybe cause i disable the stuff above. the three that are moving are
    #43-sender joyaxis Z
    #46-sender joyaxis RZ
    #47-sender joyslider
    i'll try what you just mentioned to see further anything
    looks like these must be for acceleration and braking as that is the only time they were moving. nothing happened when i turned back and fourth
  3. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    These effects a game-wheel values, not game values. There are no game values arriving in the profiler still.
    regards
  4. njracer
    njracer Member
    2Coins
    do you think its because i don't have any output's?
  5. egoexpress
    421Coins
    It seems that the NASCAR2003 plugin may not work for I-racing.
    The NASCAR2003 plugin needs a telemetry folder in the game directory. Does I-racing have such a folder as well?
  6. egoexpress
    421Coins
  7. njracer
    njracer Member
    2Coins
    there is no telemetry folder no, however the bluetiger guys got i-racing working with that api they gave out so its gotta be possible, i just don't know enough about this stuff to really help out. @ ego or sirnoname, if either of you guys are a racing fan i'll send you 20usd through paypal so you can get 1 month from i-racing and get it supported so we can all enjoy it, sounds good?
  8. egoexpress
    421Coins
    @njracer
    In the meantime, you could try to get the simforce 3D plugin working with another game.
    regards
  9. njracer
    njracer Member
    2Coins
    what do you mean? a game that already works so i get used to using it or a game that is not supported?
  10. egoexpress
    421Coins
    Yes
  11. njracer
    njracer Member
    2Coins
    well i just tried gtr2 and the same deal so maybe there is hope for i-racing. when i load the simforcegt sample i can't enable the synaptrix or i have to quit. also, when i go to launch the sim-force simulator 1.5 in the 3d simulation folder i get a message pop up and don't know what it says,
    rock-n-ride simulator
    '5,9 ist kein gultiger gleitkommawert.
    idk what that means but you think 1 of these 2 things could be causing the problem?
  12. egoexpress
    421Coins
    There are two seperate tasks.
    1. getting data out of a game
    2. using that data to move or display something
    Try to achieve task number one at first. Therefor you neither need a simforce profile, nor the simforce 3D plugin.
    Did you made the correct settings in the player.plr for GTR2?
    http://www.x-simulator.de/main/en/force ... gtr-2.html
  13. njracer
    njracer Member
    2Coins
    i didn't change the plr file the first run now that i did there are numbers going all over the place in the profiler. :D on a good note it works, bad note is i-racing apparently doesn't :( yet :D
  14. egoexpress
    421Coins
    Ok, task 1 accomplished :thbup:
    Now add a g-force effect for the lateral accellerations, and define an axis for it. Lateral forces should be assigned for X-axis.
    Then add a g-force effect for the long accellerations, and define it to the Y-axis.
    If you hover over the values in the list, the descriptions of each one should appear.
    Then open the simforce 3D simulation.
  15. njracer
    njracer Member
    2Coins
    what section is this in where i add the g effect to an axis?
  16. njracer
    njracer Member
    2Coins
    ok i got the new plugin and profile in and am running iracing and there are more numbers moving now.
    #22 try to connect sender for plugin info
    #23 try to connect sender for plugin info
    #25 try to connect sender for plugin info
    #26 try to connect sender for plugin info
    #41 sender joyaxis x
    #42 sender joyaxis y
    #48-53 depending on what gear i'm in
    #60 gear: current gear of car or bike
  17. Ringorumble
    Ringorumble Active Member
    190Coins
    Hi, did it with the new one, heres the data moving like on the pic shown, sorry for the bad arrows
      133.7 KB
      783
  18. njracer
    njracer Member
    2Coins
    yeah i just got the values too, looks like it works good :D
  19. njracer
    njracer Member
    2Coins
    my mistake, the check in the force profiler goes unchecked when in the menu and checked when in sim driving
  20. Ringorumble
    190Coins
    when i go back to menu it disappears, enter session it appears ...
    btw, 21 to 26 still moving but shows now try to connect sender for plugin info
