Project Cars UDP Alternate Plugin
Discussion in 'SimTools Plugins' started by vthinsel, Feb 16, 2016.
  1. SBDESIGN
    SBDESIGN some knowledge
    director
    125Coins
    2DOF, SCN5
    This is exactly where I am confused:
    Patch what? as the game is on xbox one.
    Am i totally thinking about this wrong?
    I have read about " launch notepad.exe on GameManager PC" does this literally mean have notepad open and do nothing with it?
  2. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,052Coins
    Arduino, 4DOF
    Yes I did it on PS4, as it is my gaming platform. You do not need a script. You need to launch notepad.exe that will trick the game detection mechanism. I know this is not clean, but it is the only quick&dirty alternative I had. I started a discussion with @yobuddy and @value1 but I need to catch-up on this to find a more elegant way.
  3. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    Cheers insanegr
    But this is where I am stuck...
    1. drag/drop plugin
    2. go through patching (BUT what patching if game is on xbox one?)
    3. Launch Pcars (on xbox one I assume)
    4. Launch notepad on pc (what? just open notepad - thats it?)
    So I am stuck at task 2 lol - I'm probably being an idiot
  4. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    vthinsel: thanks for info, and thanks for your creation. I am very interested as i haven't seen any claim of anyone trying this or using it with xbox one. Its very revolutionary! well done!
    So I do not have to assign xbox one ip or anything like that? (not read that anywhere anyhow :) )
  5. vthinsel
    FRANCE
    6,052Coins
    Arduino, 4DOF
    Nothing to configure. Just activate UDP on PCars. Data is sent on UDP, using broadcast explaining why you can use simultaneously XSim, Apps on tablets/phones/ , etc. Everyone has access to the sme broadcasted data as long as you listen on the correct UDP port.
    Your XBox must of course be on your network, and more precisely on the same network as the devices (including XSim) you want to get data from. Broadcast packets are no routed, network wise.
  6. vthinsel
    FRANCE
    6,052Coins
    Arduino, 4DOF
    UDP port is pre-defined. Do not bother about that. Just make sure UDP is enabled in the game and that your PC has no firewall/antivirus blocking the UDP stream. you can make sure UDP traffic arrives on your PC by using the small exe file I included in the zip file of the plugin, or in this post as well.
  7. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    In my other post I found I was doing something wrong.
    Radioproffi pointed it out with a screenshot, that I had to make a txt file. I didn't read the message correctly when I clicked patching, and assumed it asked for cars install location .
    Now I can launch note pad and it does say GAME CONNECTED. However I can not get any sliders to move.
  8. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    Im on w10 and that app says a problem will close the program. [​IMG]
  9. Radioproffi
    Lviv
    1,659Coins
    It looks like you have closed or busy port is needed UDP - 5606
  10. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    Is this perhaps because I am remote into the pc via my macbook?
  11. Radioproffi
    Lviv
    1,659Coins
    You can check it in Task Manager
  12. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    For some reason, after clicking this in task manager, I got a dos window displaying live values for my xbox one.
    I re-shut everything down, and rebooted the simtools engine and manager.
    And now I can see sliders move :)
    And more than that the actuators move !
    MASSIVE thank you! You guys have really helped and been patient.
    My final issue looks like its just setup configs.
    Because both my actuators move at the same time on roll, they are never different lengths.
    I have axis 1 and 2 set up the same with Roll and pitch in dof1 and dof2 and coloured the boxes orange. Is this correct?
  13. noorbeast
    153,001Coins
    +11,116 / 56 / -2
  14. SBDESIGN
    director
    125Coins
    2DOF, SCN5
    Thank you
    its fairly hard work at first isn't it. I understand tho, we or I am not asking for something common and simple. So I suppose the solution and setup won't be simple either.
    I just learnt about the Dir, and what it means thank you. At work now, but that certainly sounds like my issue.
    My head has hurt a lot already, and not even started to build the rig lol.
    I'm just over the moon that I have xbox one, cars, and actuators all syncing - it seems like the impossible, and can't find anyone who is using this setup, and many believe it is impossible.
    Funnily enough, back to the start - I am going to be on a gaming PC, but don't want to order parts until my oculus is shipping. This is so I can get the best 1080 card at the time. They are all coming out right now, so its right to wait a few weeks. Oculus stated July 12th, so got a month to play, and it is amazing news that I can do this all via my xbox one. This means i can get all setup and ready before buying a pc.
    I think if PS4/XBOX one owners knew that you can build a motion rig for Pcars on console for about £300 - then we would have hundreds of additional members building motion.
    Thanks again!!!
  15. Nur
    Nur New Member
    36Coins
    2DOF, 3DOF, Arduino, JRK, 4DOF
    Hello! I can not figure out how to do this? Which file should be sozdovat, where and how? The plugin does not see the game! What I've done; 1 Download the plugin (zip) 2. drag it Sim Tools plugin updater 3. Opened the game manager and pointed the way, what were answered Not a vaid patching patch! Please explained to the points of how to correct?
  16. Nur
    Nur New Member
    36Coins
    What are you good assistant Thanks !!!
    153,001Coins
    +11,116 / 56 / -2
    What game are you trying to patch?
    Most games will be patched to their install folder, including those inside the Steam install directly.
    But some, like Codemaster games, are confusing as they patch to the install directory if it is a 32bit system, but they patch to the particular game inside the Games folder in My Documents if it is a 64bit system.
  18. NoreiT
    NoreiT New Member
    Czech republic
    219Coins
    Sorry guys, didnt had time to do all the suggested things (capture min/max). In meantime I did learn its crucial to do it as I was optimizing LFS. Hope to get to Project Cars soon enough to try this :)
    153,001Coins
    +11,116 / 56 / -2
    Done!
  20. Octavio Olvera
    Octavio Olvera G4m3r43ver
    Trade Marketing
    Veracruz. Mexico
    65Coins
    Man, i´m on the same situation, i´m going to try the same thing even when it´s weird but i´ve tried a lot of things and the game manager still doesn´t recognize the UDP signal from my xbox one even when the UDP .exe works inmediatly. Thanks to you all for your hard work and inspiration.
