MY SIMULATOR IN MINIATURE
Discussion in 'DIY Motion Simulator Projects' started by luky_90, Mar 5, 2016.
  1. RacingMat
    21,082Coins
    More troubleshooting :confused: you've a bad luck
    Can you tell us:
    is it a genuine arduino?
    are you using a hub?
    is your arduino USB calbe shielded?​
  2. luky_90
    luky_90 Member
    276Coins
    Arduino is original , do not use hub for collegamentro and the cable is shielded ,
    I noticed that if the game manager is off Arduino not mad, there is a guide to connect two PCs ?
  3. RacingMat
    21,082Coins
  4. luky_90
    luky_90 Member
    276Coins
    hello @RacingMat , are I'll be able to find the problem and now everything works to perfection , I had an engine that was carrying current to all chassis shorting out the monster bike and Arduino ,
    Now I wanted to ask in the forum is a profile for a 2 DOF already done as a starting point ?
    153,770Coins
    +11,149 / 57 / -2
  6. RacingMat
    21,082Coins
    Good! :)
    http://www.xsimulator.net/community/threads/2dof-arduino-simulator-with-rear-wipers.4896/
    http://www.xsimulator.net/community/threads/2dof-arduino-simulator-with-rear-wipers.4897/
  7. luky_90
    luky_90 Member
    276Coins
    thank you, that I find in the link I passed all presets with rear engines and I have in front of them change the settings ?
  8. eaorobbie
    20,502Coins
    Invert the axis assignments, When going from rear mounted to front mounted motors in 2DOF
  9. luky_90
    luky_90 Member
    276Coins
    this is a video of the finished simulator What do you think? I feel a delay in the change right direction , left !! because?
  10. Pedro Pablo
    Pedro Pablo Active Member
    Software Developer
    Valparaiso, Chile
    599Coins
    Looks good my friend
    153,770Coins
    +11,149 / 57 / -2
    Do you mean the sway axis is slow responding to a change of direction?
    It would help if you post screenshots of all your SimTools and Tuning Center settings.
  12. luky_90
    luky_90 Member
    276Coins
    @noorbeast these are photos of simtool I forgot to photograph the center tuning but remember it by heart , and I will write below :
    Roll 7
    Pitch 5
    Heave 3
    Surge 3
    Sway 3
    later if I can take a picture at the center tuning
  13. noorbeast
    153,770Coins
    +11,149 / 57 / -2
  14. luky_90
    luky_90 Member
    276Coins
    Lowest I axis more movements seem weak , lighthouse a try in the afternoon !! the center is fine tuning ? there is a guide for the center tuning ? Pretty much for everything !!
    153,770Coins
    +11,149 / 57 / -2
  16. luky_90
    luky_90 Member
    276Coins
    because I can not set the center tuning 1.5 ? if I write when I save 1.5 becomes 15
    153,770Coins
    +11,149 / 57 / -2
  18. luky_90
    luky_90 Member
    276Coins
    5/6 months makes browsing the forum I found a post by a guy through an ' Arduino and a sensor made to move the image of the TV turning the VR head type only without wearing glasses !! someone can tell me where the post is not I find it more !!!
    153,770Coins
    +11,149 / 57 / -2
  20. luky_90
    luky_90 Member
    276Coins
    is the concept is this but a guy had remade by Arduino but so is fine !! always very kind thank you !!
