Kermit Kong's 6DOF Project
Discussion in 'DIY Motion Simulator Projects' started by kermitkong, Jun 15, 2016.
  1. noorbeast
    153,920Coins
    +11,156 / 57 / -2
    Nice work...it is always a relief to hook it all up and have it work :thumbs
  2. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,240Coins
    today i finally mounted the "regen energy buffer". This is very important to secure your motor-driver-bridges from returning energy from the motor during direction changes or a brake.
    The excess energy capacity from the motors are temporay stored into the 24V/1.3Ah lead-acid gel batteries.
  3. kermitkong
    1,240Coins
    next level arrived !
    swash plate assembled and under test :cheers
    • Like Like x 9
  4. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    First thing I think: "I must build a motion Sim" - * Feverishly Builds Sim, consumed for months *
    Last thing I think: "Will it fit through a door" - Crap!
  5. kermitkong
    1,240Coins
    Hehe, this was also my first thought,
    But I made it, now I've a motion seat in my hobby-room which does NOT fit through the door..... Now I think it's doesn't matter, I never will move this monster, so everything is fine, I'm happy :)
  6. Archie
    Wollongong, NSW, AU
    3,797Coins
    I did the same with my first build. Love your 6DOF. I'm very envious of anyone who makes a 6 DOF :)
  7. kermitkong
    1,240Coins
    Seat mounted !
    • Like Like x 6
  8. SeatTime
    I may be looking at this all wrong, but how do the batteries get on with the changing polarity from the motor?
  9. kermitkong
    1,240Coins
    This is a principle circuit design to explain how this works together. If you have questions please feel free to ask !
  10. SeatTime
    That's fine just wondered how you were doing it. FI on the MMs, capacitors are used on the driver card itself to do the same thing.
  11. kermitkong
    1,240Coins
    Hi @SeatTime ,
    I've also a 22000uF cap installed,
    But the regen voltage from motors back to the power supply jumps up to 36 volt (without my battery buffer). And this is really bad for the power supply and the motor driver board . I already distroid both of them one time. With the buffer circuit the regen voltage is limited to about 25V this is absolutely fine.
  12. SilentChill
    20,601Coins
    I have not had that problem @kermitkong and I have been running my 6DOF for nearly 12 months. I have just put 1000uf caps on the MM's and they are ok. Only problem I have had is the cheap chinese MM's being poorly manufactured
    • Informative Informative x 3
  13. kermitkong
    1,240Coins
    I See,
    I use the roboclaw 2x60A boards .
    And with my 6 heavy 24v/490W motors I've definitely this issue and the 22000uF or even 44000uF isn't enough. That's the reason why I'm using batteries to store energy temporary.
    And this works quite good now :)
    Hey @SilentChill thanks again for all your effort on the elite plugin project !!! Awesome!
  14. SilentChill
    20,601Coins
    Ahh of course you are, sorry getting my wires crossed with all these 6DOF's being built thought you had MM's
    • Funny Funny x 2
  15. kermitkong
    1,240Coins
    Here we go,
    1st ride on my 6DOF motion seat :cheers
    • Winner Winner x 8
  16. kermitkong
    1,240Coins
    Since that the Hotas warthog doesn't have gearing on the stick,I installed foot-pedals for gearing (same like in a helicopter ).
  17. Archie
    Wollongong, NSW, AU
    3,797Coins
    Nice Pedals. Where are those from?
  18. kermitkong
    1,240Coins
  19. Justin Dail
    Justin Dail Member
    Georgetown South Carolina
    393Coins
    3DOF, SCN5
    Very nice build looks and performs fantastic I'm looking to use the same type of gear box do you have a link the smallest I've found so far is 56c
  20. kermitkong
    1,240Coins
    Hi @Justin Dail ,
    I use size 040 for the gearboxes, smaller is too fragile I would say. The gearboxes were about 60 USD each.
    I will check for a weblink where I'm bought it. Keep tuned ...
