value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. AlexinChina
    AlexinChina Member
    China
    371Coins
    @value1, as the picture shows,I have found the [​IMG] Vert G-force's Static Base 140D9FC40, and 140D9FC40->04E81150,
    04E81150+8 ->Vert G-Force's value,
    04E81150+C->Horz G-Force's value,
    04E81150+10->Horz G-Force's value.
    and as thesecond picture shows, the red box marked place, how can I fill it?
  2. AlexinChina
    AlexinChina Member
    China
    371Coins
    and as thesecond picture shows, the red box marked place, how can I fill it?And this way is ok?
  3. AlexinChina
    AlexinChina Member
    China
    371Coins
    '/// MemoryHook Variables ///
    Private Const _Is_MemoryHook As Boolean = True 'Is a Memory Hook Required for this game?
    Private Const _MemHook_Heave_Pos As UInteger = &H140D9FC40
    Private Const _MemHook_Roll As UInteger = 0 'Not Used = 0
    Private Const _MemHook_Pitch As UInteger = 0 'Not Used = 0
    Private Const _MemHook_Heave As UInteger = _MemHook_Heave_Pos + &H8 'This is the memory offset
    Private Const _MemHook_Yaw As UInteger = 0 'Not Used = 0
    Private Const _MemHook_Sway As UInteger = _MemHook_Heave_Pos + &HC 'This is the memory offset
    Private Const _MemHook_Surge As UInteger = _MemHook_Heave_Pos + &H10 'This is the memory offset
    Private Const _MemHook_Extra1 As UInteger = 0
    Private Const _MemHook_Extra2 As UInteger = 0
    Private Const _MemHook_Extra3 As UInteger = 0
  4. AlexinChina
    AlexinChina Member
    China
    371Coins
    In VS2010,I have gain a error:
    1 Error constant expressions can not be represented in the type "Integer" in.
    I'm looking forward your answer, thank U!@value1,@SlientChill Thank U!
  5. AlexinChina
    AlexinChina Member
    China
    371Coins
    I try to use CheatEngine to find the speed,but I can't, can you help me?
  6. SilentChill
    20,595Coins
    Why are you mem hooking ?
  7. SeatTime
    Agree, this game supports telemetry UDP..as you have proven.
    And as advised a page back..
  8. AlexinChina
    AlexinChina Member
    China
    371Coins
    haha, because mem hook looks easier to implement, and I don't how to acheive the UDP feedback.
    And thanks for your answer!:)
  9. DoThink
    DoThink New Member
    fujian
    - 34Coins
    Arduino, Joyrider
    Hi,Everyone !
    Please Tell me Why?
    I had download 2.2 plus ,and test on Nolimits 2.2.3,it's working fine!
    but I want use on Oculus CV1, then I get the Nolimits 2.2.5.1,not demo.I can't get any motion data.
    Why?
    Thanks~~~:(
    152,529Coins
    +11,085 / 56 / -2
  11. Wanegain
    Wanegain Active Member
    Bruxelles
    2,008Coins
    Does it work with the demo version ?
    152,529Coins
    +11,085 / 56 / -2
    No.
  13. DoThink
    DoThink New Member
    fujian
    - 34Coins
    Arduino, Joyrider
  14. DoThink
    DoThink New Member
    fujian
    - 34Coins
    Arduino, Joyrider
    Thanks Help, I found why?
    My shortcut is wrong,it's my mistake~~~
    :p
  15. vrxsim
    vrxsim New Member
    Barcelona
    144Coins
    3DOF, SCN6
    Hey guys,
    Is there anyway to solve the bug of the motion profile in Game Manager getting stuck to No Limits 2 after a session? The only way to solve this as of now is to Sign out and Sign in to Windows again.
    Would highly appreciate any help!
  16. noorbeast
    152,529Coins
    +11,085 / 56 / -2
    NL2 not exiting cleanly is a know plugin bug.
    This is super crude, and not 100% effective, but I wrote the attached kill script to hunt down and kill running NL2 processes, then kill SimTools, then automatically restart SimTools. You are welcome to give it a go if you like.
  17. raversturm
    raversturm New Member
    Ukraine
    238Coins
    Hi to all - please send it plugin or link - i'm just registered on the forum///
  18. noorbeast
    152,529Coins
    +11,085 / 56 / -2
    Find out about the coin system and plugin access here: https://www.xsimulator.net/community/faq/coins-and-how-to-download-plugins.2/
    And here: https://www.xsimulator.net/communit...ng-appropriate-credit-community-etiquette.53/
    Members have the option to donate coins, but it helps if they know about the project you are working on. So when you are ready please start your own project thread here: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
  19. vrxsim
    vrxsim New Member
    Barcelona
    144Coins
    3DOF, SCN6
    Awesome, thank you!
    From time to time when running the script it says "Game Engine is already running". Only solution for that is to restart the computer. Any idea?
    152,529Coins
    +11,085 / 56 / -2
    Try running it again or ctrl+alt+del and kill the running process manually.
