Kermit Kong's 6DOF Project
Discussion in 'DIY Motion Simulator Projects' started by kermitkong, Jun 15, 2016.
  1. Justin Dail
    Justin Dail Member
    Georgetown South Carolina
    393Coins
    3DOF, SCN5
    That would be great
  2. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,240Coins
  3. Justin Dail
    Justin Dail Member
    393Coins
    3DOF, SCN5
    Wow nice price are they holding up so far
  4. Slider
    Slider Active Member
    Irrigation
    Brisbane
    1,130Coins
    2DOF, JRK
    This looks fantastic, awesome job!
    How much weight can the platform hold?
  5. kermitkong
    1,240Coins
    Hi @Slider
    Also the buildup (all components on the moveable swashplate) weights about 30kg and an additional 100kg payload is no problem, already tested :). I can imagine that the maximum payload could be about 150kg.
    The motors with 490W each are definitely strong enough.
  6. kermitkong
    1,240Coins
    if anybody wants to build there owm 6DOF motion seat based on my system, i'm willing to share all the drawings, 3D and 2D (for private use only).
    please let me know.
    • Like Like x 5
    • Friendly Friendly x 4
  7. Grigory
    Grigory Active Member Gold Contributor
    Moscow
    222Coins
    3DOF, 6DOF
  8. Nick Moxley
    From what i can see, You dont have much weight on the motors. Having a slightly rear biased balance point will help eliminate the backlash you might be feeling in motion.
  9. Grigory
    Moscow
    222Coins
    3DOF, 6DOF
    I have 6dof, so I do not think moving backwards will solve the problem.
    I mostly feel it at sharp reverses, when everything starts to rattle quite a bit
  10. Nick Moxley
    Ah ok, that renders my point moot, Totally different balance point and how the gears are reacting to the motion ques. Sorry, carry on.
    fwiw my tip works a treat on 2dof seat movers. ;)
  11. lioxacydak1
    lioxacydak1 Member
    rescuer
    - 256Coins
    Friends what firmware apply what arduino uno or mega 2560, offer firmware for tests on mega 2560.
  12. lioxacydak1
    lioxacydak1 Member
    rescuer
    - 256Coins
    Friend please tell me your engine settings on the actuators and their power as rpm and torque retention. Thank you .
  13. siemenson
    siemenson New Member
    Hangzhou Zhejiang China
    353Coins
    I would like to know how the real time.
  14. MB
    MB New Member
    3D animation supervisor
    Sydney Australia
    46Coins
    Arduino, 6DOF
    What a great project... I'm excited to build one myself. I wonder how much this will cost & what tools are required ?
  15. kermitkong
    1,240Coins
    hi, i'd send you a PM...
  16. kermitkong
    1,240Coins
    clean regen-circuit design with component recomendations
    The Battery MUST BE lead-acid type of battery
    • Informative Informative x 3
  17. kermitkong
    1,240Coins
    here is the belt pulley CNC processing for @kermitkong 's actuator.
    Isn't easy to machine the steel belt pulley's
  18. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Looking forward to see your actuator up and running @kermitkong ! Maybe it is time to make your own thread? Would be better to keep actuators info organized.
  19. kermitkong
    1,240Coins
  20. Hoddem
    Hoddem Well-Known Member
    Engineer
    Minnesota, USA
    3,343Coins
