  1. Historiker
    9,208Coins
    @Enrique.Rolon you are welcome to post in your own language but you are also required to post in English as that is the language of this forum. I realize that you are responding to Moaale in his language but it would be hard for others to follow the conversation and also help with issues if you post in a different language. Please use google translate to post in both languages. I have done so for you this time.
  2. Snail
    Snail New Member
    - 58Coins
    how must i change the ports in the code to use this MotoMonster to an Ardunio stack.
    I use this configuraion also on X-Sim, but now i would change to Simtool.
    But with the code it dont work's for me.
    152,676Coins
    +11,089 / 56 / -2
    Are you using UDP Mode with SMC3Utils, as per the instructions?
  4. Snail
    Snail New Member
    - 58Coins
    I hang on the "Initial Setup" Step 9.
    No motor is starting to move.
    I use only 2 motors, but the code is for 3 motors.
    This is the pin assignment from x-sim (XPID.ino)
    Pin 5 - PWMA - Speed for Motor 1.
    Pin 6 - PWMB - Speed for Motor 2.
    Pin 4 - INA1 - motor 2 turn
    Pin 7 - INA2 - motor 1 turn
    Pin 8 - INB1 - motor 1 turn
    Pin 9 - INB2 - motor 2 turn
    Pin A4 - input of feedback positioning from motor A, wire here the feedback pot middle pin
    Pin A5 - input of feedback positioning from motor B, wire here the feedback pot middle pin
    and this is from SMC3 (SMC3.ino)
    const int ENApin1 =2; // ENA output pin for Motor H-Bridge 1 (ie PortD bit position)
    const int ENBpin1 =3; // ENB output pin for Motor H-Bridge 1 (ie PortD bit position)
    const int ENApin2 =4; // ENA output pin for Motor H-Bridge 2 (ie PortD bit position)
    const int ENBpin2 =5; // ENB output pin for Motor H-Bridge 2 (ie PortD bit position)
    const int ENApin3 =6; // ENA output pin for Motor H-Bridge 3 (ie PortD bit position)
    const int ENBpin3 =7; // ENB output pin for Motor H-Bridge 3 (ie PortD bit position)
    const int PWMpin1 =9; // PWM output pin for Motor 1
    const int PWMpin2 =10; // PWM output pin for Motor 2
    const int PWMpin3 =11; // PWM output pin for Motor 3
    const int FeedbackPin1 = A4; // Motor 1 feedback pin
    const int FeedbackPin2 = A5; // Motor 2 feedback pin
    const int FeedbackPin3 = A2; // Motor 3 feedback pin
    I changed already the pins for the pots ( A0 -> A4; A1 -> A5 ). This works fine.
    But no motor is moving. The pin assignment is different, but i think it can work with some changes.( only what ?? )
    152,676Coins
    +11,089 / 56 / -2
    How many motors are supported is not the issue.
    Please post pictures of all your settings.
  6. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,320Coins
    @Snail, It won't work by just reassigning pin numbers (in particular PWM pins). I suggest you just rewire the board as per the pinouts in the first post.
  7. Snail
    Snail New Member
    - 58Coins
    Hello Rufus,
    i have rewired my Arduinio to MotoMonster Board, like you configuration in post ( side 1 )
    But no motor is moving. Whats wrong with my setup or must i change some settings in SMC-Setup Tool ?
  8. Pit
    30,499Coins
    Honestly you say you wired like in the first post but before we can help please upload HQ photos of your wiring
  9. luky_90
    luky_90 Member
    276Coins
    hello guys, I just finished assembling the IBT - 2 tabs 43A , I did some testing with voltmeter and 12v voltage to the cards but comes at a time when the motors turn the potentiometer is not working and exit the card marks 0v why? when I loaded the code I put defineMODE2
  10. Pit
    30,499Coins
    ui, hardly to understand...better you upload a video, screenshots and/or photos?
  11. luky_90
    luky_90 Member
    276Coins
    This is the photo of the links
  12. Pit
    30,499Coins
    ..which does not help. I mean you should upload photos from your wiring, your setup, and not the manual etc lol
  13. luky_90
    luky_90 Member
    276Coins
    photo is far enough away if you are unable to understand tonight I try to do them again
  14. luky_90
    luky_90 Member
    276Coins
    Tonight I tried to connect one motor but equal , to the board arrive 12v and 5v to the potentiometers , but when I turn the potentiometer the motors are at a standstill , I am attaching photos of a single motor connection image.jpeg image.jpeg image.jpeg
  15. luky_90
    luky_90 Member
    276Coins
    the photos are fine ? These are the settings simtool
  16. luky_90
    luky_90 Member
    276Coins
    I am continuing to do testing and I had a doubt , without turning simtool and moving hand potentiometers engines run too ?
  17. luky_90
    luky_90 Member
    276Coins
    These two videos are hoping that can be of help , with monstermoto use the mat code while racing with the BTS SMC3.ino code.as you see with the BTS you do not move anything because ? I hope for your help
    BTS:
    MONSTERMOTO:
  18. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
  19. luky_90
    luky_90 Member
    276Coins
  20. RufusDufus
    Adelaide Australia
    16,320Coins
    When you say mat code do you mean RacingMat's software? Have you had the SMC3 code working with MotoMonsters?
    I'm afraid the information you are providing is very incomplete, disjoint and confusing.
