  1. noorbeast
    152,445Coins
    +11,078 / 56 / -2
  2. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    Yeah, it would be perfect for any Arduino based project, you might just need to tweak the length of the supports based on the height of the shield you are using. I will be making some more different designs when I change from JRK's to MM's
    Awesome!! I didn't know we had a 3D printing section.
  3. Avenga76
    Network Engineer
    3,261Coins
    Just did a little test of the threads and they work fine at 0.2mm and the threads printed great. This test was with an M4x15mm bolt with a .05 pitch.
    I was able to tighten it so hard that it started to crush the plastic, you can see the circular dent in the top where the bolt crushed the plastic so there is no change of the thread stripping out.
    This means I can get the print time down to 6 hours.
    I will print another test one to see how it compares with the slower settings.
  4. Avenga76
    Network Engineer
    3,261Coins
    I did a print at 0.2mm layer height and it came out really well. Looks just as good as the 0.1mm.
    This has dropped the printing time from 17 hours down to only 8.
    Here are some photos. The one on the left is the 0.2mm and the one on the right is the 0.1mm
    • Like Like x 6
  5. Pit
    30,494Coins
    At the moment we have still hot summer temperatures, so yesterday I was driving my Mercedes (a 11 years old one lol) for testing purposes, what happens with the wind flow - with open windows of course - mostly the wind is coming from the back! Ergo IMHO my design is not too false @speedy ;)
  6. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    :grin:grin ...
    That is called "A perfect 3D effect" ... :thumbs :D:D
  7. speedy
    Alexandria , Egypt
    7,943Coins
    @Avenga76 ... fantastic job buddy :thumbs
    And since that a screw came into usage with most of us doesn't have such resources ...
    How about making us some useful accessories like :
    A slotted coupling for the feedback pot with the motor , or maybe a universal varable ratio reduction gears that can be used with it ;) .
    I guess the market place will be a good start here for that and I can help in the design :thumbs.
    IMHO ... an engraved SimTools logo on each part would be a fair enough good start .
  8. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    331Coins
    I got the fans installed on my rig today. They really add to the immersion. I have only tried them in Iracing yet, but it feels pretty good and it makes the VR experience more intense. I will try to get AC/PCARS/Dirt Rally working tommorow.
    No Limits 2 is also pretty cool
    The biggest challenge was taking in account that my rig is not permanent. Still need to some rewiring en find the perfect distance between the 2 fans.
    I was thinking about spray painting the fans black, but without the stickers they also look really nice in white.
    I have some issues with my 3d printer, but as soon as i have worked that out, i will be printing fan ducs and Richards Adruino box.
    • Like Like x 5
  9. sberns
    sberns Member Gold Contributor
    432Coins
    3DOF, SCN5, Arduino
    Amazing work Richard and thanks for sharing! I will definitely be printing one of your boxes for this project. If I'm not using ductwork, do you think fan grills are necessary?
    I'm planning on using an ATX power supply (430W, single 12V rail with 34A max) I already own as my power supply for the 6A fans. Can I just use one of the ground+yellow +12V wires from one of the connectors (to power the 2 fans) or must I join all of the 12V wires together and grab the feed off the group instead?
  10. Avenga76
    Network Engineer
    3,261Coins
    The fan grills do make a difference even without ducts.
    I brought an anemometer and I have done some tests and I see about a 40-50% increase in wind speed at 600mm.
    I will do a video about it later in the week
  11. HoiHman
    Mechanic
    The Netherlands
    331Coins
    Looking forward to that video richard. How high do we need to print the fan grills to make a difference ?
    I got AC & Iracing working, but Dirt Rally doesn't do anything. Could be that i read somewhere that DR is not supported in my region??
    I also have a question about Pcars. Simtools tells me to disable MMS in the game why i patch it. What setting is MMS and is the game with MMS still compatible with SC4 which i need for my accuforce.
  12. stevemontuno
    stevemontuno Active Member
    1,461Coins
    @HoiHman Dirt Rally has a Problem with the Outgauge Proxy Server so running multiple telemetry based devices is not easy,,,
    There is a work around that you can do to fix this issue though,,,
    http://www.eksimracing.com/cmps/
  13. HoiHman
    Mechanic
    The Netherlands
    331Coins
    Thanks a lot Steve, i will give that a try.
  14. Avenga76
    Network Engineer
    3,261Coins
    I see a benefit from even the 1/4 height air straightener.
    With Project Cars, make sure you are using the standard plugin, no the UDP alternate plugin. The normal plugin uses the same shared memory setting that SimCommander uses.
    With Codemaster games, Sim Commander supports UDP forwarding so you can just use that to forward the UDP to SimTools (Port 4123)
    With Dirt Rally specifically they have allowed you to do multiple UDP outputs directly from the game.
    So you could just do
    <udp enabled="true" ip="127.0.0.1" port="10001" delay="0" extradata="3" />
    <udp enabled="true" ip="127.0.0.1" port="4123" delay="0" extradata="3" />
    • Informative Informative x 3
  15. sberns
    432Coins
    3DOF, SCN5, Arduino
    Thanks quite a difference!! I didn't think it would be so significant. That said, I am terrible at 3D modelling. Any chance you would be willing to share the file for the honeycomb grill? It would be amazing to be able to print them to use on the seaflo fans. Your rig is very inspiring!
  16. Avenga76
    Network Engineer
    3,261Coins
    Yeah, it my first quick tests I see about 20-23KPH winds just with the fans and 27-30KPH with the air straighteners on. It is a more focused beam of air so it projects further. The downside it you need to angle them correctly because the jet of air is narrower.
    Just like this
    I have attached the STL with and without the mounting bracket
  17. sberns
    432Coins
    3DOF, SCN5, Arduino
    Thank you very much!! Very generous of you! My order is coming from China and is not expected until the end of October but I'll try and post some pics when it's done.
  18. noorbeast
    152,445Coins
    +11,078 / 56 / -2
  19. HoiHman
    Mechanic
    The Netherlands
    331Coins
    Thanks, i will give it a try tonight hug:
    I just designed a air-straightner yesterday myself which is a lot shorter because i do not have a lot of room. It will mount over the outlet of the motor and only be 50mm tall . It's being printed as we speak, but my printer isn't that fast so i still have to wait another 5 hours for it to finish.
    Looking at the pictures above you have mounted the motors in a box, how big is the difference in sound (coilwhine)
  20. Avenga76
    Network Engineer
    3,261Coins
    You can just print mine at half height.
    In Cura or what what ever slicer you use just set the Z scale to 0.5, leave the X and Y at 1.0 and it will be fine. That is how I did my 25mm high ones, just set the Z scale to 0.25
    Those pictures aren't mine, just an example of the affect of airflow straighteners I found on the net
