Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. noorbeast
    153,884Coins
    +11,154 / 57 / -2
    If you can do an update post to your build thread I will happily donate the coins you need. The initial post had your sim running with Xsim but members are yet to see it run with SimTools: https://www.xsimulator.net/community/threads/moaale-2dof-simulator.8705/
  2. vthinsel
    vthinsel Well-Known Member
    FRANCE
    6,056Coins
    Arduino, 4DOF
    As I feel UDP is about to arrive on PS4 (It arrived on F1 2016), I'm currenty working on a DiRT UDP plugin, following the model I used for Project Cars.
    It looks like everything sent is 4 bytes float, and I was able to figure-out some interesting values but I'm a bit lost when it comes to heave/sway/surge yaw/pitch/roll
    From the specs I found on the net there are 3 values for roll, 3 values for pitch , no explicit yaw/pitch/roll......
    Check the middle of the thread in https://steamcommunity.com/app/310560/discussions/0/481115363869500839/
    I made a UDP capture and was able to get some values, which look coherent. See the attached excel file which reflects the spec above. I can also attach the UDP data and UDP playback tool I used
    Could someone help me to figure-out how to get the values needed for our beloved SimTools ? I'm hopeless in math :p
    I also have the feeling this plugin would fit other codemasters titles as their UDP structure seems to be shared among their games..... killing many birds with one stone then.
  3. Nick Moxley
    Might want to wait for V2 to be released, I know from reading some of the comments in the Private beta, Plugin making will be a LOT more streamlined with V2.
    As for the exact details, Im not sure, you'll have to check in the V2 thread thats open for the public and see whats been discussed.
  4. vthinsel
    FRANCE
    6,056Coins
    Arduino, 4DOF
    Thanks for the info. I'm not currently at the plugin coding portion, just trying to get relevant data using a standalone VB app. I know v2 will be amazing :)
    But I need good data to feed the new amazing plugin :p
  5. Guilherme Bastian
    Guilherme Bastian New Member
    Brazil
    151Coins
    Is anyone getting speed info on game dash? I also tried to add the line
    <udp enabled="true" delay="1" port="4123" ip="127.0.0.1" extradata="3"/>
    <udp enabled="true" delay="1" port="20777" ip="127.0.0.1" extradata="1"/>
    But nothing seens to work. I patched the game correctly and my gamedash works with other tittles like Assetto Corsa, Project Cars and No Limits 2. Any idea? Tks!
  6. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
  7. Aloha21x
    Aloha21x New Member
    112Coins
    Bonjour, je vous écris car malgré de nombreux essais, je ne trouve pas de solution au problème que je rencontre :
    Lors de spéciale sur DirtRally et de manière aléatoire, les effets surge, sway et heave ne sont plus transmis à simtools. Seuls les effets roll et pitch fonctionnent continuellement.
    Le phénomène est visible en ouvrant le tunning center, les 3 valeurs restent à 0 sur telle ou telle portion de telle ou telle spéciale.
    J'ai bien trouvé quelques manipulations sur ce fil:
    - remplacer une ligne dans les fichiers "hardware setting info/config"
    - dépatcher/repatcher le jeu
    - supprimer les deux fichiers cités, relancer le jeu, repatcher
    - essayer le plugin alternatif (qui lui fige les valeurs "déconnantes" à la valeur "à l'entrée du bug" genre, je suis à 2 en surge lorsque ca se met à buguer, 2 sera maintenu jusqu'à la fin (au lieu de 0))
    Mais rien n'y fait, je ne parviens pas à faire fonctionner le jeu correctement!
    please help! :)
    Hello, I am writing because despite many tests, I can not find a solution to the problem I have:
    When special on DirtRally and randomly, the effects surge, sway and heave are no longer transmitted to simtools. Only the roll and pitch effects operate continuously.
    The phenomenon is visible by opening the tuning center, the 3 values remain at 0 on a particular portion of a given special.
    I have found some manipulations on this thread:
    - Replace a line in the files "setting hardware info / config"
    - Unpatch / re-patch the game
    - Remove the two mentioned files, restart the game, re-patch
    - Try the alternative plugin (which freezes him values "buged" to the value "at the entrance of the bug" type, I'm 2 surge when AC starts bugue 2 will be maintained until the end (the instead of 0))
    But nothing, I can not run the game properly!
    please help! :)
  8. Trafalgar
    Trafalgar New Member SimAxe Beta Tester Gold Contributor
    13Coins
    @Aloha21x, with you we are three people who have the same problem. I still have not found a solution, my problem occurred after the 1.2 update. Just for information, are you on windows 10 and are you playing steam?
  9. Aloha21x
    Aloha21x New Member
    112Coins
    I use steam and i have two operating systems, win 7 and win 10. I have the problem with both .
    Special only do not work. rallycross works
  10. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    I also am having the unusable Heave, Sway and Surge problem. I just have them not transmitting to the sim, makes for a very random violent ride when they are enabled lol.
  11. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    What are your values in the tuning center for max min on those motions?
  12. Brett Horton
    Tampa FL
    118Coins
    I am not around the sim currently, but regardless of the values, the input is so erratic, it is not usable. They all stall at 0, then jump from min and max 100% very violently, in virtual tuning, the sliders are a blur.
  13. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    its not regardless, its important. Post your values when you get a chance.
  14. Brett Horton
    Tampa FL
    118Coins
    rgr, I will when I get home today.
    Thanks!
  15. Brett Horton
    Tampa FL
    118Coins
    here is what it is currently. I have heave, sway, surge off from output though Dirt 5.jpg
  16. Brett Horton
    Tampa FL
    118Coins
    Any thoughts guys?
    153,884Coins
    +11,154 / 57 / -2
  18. Brett Horton
    Tampa FL
    118Coins
    Yes I have, will post all screen shots later today thanks guys
  19. Brett Horton
    Tampa FL
    118Coins
    here are all my settings in Dirt...
    Left and right motors are identical in the JRK Utility.
  20. aceinthesky
    aceinthesky Member Gold Contributor
    Pearland, TX
    387Coins
    I got everything working with this patch except for surge.I was able to use extra 1 and got the sway working with that but the surge does not work. Sway seems to work erratically at the beginning and in certain sections of the track and then just stops. Really frustrating because the effects that work are awesome. I tried all the fixes in this thread, including the modified patch and still nothing.
    ...quick update, after of lots of trial and error I got it consistently working by removing the patch and then reinstalling it. Then I start the game, go to graphic options and then video options. Under that I change the resolution and refresh rate to the highest my tv will allow and make sure full screen is checked. I read about a windowed mode bug on this thread and lead me to this. I'm on an oculus rift and still have to do this with the screen resolution. I'm running 8 buttkickers with sim commander, 4 in chassis, 1 in set,1 in pedals, 1 in wheel, 1 in shifter. I can not get the motion to work with simvibe. As soon a I turn on simvibe the motion does not work anymore. This game would have been the ultimate inversion for fun, but I guess I'll stick to assetto corsa, since that works perfectly.
