value1
rFactor2 Plugin 2.0.4.0
SimTools game plugin for rFactor2
  1. noorbeast
    152,977Coins
    +11,115 / 56 / -2
  2. Edson Lourenço Bezerra
    Edson Lourenço Bezerra Edson Bezerra - Desenvolvedor Open Source
    Analista de Sistema
    Jundiaí
    147Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 4DOF
    What is the operating system, this running both applications as an administrator?
    • Dislike Dislike x 1
  3. Matthias Griese
    Matthias Griese New Member Gold Contributor
    - 12Coins
    Thanks! Works perfect after Tuning Center!
  4. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Hi drivers,
    rFactor2 (Steam version) last build 1052 not work with SimTools and rFactor2 plugin!
    I have purchased the game last night and installed it, then I patched with rFactor2 Plugin 3.0.6.0 but in game there is no movement...
    When I run the game in SimTools Game Manager the "Connected" button change color from green to blue... but equally the movement is absent! :(
    Some possible solutions?
  5. Historiker
    9,214Coins
    DK, please read this entire thread as I believe this issues has been addressed a few times before. Also follow all suggestions listed.
  6. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Rfctor2 (Steam version) build 1052 works well.
    I checked it now.
  7. Doctor Kruntz
    400Coins
    3DOF, SCN6
    Sorry... I did not have read the entire thread. Now I have solved.
    Yes, RFactor 2 (Steam version) build 1052 work very well :grin
  8. Dave Nichols
    Dave Nichols New Member Gold Contributor
    205Coins
    When I try install the rFactor2 plugin I get "(rFactor2_Plugin.zip) Not a valid Sim Tools file! - Skipping Installation". What am I doing wrong? (I've installed other plugins with no probelm - pCars, iRacing, Assetto...).
  9. Dave Nichols
    205Coins
    Ignore me, I'm being stupid, sorry for the noise...
  10. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
    I just installed rFactor 2 steam. I hope you can patch the game with the latest version of the plugin
  11. piorck
    piorck Member
    french
    258Coins
    hello , i'll don't found the folder to give the plugin
    all the folder i'll make : "game did not patch" or "the selected path is not valid for patching"
    i'll try to make in C/program files X86/rfacor 2 that's right ?
  12. Doctor Kruntz
    400Coins
    3DOF, SCN6
    Hello piorck... the exact path for the rFactor2 plugin folder is: (your hard disk)/... /SteamLibrary/common/rFactor2/Bin64 (or Bin32)/Plugins... in this folder you'll find "SimTools_rFactor2_x64.dll" plugin (or SimTools_rFactor2_x32.dll) :thumbs
  13. value1
    14,175Coins
  14. value1
    14,175Coins
    I updated the patching procedure for the Steam version of rFactor2.
    You now shall select [your drive:]…\Steam\SteamApps\common\rFactor 2.
  15. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
    I need help, I have the Steam version of rFactor2 and the rFactor2_Dedicated.exe crash me if I have the plugin SimTools_rFactor2_x64.dll or SimTools_rFactor2.dll in ... / SteamLibrary / common / rFactor2 / bin64 (or bin32) / Plugins ...
    I just patch the latest version v3.0.6.1 rFactor2_plunig but also with earlier versions crash dedicated server.
    If I delete SimTools_rFactor2_x64.dll or SimTools_rFactor2.dll in ... / SteamLibrary / common / rFactor2 / bin64 (or bin32) / Plugins ... dedicated server works well.
    Is there a solution?
  16. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
  17. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
    Works without plugin:
  18. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
    Nobody has this problem ?.
  19. Chumet1
    Chumet1 Member
    - 2Coins
    2DOF, JRK
    Someone I can confirm that the rFactor2 dedicated server works properly with the patch simtools?
  20. piorck
    piorck Member
    french
    258Coins
    my rf2 version is not a steamversion.
    the steam folder didn't have rfactor folder
