  1. Nick Moxley
    17,056Coins
    I also painted war Hammer stuff Back in the day. Ah the good ol days spending hours and Hours under a magnifying glass.
  2. HoiHman
    HoiHman Active Member
    Mechanic
    The Netherlands
    331Coins
    I made an inquiry at seaflow about running the fans at 13.8v and got a reply that " 13.8v will work just fine." So "overclocking" the fans should be pretty safe since the manufacturer claims there should be no problems.
  3. Avenga76
    Avenga76 Well-Known Member
    Network Engineer
    Auckland, New Zealand
    3,261Coins
    The blowers are totally fine to run at 13.8V. On boat or a car your alternator will put out 13.8V to charge the batteries, that is why my rig runs at 13.8V so it can charge my batteries.
    My concern wasn't with the blowers or the MM, they can both easily run at 13.8V. My concern was more with the PSU's, they have a little pots that controls the voltage regulator and I just didn't want anyone damaging that pot or the PSU trying to overclock.
  4. HoiHman
    Mechanic
    The Netherlands
    331Coins
    The PSU seems to be handling the 13.8 voltage pretty good sofar.
    I do have an issue with PCARS and the windsimulator, i hope somebody can help me out
    In practice mode the windsimulator works fine, but as soon as i start a career or single player race it doesn't work at all.
    Simdash shows an error in " session state " : Invalid
  5. norbs
    norbs New Member
    NSW South Coast
    20Coins
    Hi everyone.
    Loving the wind simulator, and thought I would set one up.
    However, it wont be for my sim rig, it will be for my cycling indoor trainer.
    As you can see i have a 30cm fan on the floor which just isnt up to the job. (I cant actually add a link yet because i am a new member)
    I have grabbed 2 Aquatrack 270cfm inline fans and some ducting so i can have them mounted away from the trainer as they are super noisy.
    My question for you blokes is this. Because the software i use on the bike doesnt have shared memory or API or whatever, I need another way to control the fans. Some sort of Arduino sensor maybe. I am not sure at this point. I would like to be able to have the fans react to the speed of the bike in game. (the software is Zwift)
    I do already have an ANT+ USb sensor on the PC that talks to the trainer, and bike to pick up power, cadence and heart rate. But I have no idea how to link that to the Arduino, so just thought an Arduino sensor of some sort would be the go.
    Any suggestions greatly appreciated and I really hope this isnt too off topic.
    Thanks in advance.
  6. Guilherme Bastian
    Guilherme Bastian New Member
    Brazil
    151Coins
    Hi Guys,
    Does anyone have the Math code for Assettor Corsa and Dirt Rally or could explain me the logic behind it so I can try to find out how to make it work? I tried the settings from the first page with AC and it didnt work... tks!
  7. manzes82
    manzes82 New Member Gold Contributor
    - 91Coins
    it really depends on what blowers you are using.
    I am using strong blowers and i have set it to
    MATH * 0,5
    ROUND 0
    PAD 3 0
    and its enough. I am using the Seaflo 4" blowers.
    With the code from the first posting its really important not to get more output then 255. More couldnt be handlet by the arduino.
    So when you use MATH *1 you´re speed is the same as the output and when you´re driving over 255 kilometers/h, the blowers wont work anymore.
  8. SilentChill
    20,590Coins
    I need to update the original code with the fix for over 255, been kinda busy but I will get round to it
  9. Guilherme Bastian
    Brazil
    151Coins
    Tks Craig, but I tried the code from first page and the settings you told me with Dirt and the blowers start to spin while in the menu. I did not changed the output.... Im using 4, 4 SEAFLO blowers by the way.
  10. Guilherme Bastian
    Brazil
    151Coins
    Guys, here are my settings. No matter code (code from first page or code from page 4) the blowers starts at full speed and will never decrease until I upload another code. Any idea? tks
  11. Avenga76
    Network Engineer
    3,261Coins
    For starters you probably don't need to Math * 5 for Dirt Rally because it should already be in KPH.
    Can you post your com port settings?
  12. Guilherme Bastian
    Brazil
    151Coins
    Hi Richard, I also tried to remove the math line. Here are my com port settings.
  13. Guilherme Bastian
    Brazil
    151Coins
  14. Avenga76
    Network Engineer
    3,261Coins
    Yup. I figured that would be the problem. I had someone else do the same thing.
    You have it set up in the wrong place, that section is for motion. You want to set it up under the game dash screen
    Delete those com port settings
    Right click the GameDash icon on the task bar then go to settings.
  15. Guilherme Bastian
    Brazil
    151Coins
  16. HoiHman
    Mechanic
    The Netherlands
    331Coins
    Finally i have found the cause of why PCARS wasn't working for me:
    Somehow you need to have a race that has at least 9 laps in order to have "simwind" working in Pcars
    https://www.xsimulator.net/community/threads/project-cars-plugin.4780/page-11#post-117264
    The seaflows fans are great, but they are noisy as hell and when driving tin tops the high windspeeds feel unrealistic. Still i needed some cooling for racing in VR. So i added 3 casefans with airstraightners to my rig, which are also speedbased. With the switches on my dashboard i can turn the seaflow on or off. Which is also very handy if you pause the game and they keep running at full speed.
    [​IMG]heberger image
    Now i can drive at night while the family sleeps and still have some decent cooling.
  17. Avenga76
    Network Engineer
    3,261Coins
    Can you post all your settings so I can double check them?
  18. HoiHman
    Mechanic
    The Netherlands
    331Coins
    I never could get Dirt Rally to work either.
    I did some further testing and I have narrowed the window down in which simdash works in PCARS race session
    It's 9 - 13 laps
    If you start a race with more or less laps, simdash will see the Session State as INVALID
  19. HoiHman
    Mechanic
    The Netherlands
    331Coins
    Somethimes the arduino get bugged. Whenever you have speed output in simdash, but the fans aren't working, try resetting the arduino first
    Thanks for confirming that
  20. vanty200419
    vanty200419 New Member
    Việt Nam
    195Coins
    DC motor, Arduino, Joyrider, SimforceGT
    Very Good... Thank you
    • Dislike Dislike x 1
