  1. Grigory
    Grigory Active Member Gold Contributor
    Moscow
    224Coins
    3DOF, 6DOF
    I believe at least two reads will be required. My feeling is that something (transistor gate at analog input?) needs time to properly charge and sending multiple reads provides this time.
    Here it is: SMC3 with MODE 4 added to support Sabertooth packet serial (I marked my changes with "//GB:" - "//:GB" tags) and regular unmodified Sabertooth library.
  2. outrunner
    outrunner Run to get the race leader flag!
    father mother
    639Coins
  3. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,443Coins
    Nice work, the Sabretooth drivers seem to be growing in popularity.
  4. outrunner
    father mother
    639Coins
    @RufusDufus,
    could you please confirm that the input declarations I posted at #1057 could be used for a 2DOF setup? The goal is to simplify the connection between arduino and MM via piggybacking of the two
    thanx!
  5. RufusDufus
    Adelaide Australia
    16,443Coins
    @outrunner, I don't think it will be as straight forward as that. I had to bypass standard arduino libraries in a number of places and changing pins may affect other timers and things - it's been a while since I looked closely at the code though.
    You're welcome to give it a try though - it will either work or it won't.
    EDIT: To answer your question in post 1057 why it wasn't written to work as piggy back - simply because the MM wasn't the first driver it was developed for so it was just configured to use the pins already setup for other drivers. :)
  6. outrunner
    father mother
    639Coins
    That makes sense now ;)
  7. luky_90
    luky_90 Member
    276Coins
    hello guys, I put those two videos made smc3utility, I would like to know from you what would you change these settings or if all goes well.
  8. Meawto
    Meawto Sorry for bad English ;'(
    Thailand
    - 336Coins
    i has replace my potentiometers with new hall effect pot. and i have some problem to make it reverse. i have change the motor wire (from monster shield to motor) but it still move incorrectly, did it can change some code for make it reverse ? @RufusDufus
  9. bruce stephen
    general contractor
    michigan
    9,115Coins
    @Meawto Swap pos and neg at the motor.
  10. RufusDufus
    Adelaide Australia
    16,443Coins
    @luky_90 increase the PWMmax as far as you can until green line follows blue line as close as possible... as long as motor and driver can handle without overheating.
  11. Meawto
    Thailand
    - 336Coins
    which wire i should swap ? i've swaped + ,- from monster shield to motor but not the wire from PSU but it's not working, this is corect ?
  12. SeatTime
    What you have done is so far correct and it should have changed the direction of the motor. Don't! swap the PSU connections to the Monster shield. Do you have 5V and ground going to the right pins on the hall effect pot, it won't work if they are incorrect?
  13. Meawto
    Thailand
    - 336Coins
    i have change my new UNO and its work now.thanks for imformation :)
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
  15. Meawto
    Thailand
    - 336Coins
    i dont know what its happen but when i change to hall effect it has many problem.
  16. Meawto
    Thailand
    - 336Coins
    i cant find how to use SMC3 Utility to monitor with 2nd PC. any guys has link to it ?? :)
  17. George Dobransky
    Hungary
    - 43Coins
    Hi All!
    Can anybody send me the correct Simtools interface setup for the current version of smc3?
    Or any link where I can download the presets for simtools?
    Thanx,
    George
  18. bruce stephen
    general contractor
    michigan
    9,115Coins
    Simtools Setup
    Setup for Simtools is very straight forward:
    [A<Axis1>][B<Axis2>][C<Axis3>]
    Set for 10bit binary output
  19. George Dobransky
    Hungary
    - 43Coins
    Bruce,
    Thanx for the answer. Like this?:
    Do I need Startup/Shutdown Output?
    Thanx for answer,
    George
  20. bruce stephen
    general contractor
    michigan
    9,115Coins
    That looks correct to me. As long as you have the proper com port it should be good.:thumbs
