Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. skae87
    skae87 New Member
    - 40Coins
    Hi guys.
    I used to play nolimits v2 no problem some months ago, but today i had to unpatch the game and repatch it cause it was not working, and it still does not work. The game manager is in "blue color" so the game is "running" but there is no motion. This game is launched through stema...and i think i remember i had to type some comand on the game properties in steam in the "set up launch" options... but i cannot remember it...and also i am not sure i had to type something or not to have telemetry ouptut...
    i am using Assetto corsa no problem via steam with simtools
  2. Nick Moxley
    Check the Tuning center Values. If they are 1000+ or higher, theres good reason your not feeling anything.
  3. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
  4. skae87
    skae87 New Member
    - 40Coins
    Thanks guys! i'll check it out ASAP
  5. dovasz81
    dovasz81 New Member
    240Coins
    2DOF, 3DOF, DC motor, AC motor, Joyrider, Motion platform, 4DOF
    I tired to install the SimTools v1.3 on a win10 but it's not working properly. I.e. when I click on the Interface tab I got an error msg and it's not loading as it expected.
    Other question, where I can download the communication protocol between the SimTools and my sim controller cos I want to build a custom one.
    Can someone also explain me how SimTools works? Am I understood well that after patching a game (which doesn`t have the UDP, or outsim feature originally) it will has the UDP available and the SimTools using that after all?
    Thanks.
    Zsolt
    153,770Coins
    +11,150 / 57 / -2
  7. BlazinH
    16,689Coins
    I don't know what your windows 10 issue is but in short Simtools extracts telemetry via UDP, memory mapping, custom dlls, etc. from games, scales the telemetry to your needs, and then outputs the data as you need using either UDP or serial.
  8. dovasz81
    dovasz81 New Member
    240Coins
    I've read all docs and followed the installation guide but when the SW was installed it wasn't working as described. Error windows popping up and the interface settings tab isn't loading at all.
    153,770Coins
    +11,150 / 57 / -2
    Please post screenshots of error messages.
    Just checking the basics, is .NET installed and have you done a clean re-install of SimTools?
  10. dovasz81
    dovasz81 New Member
    240Coins
    The error msg title is Microsoft dotNET framework and it says:
    An unhandled exceptance has happaned. If you press on continue the application will ignore the error and try to continue to run. With the cancel you can close the app instantly. For all the softwarechannel-addresses usually only one method (protocol, network address, port) is enabled.
    I hope I translated well. After it lists all the exceptions.
    I'm using the newest dotNET (just installed the Visual Studio).
    If I click on continue and try to go on the Interface Settings tab, it's dropping the same error msg than seemingly closing the app, apparently minimize it even before I could read the error msg fully.
    I hope u can help, I have reinstalled 2 times, did,'t helped.
  11. lilted86
    lilted86 Member
    Malaysia
    489Coins
    are any development done for simtool to support buttkicker?
  12. Blame73
    Blame73 Well-Known Member
    8,314Coins
  13. noorbeast
    153,770Coins
    +11,150 / 57 / -2
    SimTools 2.0 is about to enter Release Candidate status. Once released @yobuddy will concentrate on Game Vibe for transducer support.
  14. lilted86
    lilted86 Member
    Malaysia
    489Coins
    awesome!..keep up the good work..cant wait no more!
  15. lilted86
    lilted86 Member
    Malaysia
    489Coins
  16. djritzzo
    djritzzo New Member
    bilbao
    36Coins
    2DOF, 3DOF, SCN5, Arduino
    where can I download simtools 2.0
  17. Blame73
    8,314Coins
    It's going to be released soon, not yet available
  18. djritzzo
    djritzzo New Member
    bilbao
    36Coins
    Will work sim tools 2 on windows 10
  19. value1
    14,237Coins
    It might only work with
    o_O
    • Funny Funny x 3
    153,770Coins
    +11,150 / 57 / -2
    Yes.
