I started My First 2dof
Discussion in 'DIY Motion Simulator Projects' started by Claudio Bello, Aug 16, 2016.
  1. Claudio Bello
    Claudio Bello Member
    Brasil
    273Coins
    thank you
  2. Claudio Bello
    Brasil
    273Coins
    thank you
  3. Claudio Bello
    Brasil
    273Coins
    I started the simulator now wanted to know why you guys how to roll effect roll not getting it seems that not accepting this ... however the pitch works without problem ...
    152,009Coins
    +11,061 / 56 / -2
    You need to post pictures your Axis Assignment interface settings.
    As an aside that pot does not appear to be securely mounted.
  5. Claudio Bello
    Brasil
    273Coins
    on the pot it was just to test my cnfiguraçoes ....
      912.8 KB
      821
    152,009Coins
    +11,061 / 56 / -2
    You should have one DIR box checked orange for roll, as the DIR boxes determine which way an axis moves, and movement should follow this proforma: https://www.xsimulator.net/community/faq/which-way-to-set-simtool-axis-movements.230/
    In SimTools 1.3 you should aim to keep the total of all axis allocations at around 100%: https://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    Once you get the basic configured properly it still takes some time to develop and refine motion profiles for each game: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  7. Claudio Bello
    Brasil
    273Coins
    thank you
  8. Thomas T.
    Thomas T. Impact
    Seller
    Austria
    134Coins
    Very Nice Job,
    I´ll do this in the next 3-4 Months.
    WATCH THREAD
  9. Claudio Bello
    Brasil
    273Coins
    thank you
  10. SeatTime
    My 2cents - Your motor drivers will need heatsinks and fans + airflow..
  11. Claudio Bello
    Brasil
    273Coins
    [QUOTE = "SeatTime, post: 117830, membro: 9228"] Meus 2cents - Os controladores de motor terá dissipadores e ventiladores + fluxo de ar .. [/ QUOTE]
    I did the test and it did not heat up when I put the cockpit on top and start the movements and get warmed up because of the weight I'm going to put the coolers on
  12. Claudio Bello
    Brasil
    273Coins
    Good night ... Someone could help me ... My simulator when I connect 2 motors is giving a few strides, when I turn off 1 normal operation will be that it can be arduino programming, I am using linear potentiometer of 10k a source of 24v 500w the motors consume Each 46w 24v
  13. Claudio Bello
    Brasil
    273Coins
    152,009Coins
    +11,061 / 56 / -2
    I am not sure what you mean by this, can you explain a bit more what the issue is?
  15. Claudio Bello
    Brasil
    273Coins
    When I am using the two motors they are ocilando ... when I turn off 1 motor it works norm without ocilar
  16. Claudio Bello
    Brasil
    273Coins
    [QUOTE = "Claudio Bello, post: 129496, member: 22598"] Quando estou usando os dois motores estão ocilando ... quando desligo 1 motor funciona normal sem ocilar [/ QUOTE]
    I'm reading here in the forum about a pid command what's this?
  17. Claudio Bello
    Brasil
    273Coins
    I have to configure the engines in this program Windows SMC3 Setup
  18. noorbeast
    152,009Coins
    +11,061 / 56 / -2
    A proportional–integral–derivative controller (PID controller) is a control loop feedback mechanism (controller): https://en.wikipedia.org/wiki/PID_controller
    Here is an analogous explanation of PID: http://www.xsimulator.net/community/threads/a-laymans-analogy-guide-to-pids.7649/
    And yes you use the SMC3 app to configure your settings.
  19. Claudio Bello
    Brasil
    273Coins
    How do I get a free 2.1 license key ... thank you.
    152,009Coins
    +11,061 / 56 / -2
