Tutorial SPS - Sabertooth Packet Serial PID motor driver sketch w/SoftStart
Discussion in 'SimTools compatible interfaces' started by BlazinH, Nov 10, 2016.
  1. SilentChill
    20,591Coins
    The settings are exactly as they are above for simtools I didn't need to change anything from before.
    In SMC3 I have the settings low but like I say it works perfectly using the SMC3 utility no jerking nice and smooth.
    Soon as I try to test using simtools it's terrible.
    Can't upload pics as I'm out at the mo. I will do a video after when I get home, shouldn't be too long
  2. Pit
    30,490Coins
    I did the same experience first when beta testing, while SMC3 was working flawlessly I had troubles to get SimTools working. Anyway you are an experienced user ntl there could be something wrong though ;)
  3. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,254Coins
    Unless there is something specific about the sabretooth version it should be OK. I've always used 1ms on my standard SMC3 on UNO.
    You could try using SMC3Utils in UDP passthrough mode to search for problems. It will display a light blue line showing what it receives from simtools and a dark blue line showing the returned value from the arduino (or the other way round?). It might help tell you where the error is introduced?
  4. Pit
    30,490Coins
    BTW I assume it's a baud issue.
  5. SilentChill
    20,591Coins
    Yes need to set that up in UDP ...... never had to use it before how do I do it @RufusDufus is it in the SMC3 thread ??
  6. Pit
    30,490Coins
    Also tested and failed. I got a lot of communication errors between UNO and Sabertooth resulting in jerky movements.
  7. SilentChill
    20,591Coins
    I changed the rate 112500 in describe for each sabertooth
  8. Pit
    30,490Coins
    And SimTools?
  9. RufusDufus
    Adelaide Australia
    16,254Coins
    OK, that's interesting. I'll have a quick look at the sabretooth code and see if there is anything I can find otherwise I can't offer any other advice at the moment.
  10. SilentChill
    20,591Coins
    Here some screenies
    These are the same for all 3 Sabertooths and UNO's
  11. Pit
    30,490Coins
    ok, try to set the Sabertooth to BAUD 38400 for testing purposes (Describe)
  12. BlazinH
    16,665Coins
    Sorry to hear your are having issues. I see serial timeout in DEscribe says 0. That screen shot is after running the sketch and download the settings again correct? My plan was to have only one sketch for both sabertooths but in may be necessary to make two, one for the 2x60 and one for the 2x32. The problem may be because the 2x32 is a V3 sabertooth and the 2x60 is V2. After @Pit couldn't get the sketch to work on his 2x32 after I got it working on my 2x60, I had to call DE support to confirm that V3 is not 100% compatible with V2 commands. That's why you must use DEscribe on the 2x32 to set its baud. I forgot to check if the serial timeout was also working or not though and from your screen shot it isn't. That shouldn't be causing your issues but maybe the code for the 2x60 is screwing with the 2x32. I assumed the 2x32 would just discard the V2 commands but maybe its causing the problem.:confused: But again, I don't have a 2x32 myself to test with.
    Shortly I will be sending you a striped down sketch that @Pit has had success with to try to see if that makes a difference since he said my posted sketch is not working for him now either.
  13. BlazinH
    16,665Coins
    Good idea to try this too. Don't forget to change the baud to 38400 in the sketch to though.
  14. SilentChill
    20,591Coins
    What should I set serial timeout to ?
    WIll try this now
  15. Pit
    30,490Coins
    Right, I forgot to mention it. Thanks @BlazinH
  16. BlazinH
    16,665Coins
    Its fastest setting, 100ms.
  17. Pit
    30,490Coins
  18. SilentChill
    20,591Coins
    change it where ??
  19. SilentChill
    20,591Coins
    I changed it uploaded it and it goes blank again ?
  20. Pit
    30,490Coins
    same here
