M4 Motion Theatre given new life Kangaroo2 and Sabertooth
Discussion in 'DIY Motion Simulator Projects' started by Baalsgate, Aug 31, 2016.
  1. Baalsgate
    Baalsgate New Member
    Melbourne Australia
    517Coins
    2DOF, DC motor, Motion platform
    153,740Coins
    Is it the steam or standalone version? It does need to be the full version, not a trial.
    If you have done so make sure you run the game before patching.
    You can also try unpatching then restart as admin and repatch NL2.
  3. BlazinH
    16,689Coins
    Its there but delay is not listed in the commands list but in an example.
    Please let us know if this helped your situation or not.
  4. Allan Scherger
    Allan Scherger New Member
    21Coins
    Hi - do you have a picture or two of the exact way the pull down resistors were wired (or a drawing)? Thanks in advance, Allan
    "So with soldering iron in hand I added pull up 1k resistors to encoder inputs A , B and Z ( index ) , but no result , then tried pull down resistors as i think pull up is for an inverted signal , pull downs seem to clean up the RF a little while pull up seemed to make it worse. after scratching my head pulling apart both motors, moving cables , then finally decided there was to many unknowns in the existing cables so I will just put in new shielded cables to the encoders and bypass all the junction boxes and plugs I had spent hours testing see what happens.
    Seems Quadrature encoder inputs are very sensitive to RF noise , and after putting in new shielded cables it looks like the problem is now gone ( solved YAY ! )
    Now both encoders are getting clean data , theres a chance the teach tune may actually work , and it did :)
    And not to forget a big thanks to Dimension Engineering and their Help Desk for the fast responses and great suggestions that helped immensely with working out what was going on with the encoder problem, got to love it when you buy a product and can actually get some support, well done I recon."
  5. Baalsgate
    Melbourne Australia
    517Coins
    This is just an schematic i grabbed from the net but shows clearly the use of pull-up and pull-down resistors , I used 1K ohm .
    Also ground the cable shield on the cable to the encoder only one end prevents ground loops and reduces RF from motors.
    The encoder in the image has signals inverted and non inverted , the kangaroo worked with either but i used the non inverted set of signals.
    You can of course use both pull up and pull down, pull down means that the signal is grounded via a resistor of 1k to ground or negative , for a positive going signal that was all I needed.
  6. BlazinH
    16,689Coins
    Your rig must be working good now although you didn't confirm using a delay solved your last issue. Would be nice for others reading this thread to know.
  7. wannabeaflyer2
    london uk
    8,350Coins
    hi can you show a screen shot of your DESCRIBE teach tune setup example cliks per revolution , units of measure used etc I had to Fit Pull up resistors as well to get the encoders to perform at there best , but I failed trying to do teach tune with limit switches if I remember correctly ,problem with the homing switch activation ,,,, if I manually tripped each the homing switch 6 for each of the axises then the platform would work great but for me that part of the start up process was pain .. great to know you have sorted it ,,, the encoders need to do the homing at start up so that the system knows where it is .. I was close but @SeatTime's linear actuator design proved to be the game changer :)
  8. vanty200419
    vanty200419 New Member
    Việt Nam
    195Coins
    DC motor, Arduino, Joyrider, SimforceGT
  9. Baalsgate
    Melbourne Australia
    517Coins
    Err yea been a bit busy so havent had much time to play with it or finish it , no the delay didnt solve the problem .
    Currently working on problems with getting the video signal into the machine not really simtools related , I can either mount the PC in the machine which i would rather not do , or use screen mirror over wifi but that seems to lag quite a lot and is really useless at the moment , I am planning on trying a wifi AC network for it , with hope that the increased bandwidth will reduce the video lag to the screen.
    Also been fitting it out with a sound system and a removable table mount so we can have something to clamp the yoke or steering wheel too .
    I figured I would wait on the new version of simtools as that may solve some of the problems but its dissapointing i have to uninstall the previous version of simtools that is working fairly good and start configuring it again from scratch , I was even thinking perhaps leave my pc with the old simtools working and setup anther pc to test out the new version , just havent had time to play with it .
    cheers
  10. peter stolmeier
    peter stolmeier Member
    558Coins
    So, blowing the dust of this thread. I've got a line to TWO of these and have big plans if I can make it compatible with the modem motion control system. This has been a good guide so far.
  11. Angela hughes
    Angela hughes New Member
    22Coins
    I have an M4 motion theatre. How do I find out it's value
    153,740Coins
    Do you mean to sell it?
  13. Angela hughes
    22Coins
    Yes
    153,740Coins
    That is hard to say, as it really is a question of what a buyer will pay, and where in the world that is, often these old arcade rigs are sold via Ebay so perhaps do some research on previous listings there.
  15. Epsilon
    Epsilon New Member
    93Coins
    I just picked one up. The real answer to your question is what are you asking?
  16. Epsilon
    Epsilon New Member
    93Coins
    Do you Still have the console or the laser discs?
  17. Epsilon
    Epsilon New Member
    93Coins
    Did you pick them up? I need a hard drive or the files on them
  18. Epsilon
    Epsilon New Member
    93Coins
    Hey, I started a reddit community on the M-4 if anyone is interested. During my research, I came into contact with one of the Dev team members, if no THE guy behind it!
  19. Epsilon
    Epsilon New Member
    93Coins
    Don't know if anyone is still following, but I've been in regular contact with the owner and IP holder of the M4 who just passed on source code for the upgraded control programs to me along with a software release. I'll verify i can distribute it.
  20. mysimnet17
    mysimnet17 New Member
    australia
    210Coins
    problem with the M4 is its dangerous , gets stuck in the wrong position and then you cant open the door because of the frame , the balance on these machines is bad and the drum and cable for changing the angle is perhaps the worst type of design thought about changing it but we stopped working on it when xsim brought in stupid licencing.
