Obutto Revolution 2DOF + Traction Loss
Discussion in 'DIY Motion Simulator Projects' started by Brett Horton, Oct 25, 2016.
  1. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
  2. obobo
    obobo Active Member
    1,323Coins
    it looks good
  3. Brett Horton
    Tampa FL
    118Coins
    Handbreak installed and working....
    Now if I can get DIRT RALLY working in motion....
  4. Brett Horton
    Tampa FL
    118Coins
    First failure tonight after about 15 hours. Traction loss nuts came loose then snapped the M3 bolt. Will be going to an M4 (M3 all I had at the time) Tons of stress on traction loss.
    No damage, motor was just spinning while the pot and shaft sat there.
    151,528Coins
    +11,042 / 56 / -2
    Glad nothing got damaged.
    It goes to show just how significant the forces involved are, it always pays to over engineer.
  6. Nick Moxley
    17,056Coins
    Ah that inertia, Shes a tricky one. :p
  7. Brett Horton
    Tampa FL
    118Coins
    Little more PID tuning to tighten things up even more....
    Question, Are occasional Motor Driver Errors ok? Not in normal driving, but when hitting a wall of something violent like that. I have my PID's pretty good now, and only get errors when hitting walls or really big curbs.
  8. Nick Moxley
    17,056Coins
    ya its ok, but your on the edge remember. A few motor driven errors is ok, but the longer the duration of the crash might run that 1 too many error's and shut ya down.
  9. Brett Horton
    Tampa FL
    118Coins
  10. Brett Horton
    Tampa FL
    118Coins
    Finally got around to mounting my 4 point.
    Really does make a difference in immersion. I tend to lean forward when I drive as I get tense from traffic, so this helps hold me in place. Made a big difference in fidelity in my rig as it transfer more information to me!
  11. Juanjo1986
    Juanjo1986 Member
    Comerciante.. Copiloto Rally...
    Argentina
    489Coins
    A consultation .. the front support for the traction loss, you put it in front of the pedalboard? You might have four wheels, two behind the armchair and others ahead.
  12. Brett Horton
    Tampa FL
    118Coins
    I'm not following your question?
  13. That Dude There
    That Dude There Member
    USA
    430Coins
    Really nice setup. I would like to see your parts list, but it's gone as far as I can see. I was able to find your pivot bearing on a lucky google search on the first try though. :)
  14. Brett Horton
    Tampa FL
    118Coins
    Phew ! I'm tired, just did over eight hours today in VR on my motion sim running iRacing 24 hours of Lemans....
    Started 23rd, my stint is over but we got up to 6th.... Night time crew in the car now!
  15. Brett Horton
    Tampa FL
    118Coins
    Are there "Better" motors than the PGsaw-mill motors we typically use?
    Assuming sticking with the JRK's.
  16. noorbeast
    151,528Coins
    +11,042 / 56 / -2
    Better is always a relative term. What is it you want to be 'better', speed, reduce freeplay more torque or something else?
    The PGsaw motors are a pretty good fit for the JRKs.
    If you were looking for better efficiency the DIY linear actuators would likely be the way to go, but with Sabertooths rather than JRKs.
  17. Brett Horton
    Tampa FL
    118Coins
    Sorry, I mean basically when my currently motors go bad, a better replacement for these. I am happy with the performance overall. Just looking ahead for a higher quality motor when the time comes
  18. noorbeast
    151,528Coins
    +11,042 / 56 / -2
    The motors you have should last for years and years under normal use, with just routine maintenance like replacing brushes.
  19. Nick Moxley
    17,056Coins
    I have yet to need to replace the brushes,.....just recently did in my first set of rod ends........you got Many years of faultless use ahead of you Brett.
  20. Brett Horton
    Tampa FL
    118Coins
    Do you know of a source for brushes by chance?
