value1
Euro Truck Simulator 2 Plugin 2.0.2.2
SimTools game plugin for Euro Truck Simulator 2
  1. obobo
    obobo Active Member
    1,323Coins
    hi all
    I'm in the same situation as many people
    I installed ETS2 with steam
    In game manager: patched the game in D: \ steam \ steamapps \ common \ Euro Truck Simulator 2
    The 2 patches 32 and 64 bits are present
    Game manager goes blue at the launch of the game and marks well game running
    The game clearly indicates the call screen to the SDK
    But no data passes in tuning center, everything stays at zero.
    I re-read all this topic and tested everything indicated, but nothing works
    I really like this game, but I would like it to work with the simulator
    I have assetto corsa, LFS and dirt Rally that work with the simulator game engine.jpg game manager.jpg
  2. value1
    15,073Coins
    Is there a message like this in the Launch Pad when you start ETS2
    If not you have to check, if you patched the game correctly.
  3. obobo
    obobo Active Member
    1,323Coins
    Thank you for your answer, and as indicated above, I have this screen that appears when I run ETS2
    152,529Coins
    +11,085 / 56 / -2
    There is a known language bug that may be the culprit: https://www.xsimulator.net/community/threads/euro-truck-simulator-2-plugin.4758/page-6#post-117813
  5. obobo
    obobo Active Member
    1,323Coins
    i'll try tonight the system language change
  6. obobo
    obobo Active Member
    1,323Coins
    After having tested the language change of windows, deleted the patch
    Restart the PC and under game manager; Replacing the patch ...
    The simulator moves !!!!!!!:cheers
    The effects are completely bizarre at the moment but I think I still have adjustments to make
    I need to make an adjustment in the tuning center.
  7. Meawto
    Meawto Sorry for bad English ;'(
    Thailand
    - 336Coins
    please make this game dash work with simtools 2.0 :cheers
  8. value1
    15,073Coins
  9. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    621Coins
    2DOF, 3DOF
    Bonjour à tous
    Je prends juste la licence pour simtools v2 et je réinstalle tout, mais ETS2 ne fonctionne pas GameEngine et gamemanager est actif, mais dans les jeux version sans mouvement du jeu 1.21 quelqu'un pouvait me aider. Je vous remercie.
    bonjour à tous
    je viens de prendre la licence pour simtools v2 et je réinstalle tout mais ets2 ne fonctionne pas gameengine et gamemanager s'active mais dans le jeuxs aucun mouvement version du jeu 1.21 quelqu'un pourrait m'aider. merci.
  10. DE CASTRO
    Cahors France
    621Coins
    2DOF, 3DOF
    Hello everyone
    I just take the license for simtools v2 and I reinstall everything but ets2 does not work gameengine and gamemanager is active but in the games no movement version of the game 1.21 anyone could help me. thank you.
  11. value1
    15,073Coins
  12. DE CASTRO
    Cahors France
    621Coins
    2DOF, 3DOF
    I try give me always nothing engine and manager goes to blue but nothing moves in the games. an other idea. thank you.
    J
    u
    m
  13. DE CASTRO
    Cahors France
    621Coins
    2DOF, 3DOF
    Good evening after the installation of SimTools V2 and reinstall the plugins I have two games for the moment that does not work.
    GameEngine and GameManager changes color well but nothing happens on euro truck simulator 2 and NoLimits Rollecoaster Simulation if someone to an idea it would be nice thank you all
    bonsoir apres l'installation de SimTools V2 et réinstaller les plugins j'ai deux jeux pour le moment qui ne fonctionne pas.
    GameEngine et GameManager change bien de couleur mais rien ne se passe sur euro truck simulateur 2 et NoLimits Rollecoaster Simulation si quelqu’un à une idée ce serait gentil merci à tous
    152,529Coins
    +11,085 / 56 / -2
    SimTools 2.0 Input Settings - The difference from SimTools 1.3 to SimTools 2.0 in setup is that instead of axis defined like this <Axis1> it is now like this to designate grouping for a or b <Axis1a>
  15. DE CASTRO
    Cahors France
    621Coins
    2DOF, 3DOF
    For NoLimits it's ok forgotten telemetry but for ETS2 nothing to do it does not work I understand not for PCARS DIRT3 ASSETTO CORSA it's OK it works I do not understand
    pour NoLimits c'est ok oublié telemetry mais pour ETS2 rien a faire ça ne fonctionne pas je comprends pas pour PCARS DIRT3 ASSETTO CORSA c'est OK ça marche je comprends pas
  16. noorbeast
    152,529Coins
    +11,085 / 56 / -2
    Have you tried a base run for your Tuning Center values and can you post a picture of your Tuning Center while the game is running: https://www.xsimulator.net/community/faq/set-base-tuning-motion-values-in-the-tuning-center.122/
  17. DE CASTRO
    Cahors France
    621Coins
    2DOF, 3DOF
    That's what happens
    voila ce que ça donne
  18. noorbeast
    152,529Coins
    +11,085 / 56 / -2
  19. DE CASTRO
    Cahors France
    621Coins
    2DOF, 3DOF
    I have that too if it can help thank you
    j'ai ça aussi si ça peut aider merci
  20. DE CASTRO
    Cahors France
    621Coins
    2DOF, 3DOF
    I changed the language but alas still does not work
    j'ai changé le language mais hélas ne fonctionne toujours pas
