News SimTools 2.0 Question and Answer
Discussion in 'News' started by yobuddy, Feb 29, 2016.
Thread Status:
Not open for further replies.
  1. yobuddy
    51,567Coins
    Hi @MWB,
    could you try another game so we can rule some stuff out?
    thx buddy
  2. MWB
    MWB Drive it like you stole it!!
    Commissioning Engineer
    U.K.
    424Coins
    2DOF, DC motor, Arduino, Motion platform, 4DOF, 6DOF
    Yes I've tried that also!
  3. MWB
    U.K.
    424Coins
    Thanks yobuddy,
    I did also try Assetto Corsa! At what point should the the Game Manager say connected,
    When the Game Engine is opened or when the interface is correctly setup and connected?
    Mark
  4. SilentChill
    20,601Coins
    In Asseto Corsa GameRunning does not show until you are actually in the car on track
    Edit: Also you dont need any Interface settings for gamemanager to show game running as far as I can remember. Are you sure you have deleted all old simtools folders
  5. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,948Coins
    It's a windows 10 problem ... try to run both programs as administrator .
    Exactly when the Game Engine starts ... I have no interface listed and the status is "Connected" .
    If I quit the Game Engine ... it says "not connected "
  6. Nick Moxley
    Unless the Axis Assignment and Interface setting's Tabs are blue....You aint Connected to jack.
  7. MWB
    U.K.
    424Coins
    Thanks for all the help!
    @SilentChill, love your rig mate its a beast. I used add or remove programs in windows 10 to uninstall the old simtools and when prompted uninstalled associated files, but I have my suspicions that the simtools folder may have remained.:think
    @yobuddy If I uninstall Simtools again, can I re-register using the same key?
    @speedy I really thought your suggestion was going to be the one, but tried opening both programs as administrator.
    It's weird I just can't get it to connect. :sos
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
    It appears that your not patched. The connected status you are seeing is manager and engine. Axis assignments, interface settings will turn blue when you are connected to a game.
  9. bruce stephen
    general contractor
    michigan
    9,115Coins
    @MWB open the game manager.. Bottom left it is labeled tools press it. Take note of the ip address in the upper right of the drop down.
    Click engine IP what does it say? put in the same IP address from the first drop down.
  10. MWB
    U.K.
    424Coins
    I tried uninstalling Simtools and reinstalling it again! But I have the same problem, I have setup the interface and can control my sim from the output testing in game engine, I have downloaded Live For Speed installed it (C:\LFS) patched it (C:\LFS) and I can't get it to connect. I've tried running all programs as administrator. :(
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    Did you play lfs once before patching? This is required with this title I believe.
  12. bruce stephen
    general contractor
    michigan
    9,115Coins
    Do they match @MWB ?
    Missmatching these ip addresses allowed me to possibly duplicate your issue. This is why I ask.
  13. MWB
    U.K.
    424Coins
    Just checking now!
  14. MWB
    U.K.
    424Coins
    Ok no they didn't match
    First one was 192.168.1.196 and the second was 127.0.0.1 Set them the same, it prompted me saying I would need to re-patch the games, so I've uninstalled LFS patch, going to open it first then I'll patch it and I'll let you know how I get on.
    @bruce stephen
    154,028Coins
    +11,165 / 57 / -2
    ^ This is important, if you did not run LFS before patching then try unpatching, run LFS for a few laps and then repatch.
  16. MWB
    U.K.
    424Coins
    thanks @noorbeast, I'll give this a go, but I've never see the Game Manager say anything but Not Connected, I've set the Engine IP and Manager IP the same!
  17. bruce stephen
    general contractor
    michigan
    9,115Coins
    @MWB before we worry about the in game we need to get you set up so that when you open both the manager and engine it shows connected. Without this they are not "talking" to each other.
  18. MWB
    U.K.
    424Coins
    Agreed! :cheers
  19. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    hello I do I get a taken for the free version. I am sad to loose gamedash but exited to try the new version.
    I have build my rig when with the other with the other similar software. however I d be glad to show off my rig
    many thx for the great software
  20. Simon Husum
    Simon Husum Member
    Electrician
    Viborg, Denmark
    217Coins
    2DOF, DC motor, JRK, SimforceGT
    As mentioned before I too would like to know how to get the motors to center with the JRK's???
    Anyone? :)
Thread Status:
