2DOF compact race / flight with Oculus Rift
Discussion in 'DIY Motion Simulator Projects' started by reko19, Jan 9, 2015.
  1. Nick Moxley
    Hopefully its not a permanent think Reko, Im sure its just you guys getting used to VR and Motion together, Tho dont rule out a Fresh start on profiles and settings....V2 is a Whole new animal as far as track details go.
  2. Blame73
    Blame73 Well-Known Member
    8,304Coins
    Yes, make sure motion and game movements match, with the least delay as possible.
    I got nausea if I don't use motion!!
    Ah, one thing just came to my mind:
    are you using Post Processing ON in Assetto Corsa? It's bugged in VR (problems with rendering some far objects) and when I tried it I started suffering nausea after just few minutes. I turned it OFF and solved the problem.
    Someone don't feel the problem, so it's just personal. Give it a go
  3. reko19
    reko19 Active Member
    electrical engineer
    usa
    38Coins
    @Blame73 and @Nick Moxley Thanks guys, I will be upgrading to V2 and will also check post processing setting. Right now my monitor replicates exactly what is shown on VR, is there a way to have a "normal" game play shown on the monitor while using VR?
  4. reko19
    electrical engineer
    usa
    38Coins
    More toys to play with. So after 2.0 upgrade my plan is to try
    • Prepar3D
    • DCS
    • Elite Dangerous
    • Wings of Prey
    • No Limits
    Am I missing any other good games with the integrated VR support? Any other suggestions?
    Thx
      378.2 KB
      750
  5. Sebj
    Sebj Active Member
    Canada
    492Coins
    War thunder, AC, Iracing
    152,105Coins
    +11,065 / 56 / -2
    Try War Thunder, it is free and it takes practice to be even a mid level player in VR with a HOTAS, as you are up against fly by wire mousers in arcade mode, but it is free, the scenery is lovely, VR now woks well including menus, and there are always lots of players to compete against.
    If the arcade blast fest is not your style you can pick a plane for test flight and then use the mission editor to create a custom AI battle.
  7. reko19
    electrical engineer
    usa
    38Coins
    HOTAS has about three hundred buttons, unreal. Between that and creating profiles for all games, probably be done in another two years. :)
  8. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    I have that stick and love it. Mine is mounted on a detachable bar that connects to the underside of me simseat and then the hotas is on an arm that swins out and back around and is spring loaded with a pin that locks the hotas in place. Its a great stick, was pricey but worth it. [​IMG]
  9. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Here you can see where the stick is but I still remove it with a pin that locks it in place. I printed a cap for the bottom to see all the wire bits away [​IMG]
  10. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    and I highly recommend these pedals to accompany the stick[​IMG] and hotas [​IMG]
  11. reko19
    electrical engineer
    usa
    38Coins
    So you swap the pedals out every time you go between racing and flight sim?
    I was thinking of keeping the stick on the right hand side in the general vicinity of where the shiftier is. Not as authentic but more "user friendly".
  12. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    I have 3d printed tabs that the extrusions click in on the floor. I just slide them back when I drive. My pedals hang down and are custom made, they dont get in the way
  13. reko19
    electrical engineer
    usa
    38Coins
    So I got a download plugin package and it looks like some plugins for the games i listed above haven't been updated. Wings of Prey shows 2014 date for dlls. Would it work for v2.0, or would I have till an updated version is available?
    152,105Coins
    +11,065 / 56 / -2
    SimTools 1.3 plugins will not work with SimTools 2.0, you will need to wait for a plugin update.
  15. reko19
    electrical engineer
    usa
    38Coins
    Is there a way to tell which have been updated without downloading them first and looking at the date.
  16. noorbeast
    152,105Coins
    +11,065 / 56 / -2
  17. reko19
    electrical engineer
    usa
    38Coins
    Hey guys, HOTAS throttle control weights a ton. Since I will be mounting it to the chair armrest, it would be nice to get rid of that additional weight. I think this is just a dead weight so that unit stays put when being used. Anybody has any insights if this weight easily removable.
    Also, anybody has any great ideas on how to mount pedals so that are easily swapable between race / flight sim. I now have it bolted so it would be a pain to swap.
    thx
  18. noorbeast
    152,105Coins
    +11,065 / 56 / -2
    I have a mount plate on a tube attached with a single thumbscrew for my Hotas quick release setup.
    My pedal tray is the exact width for my Clubsport pedals, with the front plate of the pedals slipping over the front tray aluminum angle and the bolt heads preventing sideways movement. Nothing else holds them in place other than the tray design and angle.
    I just lift the pedals out and put in the Saitek rudder pedals and they are held by a full width packer plate that goes on the back edge and again the position of the bolt heads stops them sliding sideways.
  19. reko19
    electrical engineer
    usa
    38Coins
    i could do something similar and have a channel in the front and in the back. I currently have several holes predrilled to adjust the position if needed but we haven't really used them. Thanks for the idea.
  20. reko19
    electrical engineer
    usa
    38Coins
    So I successfully (I think) upgraded to V2.0. Transferred my axis assignment, min/max tuning values, etc from V1.3. Set interface type to JRK, output rate 20 ms. Still have to set main level % to 98 otherwise it kicks me out. It feels different from V1.3, is there a reason to change axis % allocation and min/max from the previous version and start tweaking everything again?
    Also, tutorial said that a game has to be un-patched and then patched again. I just patched with a new patch after downloading v2.0, didn't find a way to "un-patch" an old version.
