Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. Pit
    30,498Coins
    What do you mean?
  2. Pit
    30,498Coins
    Did you download the new (compatible) plug ins of SimTools 2?
    152,577Coins
    +11,087 / 56 / -2
    152,577Coins
    +11,087 / 56 / -2
    You need to fill in the form here: https://www.xsimulator.net/request-diy-key-simtools/
    When it is approved you get a discount code and can then follow these instructions: https://www.xsimulator.net/communit...-question-and-answer.8175/page-25#post-122220
  5. Blame73
    Blame73 Well-Known Member
    8,305Coins
    As it's written, you have to go in the project cars options (open the game and go to options) and enable "use shared memory"
  6. Blame73
    8,305Coins
    If this always happens
    the option is not active.
    If you say it is... I don't know how to help you out :oops:
  7. Blame73
    8,305Coins
    You don't have to, simtools 2 does it for you
    Have you tried just playing the games? (if you already configured the game engine)
    152,577Coins
    +11,087 / 56 / -2
    When you run Pcars does Game Manager turn blue?
  9. yobuddy
    51,221Coins
  10. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    hello what about gamedash ?is it functional in the pro version? version beta 1.1 does not work
    thanks
  11. Wanegain
    Wanegain Active Member
    Bruxelles
    2,010Coins
    No, I think I have it for the beginning...
    Maybe this picture can help (if you want the whole message, let me know)
    152,577Coins
    +11,087 / 56 / -2
    Can you please post pictures of your Interface Settings and Axis Assignments.
    Unfortunately your language translation is not clear.
  13. yobuddy
    51,221Coins
    It the next thing to be released, I'm almost done.
  14. yobuddy
    51,221Coins
  15. Wanegain
    Bruxelles
    2,010Coins
    @yobuddy
    Ok thank you, I will try tonight.
  16. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    I have bought a new SimTools 2.0 Professional Licence and received the code with email.
    I have downloaded the software but, PLEASE, I think it would be to add a help documentation about basic installation and configuration of the new software, for new users but also for all those who come from the previous 1.3 version.
    Follow a "tutorial help" will avoid committing more or less serious errors.
    P.S.: ...from what I understood, the license purchase has nothing to do with the plugins purchase, then these should be purchased through the XS Coin Shop or 1 year premium access as always!
  17. TFOU57
    TFOU57 Member
    Thionville - France
    5,723Coins
    2DOF, AC motor, Arduino
    Not being able to get a DIY license and like SimTools V2.0 demo only works with LFS (at least that's what I understood!)
    Is it possible and how to install V1.3 with the old plugin FsX and Fs2004 ... and install the V2.0 Demo and use it with LFS in order to get the hand so as not to be lost in the future?
    Bonjour,
    N'ayant pas pu obtenir de licence DIY et comme SimTools V2.0 démo fonctionne uniquement avec LFS (du moins c'est ce que j'ai compris !)
    Êst-il possible et comment d'installer V1.3 avec les anciens plugin FsX et Fs2004 ... et installer la V2.0 Demo et l'utiliser avec LFS afin de se faire la main afin de pas être perdu dans le futur ?
  18. maxx8888
    maxx8888 New Member Gold Contributor
    - 335Coins
    Thanks, has worked perfectly
    152,577Coins
    +11,087 / 56 / -2
    You must completely uninstall 1.3 to use SimTools 2.0, which has a free discount coupon for eligible DIY builders.
    Notice has been given that 1.3 will be depreciated in a year. The development focus on plugins and extended features will be with SimTools 2.0, not 1.3.
  20. yobuddy
    51,221Coins
    You are correct @Doctor Kruntz ,
    There are people working on such things.
    Have Fun,
