SimTools v2 - Game Dash v2.3
Format and Send Game Dash data to a device/program.
  1. jose bravo
    jose bravo New Member Gold Contributor
    ecuador
    - 108Coins
    Hi. Maybe ayone could help me with this? I follow all procedure to install Gamedash, but appear these screens. What must I do? In Game Manager, Dash ouput setings is enabled.
    All the best.
      25.4 KB
      961
      41 KB
      949
  2. Blame73
    Blame73 Well-Known Member
    8,304Coins
    Game Dash for Simtools v2.0 has not been released yet
  3. yobuddy
    51,030Coins
    This resource has been removed and is no longer available for download.
  4. yobuddy
    51,030Coins
  5. yobuddy
    51,030Coins
    yobuddy updated Game Dash with a new update entry:
    GameDash v2.0
    Read the rest of this update entry...
    • Winner Winner x 5
    152,099Coins
    +11,065 / 56 / -2
    Faster, more feature packed and portable across networked PCs...well done @yobuddy, yet another evolutionary step for SimTools!
  7. Doctor Kruntz
    Doctor Kruntz Active Member
    400Coins
    3DOF, SCN6
    Sorry for my very little preparation in this matter but... I can ask in which situation Game Dash can be used?
    It is a SimTools and SimTools - Remote Profiler accessory?
    Which we can make with this SimTools add-on and it has a manual which is available on its proper use?
  8. yobuddy
    51,030Coins
    You can check for GameDash compatibility in the plugin information section.
    The plugins also list what is supported in the download section of this site.
    It supports the creation of dashboards for SimTools 2.0.
    it allows you to reformat incoming values on the fly and send the data where needed.
    Projects like this buddy,
    There are help buttons embedded in the application to help show commands, etc.
    You don't need any output equipment to actually see it in use, play with the app.
    We working on how to vids now to go along side the updated manuals.
    Seeing something used I think will make it a lot easier for people that don't use English as their first language.
    And I can get a bit wordy in the manuals. lol
  9. Juan Pinto
    Juan Pinto New Member
    Homework
    Spain
    172Coins
    Hi all!, First of all thanks for your work guys, Game Dash seem to be the software that am looking for a long time, I startetd to made a Dash based on TM1638 display and now I want finish and share with community.
    Juan.
  10. minimus1899
    minimus1899 Member
    retired/broken/falling to bit
    lincoln
    163Coins
    hi, apology's for my rubbish spelling, I'm new to this forum and have purchased the pro version of the sim tools software to use game dash.... but..... I've followed the guide of the BMW e36 dash with shift lights..... anyway I load up live for speed and the windows error sound goes off over and over again and it make the dash work well only the rev counter but not 100% or to scale, help you can
    152,099Coins
    +11,065 / 56 / -2
    Can you please post pictures of all of your settings and likely a video would also help.
  12. yobuddy
    51,030Coins
    If we know how to "talk" to the device, then yes, we should be able to.
  13. eaorobbie
    20,481Coins
    More info on what output it needs, be easy to create something to make it work , beauty of gamedash , can be very flexible or i could easily code a sister app to recieve Gamedash data and rework it to make dial work, just need to know what it needs or a unit on loan to play with, work it out , make app and send back, prefer an Aussie unit. , We can just about do anything thats can be dreamt.
  14. Romain Seignour
    Romain Seignour Member
    - 115Coins
    Hello Guys for Start really thank you at yo buddy and his team for the work acomplished ( sorry for my best english)
    I need to used Gamedash for Fan simulations i have take this dimmer motor http://www.ebay.fr/itm/2CH-AC-LED-L...060338?hash=item1c83c8d132:g:jmUAAOSw~FJZGXXD
    and all the game dash setting is ok but my fan won't Start i show you the code and the picture to my configuration i hope you see the error
    again really great works for simtools all applications is really the best
    Code:
    Using AC Phase Control Circuit.
    http://www.ebay.fr/itm/2CH-AC-LED-Light-Dimmer-Module-Controller-Board-ARDUINO-RASPBERRY-Smart-Home-/122470060338?hash=item1c83c8d132:g:jmUAAOSw~FJZGXXD
    This is my code to fan simulations
    //***************************** DECLARATIONS // PIN ******************************
    #include <TimerOne.h>
    unsigned char channel_1 = 7;    // PIN 7 sur CH1
    unsigned char channel_2 = 6;    // PIN 6 sur CH2
    unsigned char CH1, CH2;
    unsigned char i=0;
    unsigned int delay_time=2500; // delay ms or SPEED
    unsigned char clock_tick; // variable for Timer1
    int Speed = 0;
    int SpeedGameDash = 0;
    int bufferArray[4];
    int oldSpeed = 0;
    int speedmax = 400; // A partir de cette vitesse les Ventillos seront à fond
    //************************ SETUP (1 fois au demarrage) *************************
    void setup() {
      // put your setup code here, to run once:
      pinMode(channel_1, OUTPUT);// PIN 7 sur CH1
      pinMode(channel_2, OUTPUT);// PIN 6 sur CH2
      attachInterrupt(1, zero_crosss_int, RISING);//PIN 3 sur SYNC
      Timer1.initialize(100); // set a timer of length 100 for 50Hz or 83 for 60Hz
      Timer1.attachInterrupt( timerIsr );
      Serial.begin(9600);
    //************************* LOOP DE CONTROLE DE DIMMING************************
    void timerIsr()
    clock_tick++;
    if (CH1==clock_tick)
    digitalWrite(channel_1, HIGH); // triac firing
    delayMicroseconds(10); // triac On propogation delay (for 60Hz use 8.33)
    digitalWrite(channel_1, LOW); // triac Off
    if (CH2==clock_tick)
    digitalWrite(channel_2, HIGH); // triac firing
    digitalWrite(channel_2, LOW); // triac Off
    //****************** FONTION "ZERO_CROSS" PILOTEE PAR LA PIN 3 *****************
    void zero_crosss_int(){  // function to be fired at the zero crossing to dim the light
    clock_tick=0;
    void loop() {
      ReadData();
      CalcDimming();
    //********************* LECTURE DES COMMANDE DE SIMTOOLS ***********************
    void ReadData(){
      while(Serial.available()){
      if (Serial.available() == 4)  {    //if 4 bits available in the Serial buffer...
            int i;
            for (i=0; i<4; i=i+1) {       // read and label each byte.
             bufferArray[i] = Serial.read();
             if (bufferArray[0]  == 'S'){
               SpeedGameDash = ((bufferArray[1]-48)*100) + ((bufferArray[2]-48)*10) + // Take values 1-3.
                                   ((bufferArray[3]-48)*1);
           if (bufferArray[0]  == 'E'){
               SpeedGameDash = 0;
    //****************************** FONCTION DIMMING ******************************
    void CalcDimming() {
      if (SpeedGameDash > speedmax){
        SpeedGameDash = speedmax;
      if (oldSpeed != Speed){
        int oldSpeed = Speed;
        Speed = map(SpeedGameDash, 0 ,speedmax, 0 , 100);
        CH1=Speed;
        CH2=Speed;
  15. yobuddy
    51,030Coins
    @Romain Seignour,
    From the ard code it looks like you need to feed the output like this
    S<Dash1> (but the dash value always needs to be 3 bytes I think)
    So you need to add the command (Pad 3 0) to the speed Dash value.
    For a test, see if this works for output.
    S100
    This should pass the value of 100 to the ard.
    let me know how it goes buddy.
  16. yobuddy
    51,030Coins
    yobuddy updated SimTools 2.0 - Game Dash with a new update entry:
    SimTools 2.0 - Game Dash v2.1
    • Winner Winner x 3
  17. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    Great improves on 2.1 ! Awesome thanks ! ( still waiting for sim vibe support ;) )
  18. L.Dörenberg
    L.Dörenberg beginner Gold Contributor
    car bodyrepair
    Netherlands
    - 65Coins
    Im not into this technical stuff but thanks yobuddy for the work and time you put into!! Leroy
  19. Hoddem
    Hoddem Well-Known Member
    Engineer
    Minnesota, USA
    3,343Coins
    Thanks for the great addition, I am currently trying to implement fans and struggling pretty bad. I have my arduino program setup to receive serial commands in the form of S followed by a three numbers to represent the speed. for instance at S100 would turn the fans on full speed and S000 would turn them off. I can confirm this works great by opening up the arduino serial monitor and manually typing in different commands. however I cannot for the life of me get game dash to send the commands to the arduino. I have iracing working to the point that I can see values being updated in game dash but again no output to the arduino.
    I am running windows 10 with an arduino uno on com 12. the arduino is setup for a baud rate of 9600.
    speed dash is using output S<Dash1> on interface 1
    Math is setup as
    MATH * 1
    ROUND 0
    PAD 3 0
    I have purchased a pro license which i understand is required to get dash working, but it seems like i am missing something simple.
    any help is greatly appreciated
    EDIT
    I created a 2 virtual ports and linked them and I can see data output from the game engine when I do axis testing. however I get no output from game dash when applying the same method. It seems like I need to somehow turn on game dash output and I don't know how.
    I have also tried the virtual output within game dash and I get nothing.
  20. Hoddem
    Engineer
    Minnesota, USA
    3,343Coins
    I got it working, everything was correct, I just uninstalled/reinstalled game engine, game manager and dash. everything is working now.
