value1
Codemasters F1 2016 plugin 2.0.0.1
SimTools plugin for Codemasters F1 2016
  1. Sarge
    Sarge Active Member Gold Contributor
    - 181Coins
    I thought the values in the min and max were too large, but I've tried everything from 0 to 20. My latest min/max settings looked like this:
    I'm not sure if this information will be of any help, but the previous plugin for simtools 1.3 was based on the Dirt Rally plugin. Something to do with dbox support if I remember right. I had a chat with yobuddy about it when I was testing an early version of the plugin for simtools 1.3.
  2. welen123
    welen123 Member Gold Contributor
    HongKong
    35Coins
    This is the reason why I love simtools!
  3. Sarge
    - 181Coins
    Hi All, Just in case anyone is interested, I have managed to get this plugin working. The fix turned out to be really simple... although difficult for me as I am trying to learn :'(
    It turns out that the plugin doesn't change the 'dbox enabled' line in the hardware setting config to <dbox enabled="true"/> . If you manually change this in both the hardware_settings_config.xml and the cfg.BAK file, the plugin then works. It has also fixed the heave error I was getting above in my earlier post.
    Anyway, I hope this helps anyone trying to play this game,
    Happy racing :)
    • Informative Informative x 3
  4. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, the future plugins f1 2017 or dirt 4 will work with my version simtools 1.3 thanks
  5. yobuddy
    51,002Coins
    @bruno1210 ,
    No, sorry buddy.
    All future plugin are now focused on SimTools 2.0.
    SimTools v1.3 has been tucked away in my private library of apps incase I need something from it later.
  6. Leandro Kemp
    Brasil
    - 10Coins
    Don't work for me. I tried the tips
  7. Leandro Kemp
    Brasil
    - 10Coins
    Has anyone got a solution?
  8. Leandro Kemp
    Brasil
    - 10Coins
  9. SteVoortwis
    SteVoortwis New Member Gold Contributor
    Netherlands
    142Coins
  10. Leandro Kemp
    Brasil
    - 10Coins
    Hello, how are you?
    I sell the sim motion.
    I've already bought 5 pro licenses and I'm needing support for the F1-2016.
    I already contacted you a few times and also posted on the F1-2016 topic and did not get answers.
    It turns out that no movement is transposed to the platform.
    I have already reinstalled the plugin and patch.
    Could you give me a hand or check if you need an update in the plugin?
    Tankyou
  11. SteVoortwis
    Netherlands
    142Coins
    Hi
    I got it working changing udp to true in bak and hardware settings config. and the port adress.
    But the movements roll and pitch in F1 2016 are not what it suppost to be, think is still a flaw in plugin.
    Can somebody look true the plugin file maybe?
  12. Leandro Kemp
    Brasil
    - 10Coins
    OK.
    I will try this.
    What's the correct Port adress?
    Could you send me an image showing what i need to change?
  13. SteVoortwis
    Netherlands
    142Coins
    Hi I changed this in my hardware settings file and .BAK file. (You can find them in C:Documents/My Games/F1 2016/hardwaresettings) I don't know if this port i am using is the same in your sim. I used the same port what i am using in Dirt Rally.
    The movements i have in f1 2016 are a bit off, especially Roll movement. but pitch is to early or something.
  14. Leandro Kemp
    Brasil
    - 10Coins
    I tried it like this and changing it false and true without changing the port.
    Did not work.
    I give up
  15. Leandro Kemp
    Brasil
    - 10Coins
    You gave the following error after the changes in hardware settings.
    I tried other combinations of fake and true and also did not work.
    Changing the adress port and without changing.
      112.5 KB
      670
      74.9 KB
      697
  16. SteVoortwis
    Netherlands
    142Coins
    Hi value1,
    I have a question about your F1 2016 patch. I belive There are still some errors in it. Movements are not in sync or completely different. Can you look to it or does somebody else have an Idea. By the way I have the same readings as Sarge in tuning center
    Many thanx!!
    152,009Coins
    +11,061 / 56 / -2
    There may or may not be a plugin issue, but there is likely to be a problem using values that are for another rig, unless they are exactly the same design and hardware, as a motion profile is tuned to suit a particular simulator: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
  18. SteVoortwis
    Netherlands
    142Coins
    Thanks for your advice. I managed to get the right settings in axes assignment and tuning manager.
  19. yobuddy
    51,002Coins
    Could someone post the unpatched "hardware_settings_config.xml" file for this game?
    I would like to compare the file to the 2015 version, as it appears to have changed?
    @SteVoortwis,
    would you please set "udp1 enabled = false", "udp2 enabled = false", "udp3 enabled = false".
    And see if you still have motion, my guess is you only need udp0 enabled.
    Have all 4 sending to the same receiver, may diminish the ride some.
    Thanks everyone!
  20. RhaR
    RhaR New Member
    USA
    - 29Coins
    I have no idea. It doesn't work. No any action for my system. However, both LRS and F1 2015 work properly.
    Someone has the same problem?
