2DOF compact race / flight with Oculus Rift
Discussion in 'DIY Motion Simulator Projects' started by reko19, Jan 9, 2015.
  1. noorbeast
    152,099Coins
    +11,065 / 56 / -2
    Unpatching is done via Game Manager.
    SimTools 2.0 is more responsive and interfaces with JRK natively now, so it is worth tweaking your profiles to get the most out of your sim.
  2. Blame73
    Blame73 Well-Known Member
    8,304Coins
    If you completely uninstalled 1.3 and deleted settings when you've been asked to, during the uninstalling process, then you already unpatched all previous games.
  3. reko19
    reko19 Active Member
    electrical engineer
    usa
    38Coins
    thank you, i was wondering what i did wrong
    @Nick Moxley was a lot of help today, profile tweaking is a freaking endless process ....
  4. reko19
    electrical engineer
    usa
    38Coins
    Spent few hours last couple of days working on the assetto profiles. For some reason game engine keeps kicking me out. With v1.3 this was happing during a crash, etc. With v2.0 I don't think it happens when I crash. I am yet to figure out why this is happening. I am planning to replace my USB cables with something beffeer and then maybe replace USB hub that jrks are plugged into.
    152,099Coins
    +11,065 / 56 / -2
  6. reko19
    electrical engineer
    usa
    38Coins
    Proportional 0.75, integral 0.4, derivative 1.0. I was running same settings with 0.3 integral on 1.3. My PC is right next to jrks so I am not sure how helpful changing the cables will be. Very frustrating.
    Is there USB3.0 cable, looked at amazon mostly if not all 2.0.
    152,099Coins
    +11,065 / 56 / -2
  8. reko19
    electrical engineer
    usa
    38Coins
    @noorbeast i am familiar with this very useful thread and video. I also noticed native jrk support in simtools. What I didn't realize is that "some tweaking" is in order. So if I follow you correctly, I could tealax some of the PID settings and get the same response because of the native support? it is unfortunate that we can't run simtools and Jrk utility at the same time amymore, it was pretty convenient.
    Thx
    152,099Coins
    +11,065 / 56 / -2
    Not being able to run the JRK tool and SimTools at the same time is the unfortunate side effect of using the native API.
    Tuning the PID is a bit like refining a motion profile, it is somewhat unique to each sim and is worth checking.
  10. reko19
    electrical engineer
    usa
    38Coins
    So after spending a couple of hours tearing everything apart and putting it back together it looks like cables replacement did the trick. I finished late last night and didn't have a whole lot of time but based on preliminary tests I am no longer being kicked out from the game engine. JRKs are still connected to a USB hub and cables only have ferrite filter on one end, so there is still room for improvement should the issue persist.
  11. reko19
    electrical engineer
    usa
    38Coins
    found this video on assetto corsa settings, i thought it was pretty useful:
  12. reko19
    electrical engineer
    usa
    38Coins
    Was able to successfully setup No Limits 2 for motion (with some help from @noorbeast) . Could've saved myself an hour if I paid attention to instructions and put "--" instead of "-" in front of telemetry. I attached my settings, please comment away. Axis 1 and 2 are shoulder motors, axis 3 is traction loss and axis 4 is surge. I also have 35% smoothing for roll, 50% smoothing for sway, and 40% smoothing for yaw. Also notice that I don't have yaw assigned to shoulder motors, after experimenting a bit I think it works best with the traction loss axis. I also opened tuning a bit for a smoother motion as compared to more snappier response I have in Assetto. Any suggestions are appreciated, cheers.
  13. noorbeast
    152,099Coins
    +11,065 / 56 / -2
    Generally it helps to post both the settings and a video of the rig in action showing its movement and the game screen at the same time.
    That way members are in a better position to advise about possible further tweaks.
  14. reko19
    electrical engineer
    usa
    38Coins
    Will do although I suck at this.
  15. reko19
    electrical engineer
    usa
    38Coins
    Major issue tonight. The hollow tubing that u-joint is attached to gave in under my weight. Relatively easy fix, but I have to tear the whole thing apart. I just finish dressing up the wiring, permanently mounting everything in place, etc. Just started to enjoy the darn thing...Oh, well.
  16. noorbeast
    152,099Coins
    +11,065 / 56 / -2
    Ouch!
    There is always some tweak, improvement or upgrade to do, so you tend to get pretty good at tearing your own sim apart :grin
  17. reko19
    electrical engineer
    usa
    38Coins
    updated pictures of this never ending project...
      383.7 KB
      740
      451.9 KB
      792
      220.3 KB
      780
      267.6 KB
      753
      282.2 KB
      787
      357 KB
      791
      241.3 KB
      795
      468.3 KB
      768
      316.5 KB
      810
      320.3 KB
      768
      210.8 KB
      753
      376.7 KB
      795
      336.4 KB
      751
      240.3 KB
      787
      363 KB
      775
      312.3 KB
      713
      356.3 KB
      696
  18. Hoddem
    Hoddem Well-Known Member
    Engineer
    Minnesota, USA
    3,343Coins
    Wow, every time jump on the forum I feel like starting over. I'm building a seat shaker, but I want traction loss. After seeing your rig I am drooling over surge. Very Nice Machine. I will be keeping an eye on this thread for my next build.
  19. reko19
    electrical engineer
    usa
    38Coins
    Thx. I am by no means racing expert, but I feel and enjoy surge a lot more than a traction loss.
  20. reko19
    electrical engineer
    usa
    38Coins
    Hi everyone, I am back and finally got around to setting up war thunder and have some questions.
    For some reason I don't get any movement captured on roll and pitch axes, pls take a look at the screenshot.
    Also I was wondering how you are handling switching between controls. Once I connected my HOTAS Warthdog, it completely messed up my AC settings and I had to reassign all controls. Is this a one time deal, or should I disconnect controllers that are not used for a particular game? I hope this is not the case.
    Lastly, could someone pls tell me where sim tools stores games presets so i could delete old ones i no longer need? I managed to mess this up as well and has to re0enter all the settings. It ios not very intuitive as you can't really select from the drop down list of the old presets, need to type the name and then it overwrites it.
    thx
