How to convert Simexperience motionrig to Simtools
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Gelatin, Sep 8, 2014.
  1. noorbeast
    153,697Coins
    Try the relevant FAQ section: https://www.xsimulator.net/community/faq/scn5-scn6.2/category
  2. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    I did but no clear info for what I may try to do
    How many wires, colors , purpose of the wires in the simxperience plug are unknown to me .
    If someone could summaraise what are those wires going to that plug that would help greatly
    I guess I would have to remove the plsatc cap and compare to the snc5 I already have in my rig . It would be possibly easier that way ...
    however I may not buy that actuator and not take a chance as I am not really in my confort zone
  3. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    Hello Gelatin are thes the wire I should see inside the plastic cap of any snc5 ? These are the one we use for motion ?
    thanks
  4. Jacob Pederson
    Jacob Pederson New Member Gold Contributor
    USA
    223Coins
    I'm having issues trying to make this work related to the assigned axis's are now 1a-6a and 1b-6b . Do I want a 1a and a 2a or a 1a and a 1b ? Thanks!
  5. abs
    consultant
    Montreal
    764Coins
    3DOF, SCN5
    Hello Jacob , it could be that the older model sx3000 is not compatible with sim tools? Anyhow, for one thing you could use a devantech rs485-USB or similar interface and rewire the controls. I believe you d need only one interface per snc5. I ll edit this reply later with info about rs485
    http://www.ebay.ca/itm/FTDI-USB-to-...642426?hash=item3ad715f07a:g:RikAAOxyeZNTR99F
    or http://www.robotshop.com/en/devantech-usb-rs-485-interface.html
    your can rewire quite easily . there is doc available in here
    edit : noorbeast understood you question. sorry I did not. ibelieve you ll be ok...
    153,697Coins
    In most cases the Axis Assignment grouping will be 1a, 2a and so on.
  7. Jacob Pederson
    USA
    223Coins
    Thanks guys! It was 1a and 2a that I needed to make it work. Elite Dangerous is a go :)
  8. patritti
    patritti simracer
    composite race car parts manufacturing
    woodstock GA usa
    516Coins
    3DOF, SCN6
    i run on my rig 3 simexperience 150mm SCN6 with the sim experience box . did have to modified or change anything . i can start the rig with sim experience or sim tools on the fly .
  9. nipzon
    nipzon New Member
    Sparky
    Melbourne
    - 17Coins
    3DOF, SCN5, Motion platform
    I need some help please. Reading thru the posts it is still unclear to me does Simxp use the grey wire to +24V or 0V
    Talking to shige from Frex he says they use the grey wire to 0V not +24V
  10. stashy
    stashy Member
    india
    - 238Coins
    2DOF, SCN6
    hi im using sx-4000 with scn6 and im getting error one of your interface requires game engine to be restarted
    fixed it now trying to learn sim tools
  11. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    @stashy
    Asking the same question in multiple topics is not going to help you get the answer quicker..
    And be more detailed about what have you already done until the error appeared.
