Codemasters Dirt Rally Plugin 2.0.0.3
SimTools plugin for Codemasters Dirt Rally
  1. MPG
    MPG New Member Gold Contributor
    Netherlands
    57Coins
    Have the solution, it does not work with simxperience commander 4, at the same time.
    I use that for SimVibe Chassis mode
  2. Brett Horton
    Brett Horton Active Member
    Program Manager / Pilot
    Tampa FL
    118Coins
    remember Nick....... VR here... lol
    Red headed step child here...
  3. Brett Horton
    Tampa FL
    118Coins
    And I use Sim Vibe as well... But sometimes it does work... just mostly not...
    But I use SimVibe for ALL my other sims as well and works perfectly every time..??
  4. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    I use VR too and I must dismiss this issue to be specific to you and your setup.
  5. Brett Horton
    Tampa FL
    118Coins
    I don't disagree with that statement lol.... But it works with everything else... :)
  6. MPG
    Netherlands
    57Coins
    Yes,everything works well except for dirt rally
  7. SilentChill
    20,585Coins
    I have been using v2.0 plugin for almost a year and the only problem I ever had was the 0 value problem for surge. That has now been filtered and is not an issue.
    Anyone having problems with the game I suggest unpatching and deleting everything to do with the plugin.
    I would then do a verification of DirtRally through steam to make sure all your files are correct and up to date. If you using a pirate copy that's just stupid and your wasting everybody's time
    Then once it has been verified go through the install of the plugin and the patching procedure and see if it works. Once you have done the above and it is still not working come back and lets see what I can do to help.
  8. stevemontuno
    stevemontuno Active Member
    1,461Coins
    I think Codemasters proxy server is the problem here,,Well for all you simvibe users anyway ,,,It's an easy fix ,,go to the link and click the Grey download box at the bottom of the page for codemasters proxy server app and follow the steps in the video ,,, for reference Simtools UDP port is 4123 with API 3,, Fanaleds is 30500 with API 1 ,,, he also tells you the simcomander UDP port number in the video and how to set up simcomander software with it ,,
    http://www.eksimracing.com/cmps/
    I think you can also use simcomander to do this but im not sure how to do it that way
  9. Brett Horton
    Tampa FL
    118Coins
    Nice thanks! Will try soon.....
  10. shannonb1
    Sales Intelligence
    Virginia
    8,909Coins
    Please do not speak of piracy on this site as it is not permitted by our community guidelines and disrespectful to our developers and our partners in the community.
  11. Brett Horton
    Tampa FL
    118Coins
    lol.... I was referencing an above comment
    I was joking
  12. Leandro Kemp
    Brasil
    - 10Coins
    Hi.
    Same problem they reported.
    I'm testing version 2.0, it does not work sway, surge and heave.
    When the vehicle is stopped pulls many values, but when it begins to advance the values of these axes are paused.
    The rest of the axes works.
    Which may be?
    I've tried the tips given full screen, max min capture, and nothing worked.
    In 1.3 working perfectly
    Video showing the problem.
  13. Aloha21x
    Aloha21x New Member
    112Coins
    I have the same issue. I tried to cut and paste the folder game on an other disk , and the speciale that I take to test, bug but not in the same spot of the track.
    I tried to delete all the game via steam, and resetup but problem is come back as first.
  14. alxdr
    alxdr New Member
    IT
    - 39Coins
    Does somebody have a link for the old 1.3 plugin version cause I don't reveived my DIY V2 licence yet... :blush
    151,461Coins
    +11,038 / 56 / -2
  16. alxdr
    alxdr New Member
    IT
    - 39Coins
  17. SilentChill
    20,585Coins
  18. hyper1966
    hyper1966 Domenic
    Edmonton QLD Australia
    833Coins
    2DOF, JRK
    Can some help me please Codemasters Dirt Rally Plugin 2.0.0.2 doesn't seem to work with Game Dash ,its not present in Sims tool profile editor .Work fine before with sims tool 1.3 version .Look at picture ,I have added pic of Profiler Thanks Domenic dirt rally.png
  19. yobuddy
    50,746Coins
    Confirmed Working!
    Could someone with the dirt rally game and plugin installed try editing the DBOX line of the hardware_settings_config.xml to True?
    Then run the game again and see if it makes a difference.
    Since they added DBox support for this game, I wonder if its messing with the UDP output?
  20. prosimu
    prosimu Member Gold Contributor
    - 900Coins
    Dbox = true motion is ok
    Remove Heave parameters in axis assigments ( put heave = 0)
    The pitch and roll value from the game are ok (tuning center and real test)
    Sway Surge and Yaw Values from the game are freezing during many seconds, depending of track.
    We must wait that Codemasters improve the telemetry or just use the pitch and roll value inside Axis assigments.
    Thx Patrick
